Question about D-Link 802.11g Wireless Router WBR-1310 (WBR1310)
Can't network a laptop with a PC server
Do new laptops need a wireless card
    An expert who has written 3 tips or uploaded 2 video tips.
  • 80 Answers
Not really, you can just make a "crossover cable" and connect it to PC Server Ethernet Controller, or just use concentrator as switch/hub. If you've choose to use Wireless Access Point/Router as concentrator, you will need Wireless Card (usually it already built in in some new laptop) for sure...
P.S.: If this information was helpful, please rate this solution.
Posted on Mar 12, 2009
Wireless connection with a wireless router (Netgear WNDR 4000) a pc and a laptop.
I assume you connect your printer to the desktop with the USB cable.
I assume the laptop is connected to the Wifi network.
First you need to setup the printer to connect to the wireless network. Follow the printer installation instructions to do that.
Next insert the install Disc into the laptop and follow the installation instructions. Use the network installation section.
The printer has a built-in server for printing.
If UPNP is enabled on the router then you should be able to browse the printer on the network.
Sep 30, 2017 | NetGear WGPS606 (WGPS606NAR) Print Server
How to Share your Internet Connection through laptop's WLAN(Wifi) card?
Every Windows Operating System after Windows 98 can share its Internet Connection using this Technique. Microsoft defines this technique as Internet Connection Sharing (ICS). But setting ICS is very obscure to most of the users. This comes very useful if you live with your roommates and you guys have single internet source like a USB modem Connected to one laptop only. Using Internet Connection Sharing(ICS) that laptop can Broadcast its Internet to other laptops in the room. Technically, the range of a laptop's WLAN adapter is around 20-25 meters. So it can easily handle near by rooms also. This can also be done with a PC having a WLAN card.
To setup and broadcast your internet it is mandatory that you are accessing internet using anything other than Your WLAN card like a USB modem, Ethernet etc. This is because your Wireless adapter(WLAN) will be used for Broadcasting your Internet connection to your friends.
Server laptop:- Laptop with Internet Connection.Client Laptop:- Laptops accessing the internet of server laptop.
Follow the steps to share your internet it goes:--0b73509.gif
  1. Open the "Control Panel" of the laptop that is accessing Internet and go to "Network and Internet" then "Network and Sharing Center".
  2. On the right side of the "Network and Sharing Center" click the "Change Adapter Settings" and you will see all the available network adapters in your laptop.
  3. Now Right-Click the adapter through which you access internet and click "Properties" option. The properties window will open.
  4. In "properies" Window click the "sharing" tab check "Allow other network user to connect through this computer's Internet connection"97ac799.jpg
  5. In the sharing tab, Select "Home networking connection" type as "Wireless Network Connection" click "OK" and select "Yes" to the Confirmation warning. see above image.
  6. Now Right-Click the "Wireless Network Connection" in "Change Adapter Settings"and Open Its Properties.
  7. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and select the "Use following IP address"
  8. Enter the IP address as "" and "Subnet mask" as ""
  9. Leave all other fields blank in Server laptop, which has access to internet.0219162.jpg
  10. Now setup a wireless "ad hoc" computer to computer connection using "setup a new connection or network" in "network and sharing center" and Name it as anything like "Internet_sharing".c2debe7.jpg3a69972.jpg
  11. Now bring other laptops that will use the Shared Internet connection.
  12. Open "Change adapter Setting" (Described in step 2).
  13. In "Change adapter settings" Right-click "wireless Network Adapter" and Click its properties.
  14. In "Wireless Network Connection Properties" Double-click the "Internet Protocol Version 4(TCP/IPv4)" and enter following IP address:-
  15. IP address-"", Subnet mask "", Default gateway-"" and Preferred DNS server: "".
  16. Use the same step from 11 to 15 to connect other laptops and Increase the IP address by +1. Ex-, & so on. Rest of the settings like Default gateway etc will be same on all laptops. Only the server laptop will have blank entries in these settings.
  17. Now connect all the laptop with the Wireless network(ad-hoc) named "Internet-sharing" that you had previously broadcasted in step 10 in server laptop.
  18. Now in the server laptop, disconnect and then reconnect the internet connection(This is a necessary step for Internet Connection sharing(ICS) to work).
  19. Now access internet in all laptops...ENjoy.
Note:- For Advance Users.. this information is necessary only--The IP address of server laptop work as the "Default gateway" and Preferred DNS server of Client laptop and on server laptop these fields are blank. Use same series of IP address as used in the server.
please vote if you found this helpful.. --Abhishek
on Sep 30, 2010 | Computers & Internet
Wifi server
Once you have setup the central sever you can right click either the harddrive(s) or individual folders and there should be an option to share (or sharing and security). Open that and it should be quite straightforward to setup permissions so all computers can access those network places.
Next on the server right click My Computer and click properties. Write down what the workgroup name is.
Now go to the Vista laptops and goto Control Panel, then network places, or view wireless devices on network. Hopefully your shares will appear on the laptops and you can access them.
If they appear and you canot access them then you probably need to go back to step one and alter the permissions for sharing on the XP server.
Hope this helps,
Apr 09, 2010 | Acer Aspire 5050 Notebook
EPC smart book cannot conect to internet
make sure that your wireless network card is turned on. reinstall your wireless network card driver. if nothing happened, consult your manufacturer. possible defective wireless network card. you can also test your router by using other computer if that computer can connect to your wireless router. if yes, then the problem is your computer. if not, then problem is your router. hope this helps.
Apr 01, 2010 | Computers & Internet
D-link range booster installed on main PC, still
Check your wiring:
Cable-modem (or DSL-modem) <---> WAN-port on Router
LAN-port on router <--> network-port on your desktop computer
Follow the instructions that came with the router,
to access the built-in web-server "inside" the router.
Run the "Wireless Networking Setup Wizard" to configure your wireless network.
Now, try to access your newly-defined network from your laptop.
Jan 08, 2010 | Acer Aspire 5500 5570-2609 Laptop
Windows 7 and Linksys wireless print server
Step for installing Network print server in windows 7.
Click Windows "Start button"
Select "Devices and Printers"
Click "Add a Printer" button
Select "Add a Network, Wireless or Bluetooth Printer"
Printer wizard will searhc for all network printer including wireless.
Select "The printer that i want is not listed"
Select "Select a shared printer by name"   (Make sure you have shared the printer you want to connect)
Type the IP address of the printer if it ia a printer.
If it is printer that is connected to a PC then type like this below
\ shared name where is the IP address of the PC where the printer is connected.
Click Next and if you want to Send a test print you can try that too,otherwise click "Finish".
That's it.
Jan 02, 2010 | Dell Inspiron 1545 Notebook
Wireless card in my laptop can see the modem!but cann't connect?
Make sure you have IP Address,Subnet Address,Default Gateway Address assigned either manually or by DHCP server.And refresh your wireless Network connection.It will connect.
Dec 28, 2009 | HP Pavilion dv6000z Notebook
Need my laptop to communicate wireless to printer
If the printer does not have a built-in network card/print server then there is a couple of ways to do this.
If you have a desktop computer connected to the wireless router with a LAN cable, then connect the printer to the desktop computer and make this printer a shared printer on your network. This means that the desktop computer and printer needs to be on when you want to print from the laptop.
The other way is to purchase a print server, connect the printer to the print server and connect the print server with a LAN cable to the Wireless router.
If you don't have sufficient network ports on the wireless router then you need to purchase a hub. Then connect the hub and wireless router with a LAN cable and then the print server to the hub and other computers to the hub.
Setting up the wireless printing will depend upon which method you want to adopt and I can advise you when further when you are ready.
Aug 02, 2009 | HP Photosmart 3310 Printer
I re-installed XP T43 laptop and my wireless does not work
First thing is to check if the wireless device is working. Go to Control Panel - System - Hardware - Device Manager. Click on Network Adapters. Do you see the the Wireless card?
If not in Control Panel click on Network Connections, do you see a Wireless Connection? If not you need to install the correct wireless network driver, Check the IBM site again, there should be another wireless driver (there are a couple of different wireless card installed on T40 series ThinkPads).
If you succeed in installing the wireless driver and it is enabled.
Then click Control Panel - click on Network Connections - right click on the Wireless Networl Connection - Click on Properties and check if TCP/IP has been installed, if not install it. Check TCP/IP properties - make sure it is set to Obtain an address automatically and Obtain DNS Server address automatically.
Check the wireless settings on your other laptops, use this information to configure the wireless on the T43, ie the SSID, WEP or WAP settings
You should be able to connect to your wireless router and Internet now - let me know how it goes,
Mar 13, 2009 | Lenovo ThinkPad T43 Notebook PC
Card is green, wireless router is green , but no internet
r u c'in any message as limited r no connectivity in wireless connection,did u chk if u r able to go online wth the cable connection in ur laptop
Nov 05, 2008 | Dynex 802.11g Wireless-G Laptop Card
D-Link 802.11g Wireless Router WBR-1310 (WBR1310) Logo
42 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
