Question about Nintendo Wii Console
Wii makes a horrible noise while loading or ejecting the disc
Well, lets be honest, we all know that the older Wii's eventually start making a buzzing noise... this buzzing noise isn't my worry. I've fixed that. (Let me tell you, bending those little triangles or stuffing something in between them over the disc? stupid friggin idea!! for the most part)
While finding a permanent fix for the buzzing, I created another problem.
My Wii runs as silent as it did new out of the box, if not even more silent than it was before, as the disc spinning at speed makes no noise.
Loading or Ejecting the disc, or turning the Wii off, however, is a WHOLE other story.
I must have bumped something or tweaked something wrongly, but while the disc is spinning up to speed (powering on, using the wii channel, etc), or coming down from speed (eject or off, or going into a non-disc using channel) it makes what I can only explain as an off pitch grinding. I'm thinking perhaps the braking or stabilizing mechanism is a bit "off" ... because I can also not play my Wii vertically at the time being, it seems the disc isn't firmly seated in vertical mode (also because when I turn it vertically, it decides to stop spinning, with said funny noise)
any ideas?
  • demon610 Mar 14, 2009
    how do you go about fixing that?
    I will certainly leave feedback if you can give a general idea how to unstick the magnet
    Scholar:
  • 80 Answers
Hello my name is Tim Ehrhart, I repair 360's and have had this problem with them and there problem is that the magnet that holds the disk in place gets stuck and makes a grinding noise that sounds horrid. Please leave feedback as I am new and trying to build a great rep. Thank You.
Posted on Mar 14, 2009
When disc playing makes really loud buzzing or grinding sound.
My friend too faced same kind of problem ............
with his nintendo wii console it doesn't get start at all.....
If you are also facing exactly same problem
then dont worry
Go to this site and fix your problem by downloading repair guide
Click Here to get guide
Dec 03, 2010 | Nintendo Wii Console
HEAT PUMP
It is not normal to have a loud buzz associated with the electric heat. Try turning the heat off and running the fan only to see if the buzz continues. The buzz could be coming from any number of sources including an electrical component, the blower wheel, a loose fastener...etc.
The temporary smoke and smell could have been the dust burning off the element if the elements have not been used in a long time. However, if the elements have been running, it could be something got loose in your system and stuck between the blower and the heating elements.....for example, the wiring diagram could have come loose and worked it's way through the wheel. I've also seen owner's manuals left in the air handler that eventually got stuck in the blower. This should be inspected to ensure there is not a fire hazard.
I hope this helps and good luck. :-)
Feb 24, 2010 | Friedrich Heating & Cooling
My wii is making a loud buzzing sound, what do I do?
My friends Wii does the same. As long as the Wii isn't lagging, glitching, or randomly shutting off while in use, everything is alright. Also, make sure your Wii is able to read disks properly, because that is the main cause that leads to the buzzing noise. If the noise is to annoying to stand, call Nintendo, and ask for a repair to be done, I'm sure they will fix it up. Hope this helps!
Dec 06, 2009 | Nintendo Wii Console
Game always freezes and makes loud buzzing noise
i havent had this problem with mine but you can call this number and they may help you
18002553700 try it
May 24, 2009 | Nintendo Madden NFL 09 for Wii
Wii makes a buzzing sound when discs are running
The noise is the wii working extra hard to read the disk the lens might be dirty. Your wii might also have a bomb in it.............Just kidding. I would try cleaning the inside and if all is bad send it in to get fixed
Apr 10, 2009 | Nintendo Wii Console
Older model bottom freezer PBF2253HEW: buzzing starting/stopping
You'll have to listen to the noise to see if it is coming from the compressor but it sounds as if the start relay on the compressor is going bad, you can use a 3in1 start kit to fix this contact us at www.airenergyexperts.net
Mar 14, 2009 | Refrigerators
My quickie motorized wheelchair is making a loud buzzing sound when turned on, but I can still move around, Checked for moisture, dried with hair dryer. Is it the horn Can I disconnect? How? What else can...
Honestly I don't know if I can solve this problem, but, when do you get the buzzing sound, when your in motion? (in other words moving) what brand do you have? It shouldn't be making the noise unless you have the QLogic Controller that can make beeps when you move to a fuction... Let me know more...
Feb 21, 2009 | Quickie Wheelchairs Health & Beauty
Wii makes squeaking/chirping noise
This is a hardware failure. Sending it Nintendo is the only option. Unless you think you have the skills to repair it yourself. Here is the link to Nintendo
http://www.nintendo.com/consumer/repair/repair_options.jsp
If you want to repair it yourself you need a wii dvd drive. Any version works.
Dec 07, 2008 | Nintendo Wii Console
My Wii makes an annoying buzzing sound
I think thats normal. If your really annoyed about it, Play some music that cancels out the noise. I'm sure the in-game music your playing should go over the buzzing noise.
Jun 28, 2008 | Nintendo Wii Console
Wii fit
I know this might sound obvious but have you got it inserted in the console the right way up?
May 17, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
726 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
