Question about Frigidaire GLTF2940FS 3.5 Cu. Ft. Front Load Washer - White
Frigidaire gallery series washer stuck on pause
Stuck on pause.......
IFIXALL
  • 868 Answers
SOURCE: machine stuck on pause/err
un plug the washer for 5 minutes and re try
Posted on Jun 03, 2008
  • 89 Answers
SOURCE: FWT445GES1 Washer makes loud banging noises like it's going to explode.
Washer- you need a complete tub and bearring kit. this is a common problem for people who have well water. (also just happens) the rear yoke has become corroded and broken. its a costly repair.
dryer - you would need a new front slider seal. very simple to install.
Posted on May 28, 2009
Krazytech
  • 725 Answers
SOURCE: the washer is stuck in pause mode. How do I get
Control Lock To avoid having someone accidentally start or stop the washer, press Options and Select at the same time and hold for 10 seconds until “LOC” is displayed alternately with the estimated cycle time. To unlock the controls, press Options and Select at the same time and hold 10 seconds until ”LOC” is no longer displayed.
Posted on Sep 19, 2009
SOURCE: I have a Frigidaire Gallery front load washer with E10 error code
When ours does that it is because of the hard water build up. We have to un-hook the hot water clean out the minerals and it stops doing it.
Posted on Dec 03, 2009
SOURCE: I have a Frigidaire gallery series front load
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Posted on Apr 10, 2010
How to fix gallery frigidaire code pau
Hey friend, thank you for the post!
I see from your post that your Frigidaire washer is displaying a PAU code. Normally means the washer has been paused, which could be cleared be pressing either the cancel button or start button once. If that does not clear the code you could try resetting the appliance by disconnecting power. This could be done one of two ways by either unplugging the washer or flipping the household circuit breaker for ten minutes. Please comment back I would like to know if this information has been helpful. -Matt
Jul 23, 2014 | Frigidaire Washing Machines
How to perform key stuck closed button test
To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink
Aug 14, 2012 | Frigidaire Electric Dryer
How to disable buzzer from frigidaire gallery series stackable washer/dryer?
Here is a site showing all of the steps to disable both buzzers on the Frigidaire Gallery series stackable washer/dryer.
http://www.scribd.com/doc/34420420/Buzzer-Disconnect-Frigid-a-Ire-Gallery
Nov 19, 2010 | Frigidaire GLEH1642DS Front Load Stacked...
Gallery washing machine door latch stuck in lock position
I have the same problem with my Gallery. I can not open it at all. I have tried unpluging it and putting it through another cycle to see if it will open. No such luck. Any suggestions?
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
The washer is stuck in pause mode. How do I get
Sep 18, 2009 | Frigidaire Affinity ATF7000E Front Load...
May 28, 2009 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Sep 25, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire gallery stack wash/dryer
Sounds like it could either be a bad solenoid in the fill valve or a bad pressure switch...both issues are easily repairable.
Jul 28, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Machine stuck on pause/err
May 28, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940FS 3.5 Cu. Ft. Front Load Washer - White Logo
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
