Question about General Electric Cooktops
Words worn off knobs
The knobs for the oven have the words worn off, I can't tell which is bake or broil etc.
Display panel dim
The display on my cooker started to dim until it finally went dark over a few weeks. Although a different make, I replaced the panel and everything is now fine. I was amazed how bright the new display was so it must have been dimming over a long period.
Nov 01, 2015 | Dacor Discovery ER30DSRSCHNG 30" Slide-in...
I have FGES3065KFA gallery and I have baking problems. It bakes outside of the cake but inside of the cake stays raw. Me and my husband check the bake and broil element they work fine. We change the...
read the mixture instructions
try preheating the oven for the required temperature or when the thermostat turns the light off
insert the cake to be cooked and leave it there for the desired time
Too hot will burn the outside with out cooking all the way through
check the ingredients carefully as if the mixture is too wet ( butter, milk, water all make it wetter than required )
Place the cake in the center of the oven ( not on the bottom shelf or the top shelf)
All these may sound mundane but they all point to getting a good cake result
Sep 14, 2015 | Frigidaire FGES3065KF Gallery 30" Slide In...
My frigidaire fef368gch was working fine and then the oven just stopped baking. It will broil but not bake. What causes this and how do I fix it?
Good Morning Shari,
I see that you are having trouble with your Frigidaire range, model# FEF368GCH, and the bake element not working while the broil element is. I suggest giving your appliance a hard reset, by shutting the power off at your home's circuit breaker, for 2-3 minutes. When power is restored, you will have to reset the clock by entering in the time and pressing start. Start a bake cycle, and if you notice that the bake element is still not working, I suggest contacting your local authorized technician. Hope this is helpful.
-Best Regards-
WP
Apr 23, 2014 | Frigidaire FEF368GC
E1234 flashing
I noticed the same thing with my Samsung oven. The repair tech was just here and figured out (with Samsung phone support's help) that it is normal behavior when the divider is inserted. You will notice, if you look carefully, that the E1234 is showing in some pictures in the manual when it talks about using the oven with the divider in. Bottom line is you can ignore it.
Sep 10, 2013 | Samsung 5.9 cu. ft. Freestanding Flex Duo...
We have as Whirlpool FXTM6 induction oven .. (and no manual). The display stays on 'STOP' no matter what you do.. how do i get out of this?
We discovered if you press in both the oven control knob and the temperature control knob simultaneously for several seconds, the stop message goes away and the oven returns to normal.
Jan 27, 2013 | Whirlpool Cooktops
Broil on oven come on then goes off
you might have a short somewhere in your oven.
Nov 13, 2012 | Maytag Stove / Oven / Range Cooktop -...
Oven dont turn on ihave checked the braker is ok
have you turned the control knob to broil and the temp all the way up, this will check to make sure you have a good switch on your selector. then turn onto bake and turn all the way up. let me know
Feb 03, 2010 | Cooktops
Bake and broil do not work
assuming that the worst case senario has taken place
first thing i would check is ensure i have proper voltage at the outlet, 120 from each side to ground
220 across L1-L2
the elements are the only thing on the range that uses 220v
if you know how to use a mutimeter
you can test both the elements
disconnect the range at teh breaker
take out the screws at the back wall that hold the elements in
pull out about an inch becareful they dont leave much slack on the wires
disconnect on element terminal and apply your leads your looking for continuity, your meter should beep
if not replace the element
if yes, let the element hang ensureing niether terminal touches anything, reconnect the other terminal
now turn the stove on bake if your doing the lower
turn you meter to ac voltage
you should read 220v
anything less than that, your problem is before that
Aug 02, 2009 | Maytag 30 in. Admiral LGC1330 Gas Cooktop
JENN-AIR MODEL D156B Electric oven
code f 0 means what?
Feb 11, 2008 | Cooktops
Sve47100 oven doesn't heat
Test the swtich w/ multi tester /connect tester as a jumper to the switch dettach one line on and off switch /if does not reponse / replace the switch.
Jan 03, 2008 | Jenn-Air JED8430 Electric Cooktop
Cooktops Logo
62 people viewed this question
Top General Electric Cooktops Experts
gbob59
ray gallant
Are you a General Electric Cooktop Expert? Answer questions, earn points and help others
