Question about Dishwashers
This i found in the bottom of my Maytag dishwasher but can't seem to figure out where it goes. Any input
Put your self in front of the pc and psuh it very hard ,when it falls down and crash then repit fifya fixya fixya and thats it
Posted on Apr 21, 2013
  • niceeyes Apr 21, 2013
    put your self in front of the pc and psuh it very hard ,when it falls down and crash then repit fifya fixya fixya and thats it
The spring holding the door came off. Where does it go? Is there a picture to help see?
If you take the bottom panel off there are two springs, if one is still in place you can see where the other one goes. Hope you found this helpful.
Jun 18, 2011 | Maytag MDB6000 Dishwasher
I have a Maytag MDB4709AWS dishwasher that's not doing a good job cleaning dishes. Even on heavy duty cycle I still have small particles stuck inside my cups and on top also. I wanted to remove the inside...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
Dishwasher Residue and Film on Dishes
heatman101
Dec 09, 2010 | Maytag MDB7100AWB Dishwasher
The spring popped off my mayday dishwasher door. I can't figure out where it goes to put it back.
look at the other spring ..their is 2 springs ..they hook to the bottom rail of the D/W let me know an good luck P/S remove the bottom cover plate to see the springs they are located on the left and right side /joe/
Aug 29, 2010 | Maytag Dishwashers
Maytag eq plus, not cleaning properly, seems the
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
heatman101
h
Feb 28, 2010 | Maytag MDB7100AWB Dishwasher
Maytag Quiet Series 300 only goes to RINSE ONLY
Try unplugging the washer to reboot the computer board. Sometime power surges at night can cause undervoltage on the board and make it do funny things. Rebooting by removing power for 10 min will drain the board and start with a fresh program. This is true for microwaves, dishwashers, dryers, etc.....
May 08, 2009 | Maytag 24 in. MDB5600A Jetclean II...
Loud noise maytag dishwasher quiet series 100
Hi All,
I have had a Maytag Quite Series 300 for some years now and have done basttle with it on may occasions. I now consider myself somewhat of a veteran, although by no means a repair expert!
Grinding Noise: From either a clogged/blocked impeller or not enough water getting to the impeller.
For a clogged impeller, it is fairly easy to disassemble the washer to get at the impeller to remove any debris or blockages.
For not enough water it can be a number of things. First of all, you will notice that the noise lessens if you add a jug or two of extra water. This is because if the water level is too low, the pump impeller will get some air mixed with the water & this is LOUD! Now for the causes:
Float – If the float gets stuck in the wrong position (debris or water deposits), it will not fill enough.
Float Set Wrong – Seems thats some of these dishwashers have the float set a little too low to let the dishwasher perform without grinding. A few pennies attached to the float with a rubber band seems to help here. Don't go too far or you'll flood your kitchen!
Timer – Some folks have mentioned that dishwashers that fill on a timer will not fill enough in the allotted time, if the water pressure is low. While this is true, I have looked over the electrical & parts diagrams for the QS300 and I do not see a timer listed anywhere. Also, the wiring diagram appears to show that this dishwasher only uses the float to achieve the correct water volume. I could be mistaken here.
Note that in VERY hard water areas (like mine – TDS of 850 hardness or 49 Grains), the plastic fins on the cover of the impeller get very choked up with water salts and this can impede flow, leading to a low-water symptom, when in fact, there is plenty of water.
Dishes Not Cleaning:
Poor Water Flow – See above, all the above items will negatively impact dish cleaning.
Poor Q uality Detergent – After trying them all – Yes, all – Do not use cheap detergent. Buy the brand names: Cascade or Electrasol work well. I have found that by far, the little packs work the best. We found that the liquid works second best and the dry stuff really isn't up to the task at all, no matter which brand.
Spray Wands Catching – We found that our lower spray wand was catching on the bottom of lower dish tray, so I very slightly bent down the legs that the wheels mount to in order to lift the dish tray/basket a little and give the wand a little more room. This worked well.
Spray Wand Nut Too Tight – The factory seems to send the dishwasher out with the nut on the bottom spray wand tightened a little too far. Loosening this a little bit lets the bottom wand rotate much more easily.
Top Spray Wand Not Meeting Receptacle – The top spray wand is attached to a pipe that mates with a port (well, one of two ports, depending on if you have the top rack in the “Upper or “Lower” position). The pipe seems to have a tendency of missing the port. A well placed elastic band will help here. Note that on our dishwasher, by the time the first elastic band wore out, the pipe had been permanently moved to the correct position by the gentle pressure.
Tines/Dish Holders On Top Rack Falling Over – The tines (metal spikes) that hold dishes on the top rack fold down by design. Issue here is that they do it sometimes during the wash, causing the dishes to fall over and block the spray. A few well placed rubber bands help here as well.
Water Salt Buildup – If you live in a very hard water area, you can still get clean dishes from yor dishwasher. We do and we have VERY hard water. Buy a gallon of vinegar once a month. Pour this into a clean dishwasher. Turn it on so that it runs for 2 minutes to circulate the vinegar. Open the door & let stand over night. Close door & finish cycle. This will cut down significantly on the hard water salt buildup in the washer.
It's A Maytag – Sorry folks, it's true. I have learned (after purchasing the dishwasher) that Maytag has run into financial difficulty in recent years and has reduced build quality to save money. If you got suckered into buying one of these, you will very likely never buy one again. My opinion is “Do not by Maytag.”
Hope this helps someone!
Dec 31, 2008 | Maytag 24 in. MDB9750AW Dishwasher
Dishwasher
I found a plastic cone shapped part in the bottom and can not figure out where it goes. thanks
Oct 08, 2007 | Kenmore 15529 Built-in Dishwasher
Maytag MDBH950AWB
You need to remove the lower spray arm (the little plastic nut in the middle of the arm can be removed with a 3/8" nut driver), then the dome housing, then the impeller, then the entire cover. This gets you down to the motor where the chopper blade is at. There's probably something hard that's getting in the blade. If you don't find anything, you'll need to replace the motor and the seal kit, which includes the blade and the seal that does not come with the motor.
Mar 12, 2007 | Maytag 24 in. MDBH950AWS Built-in...
Dishwasher
I had this same problem. I think its the upper spray arm vibrating during wash cycle. To verify; prevent the upper arm from rotating by putting a long spatula through the top rack or zip tie the arm so it don't rotate. If the noise goes away you found your problem.
Feb 15, 2007 | Maytag 24 in. MDBH940AWS Built-in...
Dishwashers Logo
275 people viewed this question
Top Dishwashers Experts
