Question about Garden
My trimmer will start for a few seconds running only from the primer blub but will not continue to run from the main gas line. I can see that it is not drawing gas from the main gas line.
I believe my son had put this unit away a couple of years ago with bad gas in it, I found it very gummed up and cleaned as much as possible with carb cleaner but I am not sure but the diaphragm may be damaged.
  • 3 Answers
Take the carb off then pull it apart and thoroughly clean every hole and part with carb cleaner, make shure you you clean the neddle valve and there is no biuld up on the floats. also mak sure there isn't any holes in the floats an in the diafram
Posted on Apr 21, 2013
2 Suggested Answers
  • 1702 Answers
SOURCE: My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Posted on Jun 13, 2011
Testimonial: "Thank you. I had to merely add more gas to tank & bulb siphoned fine. Changed the plug and bingo! It started & runs great. "
My 25cc craftsman weedwacker will not start it is not getting fuel prim bulb will not fill up lines are full of fuel when i pull them off new lines took csrb off and blue out with air. if i put fuel min...
Clean you needle/ seat inside carb pull apart and clean all out and try it off the w.w. to see if primer works ,also the primer has a check valve internally also make sure that is working, if the primer won;t pull gas through carb it won;t run 2StrokeJim
May 17, 2011 | Craftsman 25cc Gas Line Trimmer
My Ryobi start great but when I change it from start to run stays few seconds and died
  • Alow the engine to run for longer on the start setting before you switch to run
  • Ensure air filter is clean. Foam elements can be washed with hot water and detergent. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
  • Check fuel lines aren't kinked or blocked restricting fuel flow.
  • Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
  • The fuel lines may have become airlocked.This can happen if the tank is run dry. If the trimmer has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.Once the engine kicks, switch to run.
Apr 05, 2011 | Ryobi Gas Hedge Trimmer
Troybilt trimmer primer bulb collapses. it will start occasionally but will only run a few minutes.i have replaced the primer bulb and gas lines and still have the same problems.
it should have a small vent in the fule tank cap if its blocked the primer bulb will be sucked in as the fule pump can **** any fule from the tank
check the tank cap first,,,,,
Aug 08, 2010 | Troy Bilt Tb70ss Gas Trimmer
Craftsman weed trimmer primer bulb is working in reverse
Make sure the line is near the botto ofthe tank.Thanks you for asking and I hope it helps.Please leave me a 4 thumbs up.
Jul 19, 2010 | Craftsman 25cc Gas Line Trimmer
Edger will not stay running
Your diagfram is bad replace it in your carb and you will be ok
Apr 12, 2010 | Yard Machines Red Edger
Primer bubble is cracked.minimal fuel is getting to carburator. when it starts it will run a few seconds then cut off.Won't run except in full choke. Please Help
The primer bulb needs to be replaced. It is introducing air to the system and not allow fuel to flow. Replace it and check the fuel lines while you are at it.
HTH
Good Day
Oct 29, 2009 | Craftsman 25cc Gas Line Trimmer
Primer bulb won't re-fill.
Not sure about your particular set-up, but there is usually two fuel lines running from the fuel tank. One goes to the carb and the other goes on a fitting on back of the primer bulb. The primer bulb will have a second fitting with a line going to carb. Sounds like either a clogged or leaking fuel line to me. Hope this helps and good luck.
Jul 11, 2009 | Garden
Put in new carb kit, starts but dies after a few seconds
If you removed the fuel lines from the primer bulb you may have reversed the lines. On two stroke engines the primer pulls gas through the carb it does not push gas into the carb. On the back of the primer bulb there are two hose barbs, one says in (in very small letters) this side goes to the carburetor and the other goes to your gas tank (it is a return line) This line is about a third to a half way up the side of your gas tank, not at the bottom where the fuel line is.
Jul 04, 2009 | Craftsman Convertible 25cc. Gas Line...
Craftsman gas 25cc weedwacker starts, runs a few secs, then dies
The gas take up line is disconnected or is broken. I have the same problem and need to find a diagram to fux it.
May 17, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
