Question about Dishwashers
Kenmore model 17692200 don't fill unless i play
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: My Kenmore ELite 630.16309406 dishwasher
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Posted on Sep 15, 2011
er_vardansha
  • 4 Answers
SOURCE: whirlpool quiet partner i5 dishwasher..I installed a new water line and now water won't fill. The float is down..Any suggestions
Its possible that there is air in pipe..
Also the hight of ur washer is high..
Posted on Nov 28, 2012
Dishwasher won't fill with water
Hi
When the Dishwasher won't fill you'll need to check for the water inlet hose, the water inlet valve and the float switch assembly. When the water fills your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the float switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Kenmore Dishwashers
Do not clean dishes very well
Hi
If the water inlet valve is fine and it fills with water then the issue seems to be with the float switch assembly that is bad and should be replaced. Float assembly is found inside the dishwasher's tub, on the bottom. The water that fills the dishwasher lifts the float, and when it reaches a certain level, it acts as a trigger for the float switch. The float triggers the float switch to shut off, thereby shutting off the flow of water into the dishwasher. A defective switch may interfere with dishwasher's filling and/or draining ability. Use voltmeter to test the switch. Set the device to the ohms setting x 1. Take each probe and touch them to one switch terminal each. This should produce a reading of either zero or infinity. Continue to touch the probes to the terminals, and press down on the switch's button. The reading should change to the opposite extreme. If the switch fails either of these tests, you should replace it. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Kenmore Dishwashers
We have a Kenmore Elite 16579. The soap as stopped dissolving and the dishes are not getting clean. There seems to be good amount of water, and good heat.
Hi
Daniel
Kenmore 17621 model--wife says it's making all the right noises,but no water entering.removed bottom panel-no filter visible.obstruction in water supply line is my guess.
Open the door and look for the water level float in the bottom of the dishwasher.
Make sure there is nothing stuck under the float holding it in the up position.
Wiggle the float up and down to make sure it can move freely and then run the dishwasher again to see if it fills with water.
If the float is not stuck up then chances are you will need to replace the water inlet valve.
If you know how to use a volt meter you could check to see if voltage is at the valve during the fill cycle. If there is voltage to the valve but you are not getting any water then you know the water inlet valve is bad for sure.
I find that 90% of the time I need to replace the water valve on dishwasher that no longer fill with water and the other 10% of the time I find the water float is stuck.
Aug 07, 2011 | Kenmore Dishwashers
Ishes don't come clean in dishwasher
Hi
Daniel
Aug 05, 2011 | Kenmore 16602 / 16604 / 16609 Built-in...
I have a white film on my dishes after i wash them in my Kenmore Elite dishwasher. I use Cascade powder. any suggestions?
Hi
Daniel
Jul 21, 2011 | Kenmore Dishwashers
I have a Kenmore built-in dishwasher and just recently when I take the dishes out there are food particles or residue on the dishes after the wash. I changed from capsule soap to liquid soap thinking that...
Hi
Daniel
Jul 20, 2011 | Kenmore Dishwashers
Kenmore dishwasher 15894 water not coming out and soap pod not opening
Hi
When the Dishwasher is not filling in, you'll need to check for the water inlet valve, the filter screen and the float switch/assembly. Also check for the float assembly inside the dishwasher. When water is filling your dishwasher, a float rises along with it. As the float reaches a certain threshold level, it shuts off the flow of water, thereby preventing a leak. Sometimes the float can get stuck in the wrong position in your dishwasher, and it can prevent your dishwasher from filling. Sometimes it can happen due to float valve and on other occasions due to float switch. Inspect the water hose coming to the dishwasher for any blockages.
If these are fine then it's due to Water Inlet Valve. Use a multimeter and check for the continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly.
Daniel
May 18, 2011 | Dishwashers
No water is coming in the dishwasher. I can hear the water running, but the water is not coming into the dishwasher
If you can hear the water running - but it's not filling, you most likely have a drain problem, which is being stuck open. Usually the motor kicks in and either pumps the water through the wash arms (during wash cycle) or through the drain (during drain cycle) the switch that/or flap could be stuck on the drain and it is pumping it out the drain all the time instead of the wash arms.
Apr 18, 2011 | Kenmore 1348 Builtin Dishwasher
Dishwashers Logo
27 people viewed this question
Top Dishwashers Experts
Owen Barnes
