Server system hanging
We are using asp.net application through IIS in multiple systems, When I send the request from client system, server system is hanging. Plz resolve this problem asap.
My n97 is being hanged at any position
Posted on Apr 22, 2012
System hanging when i connect server system
Posted on Mar 20, 2009
Netflix error 405
http://forums.mozillazine.org/viewtopic.php?f=38&t=605984&p=3155060
http://www.checkupdown.com/status/E405.html
SYMPTOMS
When you browse the default document, you receive one of the following error messages: HTTP Error
405 Method Not Allowed
The method specified in the Request Line is not allowed for the resource identified by the request. Please ensure that you have the proper MIME type set up for the resource you are requesting.
Please contact the server's administrator if this problem persists.
HTTP 405 - Resource not allowed
Internet Information Services
This problem occurs if the following conditions are true:
  • You do not specify the file name. For example, you do not specify http://Server/Web/.
  • The Scripting Object Model (SOM) is enabled.
  • A DTC event is called.
CAUSE
This problem occurs only when you use Microsoft Internet Information Services (IIS) 4.0 and Microsoft Internet Information Services 5.0. This problem occurs if you send a POST request to a server that is running IIS 4.0 or IIS 5.0, and the POST request contains a URL that ends in a slash mark (/). IIS returns the 405 error message instead of the default document. However, if the method value of the Verb property is GET or HEAD, IIS returns the default document. RESOLUTION
When the SOM is enabled and a DTC event is called
When the SOM is enabled for the page, a <FORM> tag that is similar to the following is inserted in the page. <FORM name=thisForm METHOD=post>
Because no ACTION attribute is specified in the tag, both Netscape Navigator and Internet Explorer try to make an HTTP POST request to the URI "web/". According to the HTTP RFC (RFC 2068), this is not a valid Request-URI for a POST operation.
To work around this problem, use one of the following methods:
  • Redirect from the default document to a different document. In this case, the SOM-enabled document will no longer be the default document. The new default document will just redirect to the SOM-enabled document. For example, if your SOM-enabled document is named MyDefault.asp, the default document (Default.asp) will contain only the following code. <% Response.Redirect "mydefault.asp" %>
  • Use client-side script to make sure that the file name is included in the URL. If you must use your SOM-enabled document as the default document, use a client-side code block that is similar to the following code block as the first code block within the <HEAD> section of the page. This code block does the following location replacement. Language=JavaScript> var loc = document.location.toString() var loclen = loc.length //The name of the default document var filename = "default.asp" var filelen = filename.length loc = loc.substring(loclen - filelen, loclen) if (loc.toUpperCase() != filename.toUpperCase()) { location.replace(filename) }
When the remote scripting is called
This problem may occur if you use the window.location.href property in an HTML document to determine the path of the current document. If you do this when you initiate a remote scripting call, the remote scripting call fails because the client page does not have a file name.
To determine whether the page can use remote scripting on the client, verify that the value of the window.location.href property does not end in a slash mark. To provide a file name in the client browser, and to prevent the error on the server, use the Response.Redirect method redirect the request from the default page to another page. For more information, see the first resolution method in the "When the SOM is enabled and a DTC event is called" section. STATUS
Microsoft has confirmed that this is a bug in the Microsoft products that are listed in the "Applies to" section.
This bug was corrected in Microsoft Internet Information Services 6.0. Properties Article ID: 216493 - Last Review: 11/21/2006 13:13:42 - Revision: 3.2
Applies to
  • Microsoft Internet Information Services 5.0
  • Microsoft Internet Information Server 4.0
Keywords:
  • kbbug kbctrl KB216493
Apr 20, 2014 | Netflix Computers & Internet
Automatic update
are you using windows...
some of the windows updates are trojans....that must be you are seein this problem
Apr 09, 2008 | Microsoft Windows Xp Home Edition English...
What proxy server can i use on facebook with chat?
There are a lot of proxy sites available to bypass your firewall restriction.
Here are few:
http://ads-blackfriday.com/
https://www.rbypass.info/
http://bypassfacebook.us/
just type www.facebook.com on the address field and hit Go.
Please tell me how this goes. Thank you for using FixYa.
Dec 06, 2010 | Facebook Social Network
What is proxy
Hi liverpool97.
Let me explain you about the Proxy servers.
In Computer Networks, a Proxy Server is a Server (a Computer system or an application program) that acts as an intermediary for requests from clients seeking resources from other servers.
A client connects to the proxy server, requesting some service, such as a file, connection, web page, or other resource, available from a different server.
The proxy server evaluates the request according to its filtering rules.
For example, it may filter traffic by IP address or protocol. If the request is validated by the filter, the proxy provides the resource by connecting to the relevant server and requesting the service on behalf of the client.
A proxy server may optionally alter the client's request or the server's response, and sometimes it may serve the request without contacting the specified server.
In this case, it 'caches' responses from the remote server, and returns subsequent requests for the same content directly.
Hope this helps.
Please let me know if you need further information about the Proxy servers.
I'll be glad to assist you.
Sep 21, 2010 | Computers & Internet
Donwload multiple files from server to client using asp.net
Sir,
//To Get the physical Path of the file(me2.doc)
string filepath = Server.MapPath("me2.doc");
// Create New instance of FileInfo class to get the properties of the file being downloaded
FileInfo myfile = new FileInfo(filepath);
// Checking if file exists
if (myfile.Exists)
// Clear the content of the response
Response.ClearContent();
// Add the file name and attachment, which will force the open/cancel/save dialog box to show, to the header
Response.AddHeader("Content-Disposition", "attachment; filename=" + myfile.Name);
// Add the file size into the response header
Response.AddHeader("Content-Length", myfile.Length.ToString());
// Set the ContentType
Response.ContentType = ReturnExtension(myfile.Extension.ToLower());
// Write the file into the response (TransmitFile is for ASP.NET 2.0. In ASP.NET 1.1 you have to use WriteFile instead)
Response.TransmitFile(myfile.FullName);
// End the response
Response.End();
private string ReturnExtension(string fileExtension)
switch (fileExtension)
case ".htm":
case ".html":
case ".log":
return "text/HTML";
case ".txt":
return "text/plain";
case ".doc":
return "application/ms-word";
case ".tiff":
case ".tif":
return "image/tiff";
case ".asf":
return "video/x-ms-asf";
case ".avi":
return "video/avi";
case ".zip":
return "application/zip";
case ".xls":
case ".csv":
return "application/vnd.ms-excel";
case ".gif":
return "image/gif";
case ".jpg":
case "jpeg":
return "image/jpeg";
case ".bmp":
return "image/bmp";
case ".wav":
return "audio/wav";
case ".mp3":
return "audio/mpeg3";
case ".mpg":
case "mpeg":
return "video/mpeg";
case ".rtf":
return "application/rtf";
case ".asp":
return "text/asp";
case ".pdf":
return "application/pdf";
case ".fdf":
return "application/vnd.fdf";
case ".ppt":
return "application/mspowerpoint";
case ".dwg":
return "image/vnd.dwg";
case ".msg":
return "application/msoutlook";
case ".xml":
case ".sdxl":
return "application/xml";
case ".xdp":
return "application/vnd.adobe.xdp+xml";
default:
return "application/octet-stream";
Thanks
Good Luck
Aug 17, 2009 | Microsoft Designing ASP.NET Applications...
Parser error
the Bin folder was not on the installation cd given by a provider
allow also webdav on IIS
Mar 19, 2009 | Polyvision RoomWizard Room Scheduling...
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
How to configure FTP server in windows xp prof ?
Setting up an FTP site Using Windows XP Professional Windows XP professional (as well as Windows 2000) includes Microsoft's IIS (Internet Information Server) which can be used to create an FTP site on your computer. It's a fair bit less complicated and less flexible than using some third-party FTP server software packages, so we will give you guides for setting up both. If you are using XP Home you will need to use third-party software. There is no way to publish an FTP site with the Home Edition of XP.
The first step is to check that IIS (Internet Information Services, Microsoft's web-server application) is configured properly.
Go to start\'control panel'\'add/remove programs'\ choose the 'add/remove windows components' button from the bar on the left. Highlight the item 'Internet information services (IIS)' If it is unchecked, check it, then click 'details.'
The components you will need are: 'common files,' 'file transfer protocol (FTP) service' and 'internet information services snap-in.' Uncheck any others then click next. IIS will configure itself, and you may be prompted for the XP CD.
Mar 21, 2008 | Microsoft Windows XP Professional x64...
Asp
Hi, Have you checked your security permissions on the 2003 IIS ?
Are the users using it as Intranet or Internet?
Is the site internal/external or possibly firewalled with rules restricting correct port operation and access permissions?
x-b-m
Feb 19, 2008 | Microsoft Windows Server Standard 2003 for...
Windows NT server using RDP client
To resolve this issue download the MobilePro Service Pack 1 and install it on your system: ftp://ftp.necsam.com/pub/Catalog/3959/MobileProSP1.asp
Sep 14, 2005 | NEC MobilePro 780 Pocket PC
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
