Question about KitchenAid Architect 25.3 Cu. Ft. Side-by-Side Refrigerator w/ Thru-the-Door Ice and Water - Satina Stainless-Look
White residue on the tray of the refrigerator water dispenser.
Is there a good product to remove the white residue that builds up on the tray of the water dispenser of my refrigerator?
  • 400 Answers
You need to install an inline water softener or Reverse osmosis unit. Your water has too much lime and so cleaning the dispenser would not make any difference as it will just happen again. Get the source of the problem sorted.
Posted on Mar 12, 2009
Clean the water tray of the white build up over time?
when tray is dry use isopropyl alcohol in a universal spray bottle, let it set for about 30 seconds and then wash off. Heavy caked areas may need a dish brush to dislodge, but should release the mineral build up.
Sep 18, 2014 | GE Refrigerators
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
Apr 01, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Rust ruining door at lower corners of ice/water dispenser.
when you dispense ice or water, you are allowing the drip tray to overfill and the water builds underneath the tray until the water reaches the point were it will leak down the front of the door. the water will rust the panel beyond repair. you will have to replace the whole door at this point. hope this helps.
Oct 20, 2009 | GE GSS22JEM Side by Side Refrigerator
White film/residue left on dishes
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. Dishwasher Magic is a good choice. works great.
Jun 18, 2009 | Kenmore Dishwashers
Water dispenser working but ice maker not working
is water is in side ice maker if not check hose at the back if water in icemaker call for service
Mar 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold Ice dispenser problem
i had same exact problem, i search over and over for solution. I even change the auger moter.
here is the solution for this particular problem.....
with the fridge door closed, remove bottom catch tray under ice dispenser revealing two screws, take off screws and slide front trim up to remove, you will have to unplug switch on trim to fully remove, look in top right corner there is black switch the will most likely be loose, this switch is your problem, mine was basically dislodged and the ice dispenser lever was not making contact, i simply zipped tied and siliconed the switch back to its respective place. if yours is making a good connection then the switch its self must be bad, you can test the switch by using the switch from water dispenser side...
i hope this helps
Jul 21, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dishwasher not cleaning well
clean the dispensor assy around the spring door hinge witha vinegar water solution . liquid detergent has a tendency to not fully break if your water is not hot enough, causes doors to stick, reccomend running hot water before starting d/w, and using a quailty powder( not tabs) detergent
Feb 20, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Dishwasher problems
Hi Bmissy,
I had the same problem with my dishwasher. In my washer the problem was caused by a buildup of water deposits throughout the machine. I increased the temperature of the water, used three bottles of "Dishwasher Magic" and now my machine is working well. I read that the rinse aid dispensers do not disperse enough of the product for extremely hard water, the solid rinse aid dispensers work better. I know that adding a little water softener to your washer when you run it can help. If you can't find "Dishwasher Magic", you might want to try running your dishwasher with a few quarts of white vinegar to remove the deposits on the coil. You may need to clean out the deposits in your washer regularly to keep the machine working well.
HTH!
Ann
Nov 02, 2007 | Dishwashers
KitchenAid Architect 25.3 Cu. Ft. Side-by-Side Refrigerator w/ Thru-the-Door Ice and Water - Satina Stainless-Look Logo
1,452 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
