Question about Gateway Computers & Internet
Joe covette Want to go feom a 2.33 to a 283 processor. All specs on both chips are the ssame except parity and die size
  • Gateway Master
  • 5,660 Answers
I understand, and I appreciate your looking deep into both CPU's.
Are we talking about,
1) Intel Core2 Duo E6550, which has a maximum frequency rate, ('Speed'), of 2.33GigaHertz?
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors#.22Conroe.22_.2865_nm.2C_1333_MT.2Fs.29
4MegaByte of L2 Cache, 1333MegaHertz Front Side Bus?
(4MB L2 cache / 1333MHz FSB)
Based on the Conroe Core technology, and the 65nanometer architecture? 0.85Volts to 1.50Volts - voltage range?
2) Intel Core2 Quad Q9550, which has a maximum frequency rate of 2.83GHz?
http://en.wikipedia.org/wiki/List_of_intel_core_2_microprocessors#.22Yorkfield-6M.22_.2845_nm.29
2 times 3MB of L2 Cache, 1333MegaHertz FSB, Voltage range - 0.85 Volts to 1.3625 Volts?
Based on the Yorkfield-6M Core technology, and the 45NanoMeter architecture?
Don't know.
I just look at what motherboard chipset is used, then if it will support both a Dual Core, and a Quad Core; I look at the voltage range, and core technology/architecture.
http://www.fixya.com/support/p929676-gateway_gt5692_desktop_computer
So we are talking about a Gateway GT5692?
http://support.gateway.com/s/PC/R/1015553R/1015553Rnv.shtml
Components > Motherboards > 4006272R - Foxconn (Bengal) RS780 Motherboard > Specifications,
http://support.gateway.com/s/MOTHERBD/Shared/4006272R/4006272Rsp2.shtml
Ha! So we are NOT talking an Intel CPU! (Processor)
Apparently not discussing a Gateway GT5692 Desktop PC, either.
What desktop computer are we talking about Virgil, and what is the motherboard chipset?
Regards,
joecoolvette
Posted on Apr 24, 2013
Nmi error
Chip-set or memory error that relates to parity or ECC (error correcting) Try singling out your system memory and see if you still get this error.
Feb 05, 2014 | IBM Xseries x346, 1 x xeon 3.6 ghz/1 mb,...
Tip
10 reasons why PCs crash-You must know tip 2
2 Bad Ram
Ram (random-access memory) problems might bring on the blue screen of death with a message saying Fatal Exception Error. A fatal error indicates a serious hardware problem. Sometimes it may mean a part is damaged and will need replacing.
But a fatal error caused by Ram might be caused by a mismatch of chips. For example, mixing 70-nanosecond (70ns) Ram with 60ns Ram will usually force the computer to run all the Ram at the slower speed. This will often crash the machine if the Ram is overworked.
One way around this problem is to enter the BIOS settings and increase the wait state of the Ram. This can make it more stable. Another way to troubleshoot a suspected Ram problem is to rearrange the Ram chips on the motherboard, or take some of them out. Then try to repeat the circumstances that caused the crash. When handling Ram try not to touch the gold connections, as they can be easily damaged.
Parity error messages also refer to Ram. Modern Ram chips are either parity (ECC) or non parity (non-ECC). It is best not to mix the two types, as this can be a cause of trouble.
EMM386 error messages refer to memory problems but may not be connected to bad Ram. This may be due to free memory problems often linked to old Dos-based programmes.
on Mar 04, 2010 | Computers & Internet
Cmos beep codes
do you know which bios your computer is running ?
AMI BIOS beep codes 1 beep - DRAM refresh failure
2 beeps - Parity Circuit Failure
3 beeps - Base 64K RAM failure
4 beeps - System Timer Failure
5 beeps - Processor Failure
6 beeps - Keyboard Controller / Gate A20 Failure
7 beeps - Virtual Mode Exception Error
8 beeps - Display Memory Read/Write Failure
9 beeps - ROM BIOS Checksum Failure
10 beeps - CMOS Shutdown Register Read/Write Error
Phoenix BIOS BEEP codes. 1-1-3 CMOS write/read failure.
1-1-4 BIOS ROM checksum error.
1-2-1 System timer failure. (Programmable Interval Timer PIT)
1-2-2 DMA (direct Memory Access) failure.
1-2-3 DMA page register failure.
1-3-1 RAM refresh failure.
1-3-3 64K RAM chip or data line failure.
1-3-4 64K RAM odd/even logic failure.
1-4-1 64K RAM address line failure.
1-4-2 64K RAM parity error.
2-?-? Any beep series starting with 2 beeps indicates a 64K RAM chip or data line error.
3-1-1 Master DMA register test.
3-1-2 Mslave DMA register failure.
3-1-3 Master interrupt mask register failure.
3-1-4 Slave interrupt mask register failure.
3-2-4 Keyboard controller failure.
3-3-4 Screen (video) memory failure.
3-4-1 Screen initialization failure.
3-4-2 Screen retrace failure.
4-2-1 Timer tick interrupt test failure.
4-2-2 Shutdown test failure.
4-2-4 Unexpected interrupt in protected mode.
4-3-1 RAM test failure above address 0FFFFh (64K +)
4-3-3 Interval timer channel 2 test failure.
4-3-4 Time of day clock failure.
4-4-1 Serial port test failure.
4-4-2 Parallel port test failure.
4-4-3 Math Co-processor failure.
BEEP codes may vary dependent upon the revision of BIOS. This list is for reference only
hope this helps
Oct 10, 2012 | Intel Mother Board S5520HCR (988889365963)...
Is there a cpu upgrade for an hp pavilion 6835 with a motherboard 115561 cognac 20000731
The fastest Pentium 3 that will work in your board is a Intel Pentium III 1GHz chip. Here is a link to the specs:
http://www.cpu-world.com/CPUs/Pentium-III/Intel-Pentium%20III%201000%20-%20RB80526PY001256%20%28BX80526F1000256%29.html
You could also get a Intel Celeron 1.1 GHz but it only has half the level 2 cache size so it's actually a bit slower than the Pentium III 1GHz chip.
Here's a link to celeron specs:
http://www.cpu-world.com/CPUs/Celeron/Intel-Celeron%201100%20-%20RB80526RY005128%20%28BX80526F1100128%29.html
May 23, 2012 | Powerleap PL-NEO/T Celeron, 1.4 GHz...
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at: http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
I would like to upgrade my cpu. Can I put a larger cpu? I have a compaq EVO D510 with a 1.8 processor.
You can upgrade the speed of the CPU. Of course in order to do that you must know the motherboard capabilities. If the motherboard is upgradable to 2.0ghz processor with the same specs with your 1.8ghz processor then you can upgrade. If the motherboard is un-upgradable, my suggestion is to replace the motherboard, get a new processor, memory module, etc. Meaning you just bought a new computer. For the mean time, upgrade your memory module. Un-install the software that you don't need. Especially the one the eats up the processor speed.
Jul 12, 2010 | Compaq Evo D510 Minitower (Open Box)...
I replaced my pentium 4 2.53 processor applied processor compound , then my heatsync fan. Now an alrm sounds while booting up and it stops booting. what are the possible issues. I upgraded my power supply...
Start by taking out the new power supply and putting in the old one and rebooting the system. Recheck the specs on that processor and make sure they have the same Die number on them. Just because they say P4 does not mean they will work in all systems. There is a die number printed on the smooth face of the chip near the bottom. Hopefully, it is just the power supply the computer is having the issue with. Always work backwards when there is a problem and take off new stuff first before changing settings. Good luck
Oct 16, 2009 | Computers & Internet
Fujitsu Siemens Amilo A1650G Hello.Can i use a processor sempron mobil from a labtop in a motherboard with the same socket? If yes ,,,what about the cooling ?can i use a normal processor cooling for socket...
go to the manufactures website and check voltage and specs. You can buy cooling fans for the processors. Just because the socket size is the same, does not mean the chip will work. Variations in voltage and buss speed can affect or damage processors.
Mar 20, 2009 | Computers & Internet
Continuous beeping sound
Do you get video? If so then it could be a stuck key on the keyboard.
Do you get no video? If so then reseat the RAM.
Feb 10, 2009 | Sony VAIO PCV-RX370DS PC Desktop
Processor and Disk space
The biggest processor available for the T20 is 1ghz. Be sure when replacing the processor that you get an IBM 133mhz processor. The memory is 1g max, the machine will hold two 512mb chips, and be sure that it's PC133 memory. You can put up to a 120g hard drive in the machine, be sure the hard drive is an IDE 4200rpm drive. These are the specs for the T20, and the maximum size this machine will hold. You can go to this max or anyplace in between.
Aug 27, 2008 | IBM ThinkPad T20 2647 Notebook
Computers & Internet Logo
139 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
