I have a Technics stereo cassette deck model - Audio Players & Recorders
I have a Technics stereo cassette deck model RS-B28R that is missing it's power cord...indicates "AC 120 V"..where do I obtain one..from Technics? Are they still made or is there a standard power cord that would fit it?..Jim in Lehigh Valley PA
Technics stereo cassette deck rs az6 spares
Tape belts are universal generally. All you do is measure the diameter of the belt in MM and if it is wider than the "string" type the width in MM again. Put the words "cassette drive belt xx MM" into Google. You don't have to precise with the measurements.
Feb 23, 2014 | Technics Audio Players & Recorders
The doors of my technics deck RS TR575 don't open or close when I press open/close switch, it sound , but not responding. Please help me Thanks Manuel
It's a simple job for a repairer - if you can find one that will have anything to do with audio cassette technology anymore, sorry, but I'm finding that some won't.
Not knowing where you are I don't know which currency you use but if it helps, here in the UK I'd say don't spend more than £25 on this.
There are still new cassette decks made and lots of good used ones around.
I know Technics is a very good make but I was looking at superb condition Nakamichis the other week for £35 which are a far better brand.
Sep 21, 2011 | Technics RS-TR575 Single Dual Cassette...
I can't find the manual to my Technics RS-TR272 Stereo Cassette Deck. How do you tape something on one cassette to another?
Place the tape you want to record into the left deck, Then the blank tape into the right deck. Press play on the left deck and record on the right deck.
It may be opposite depending on which side your recording deck is on.
Which ever deck has record, place blank cassette into that one and the cassette you want to copy into the other deck.
Hope this helps and please rate thanks
Mar 13, 2011 | Technics RS-TR272 Single Cassette Deck
I need the power cord.
you might find that a general power cord of a electric kettle works just the same there all standard pwer cords 2 or 3 pin
Feb 07, 2011 | Technics RS-TR373 Single Cassette Deck
Where can I find a power cord for my technics stereo cassette deck RS-B282?
Not sure what is odd about it-is it a regular IEC 3-prong? Mouser may have a cable if it's something else.
Dec 20, 2010 | Technics RS-TR373 Single Cassette Deck
Power to technics rs-t24 dual deck
I own a RS-T24 as well and stumbled upon this thread while searching for this exact same solution. The RS-T24 generates no power on its own. It gets its power from, in my case, the SU-V75 amplifier. I still have a working SU-V75 and got the following readings out of the plug-in for the RS-T24 on the amp:
Left = pin 1 - (white wire)
Middle = pin 2
Right = pin 3
1-2 = 11.5 vac
1-3 = 23.0 vac
2-3 = 11.5 vac
Jan 30, 2009 | Technics RS-TR272 Single Cassette Deck
Missing ac plug for receiver
If the AC plug is the standard "D" shape with the indents for polarization of the cord on both units, yes ou can.
Dan
Mar 25, 2008 | Technics SA-EX510
127 people viewed this question
 Grubhead
Grubhead
