Question about Coby Kyros MID7022
Part of screen doesn't work
I have a Coby Kyros MID7022 tablet. I have dropped it many times and now the screen is cracked and the screen doesn't respond to my touch on one side. This was okay, except i couldn't type right. at first i would just turn the tablet so the words are on the other side. then one day it slipped out of my hand. i tried to put my pass code in, but part of the screen didn't work. i tried to turn it to put in the pass code, but it doesn't turn when its locked up. is there someone who can fix this, or could i buy a keyboard for it and put my pass code in like that. also, is there a way to reset the pass code so i can get into my tablet?
  • Coby Expert
  • 133 Answers
Turn the tablet all the way off, press and hold the VOL - and power at the same time for 8 to 9 seconds, it will show a green android guy with a system recovery menu. Use vol - to go down to Wipe Data/Factory Reset, press the power button to select it, go down to 'yes' to confirm, press the power button to select it, it will wipe the tablet, you then press the power button on 'reboot system'.
Posted on Jul 03, 2013
  • 76 Answers
SOURCE: my apps libaray on my
Sounds like you need to reset AppsLib.
This fix will wipe all your data, so be sure to back everything up.
Go to Settings.
In settings go to Go to "Privacy".
Select Factory Reset.
Select Reset Device.
Connect the unit to the computer using the USB cable and "Select" Erase Everything" The following will occur: • The screen will display COBY • The screen will display Android • The unit will reboot to the Menu screen
Step 6- The unit will prompt to calibrate. Hold stylus on the center of the target. Repeat as the target moves around on the screen. ****DO NOT *** press Return or Home". The unit will display "calibrate success" and will return to the main /home menu automatically. If for any reason the unit went into standby mode and the touch screen does not respond, reset the unit using a pin.
After the Factory Data Reset, do not launch the Applibs yet until: 1- You have configured your Wi-Fi 2- Check/enable "Unknown Sources"- Go to Settings, Application Setting. Done.
You can now open appslib.
Posted on Feb 28, 2011
  • 8909 Answers
SOURCE: where can i find free driver software download for
Need driver and bios updates?
Always get your drivers and specific software from the manufacturer of your Laptop, Notebook or Desktop. They are usually free of charge.
If you were to log on to the manufacturer's web site, usually one is able to download if available, by model number, All available Driver downloads as required.
If the driver is not available, perhaps your manufacturer does not support the OS you are installing.
This is the best way of ensuring up to date drivers for your system and they are free of charge!
I hope this helps.
Posted on Mar 03, 2011
  • 6 Answers
SOURCE: can i download kindle to
You need AppsLib on your tablet (you can download from them), and from there you can search for third party readers (I dont think you can get kindle as its designed for phones). Android tablets dont have access to the android market place therefore tablet manufacters have their own - in this case AppsLib.
Posted on Jun 09, 2011
SOURCE: How to clear internet history on coby kyros
Go to your url box and click the bookmark button, choose history, press the menu button above your tablet, the one beside the home button. A clear history option will pop out, press it and your whole history will be erased. Hope this helps. :)
Posted on Jun 26, 2011
SOURCE: my coby kyros internet tablet wont turn on
i cannot turn on my coby kyros internet tablet after charging and there are no answers or problem tips in user manual
Posted on Jul 11, 2011
Coby Kyros Mid7051 I accidently dropped my tablet and cracked the screen. It still works but I cant use the touch screen
Well you have broke the mask of the touch screen. Live with it or buy new cause a fix is more expensive than the device itself
Mar 03, 2015 | Coby Tablets & eReaders
Screen is cracked and require a replacement screen for coby kyros MID 8042 tablet
It is cheaper to buy a new tablet than it is to replace a cracked screen with a new screen. Buy a new tablet pc.
Jun 28, 2014 | Coby Kyros 716829701508 Tablet PC
Can't do anything
try to reset it again and put you information back in if still not working call tech support for there help they can give you more ideas on how to fix the problem you are having.
Nov 11, 2013 | Coby Kyros MID7022
My tablet was drop and the screen want come on
I seriously doubt they will replace it since you dropped it, but it's worth a try. You will need to contact coby support here:
http://www.cobyusa.com/?p=support
Good Luck!
Jun 14, 2012 | Coby Kyros 716829701508 Tablet PC
Dropped a Kyros tablet and cracked touchscreen,can it be fixed?
What is the extent of the damage? Size of crack, apparent depth, shape, and location on the tablet?
Jun 07, 2012 | Coby Kyros Android Tablet
Will a pny micro memory card work in my coby kyros?
Any Memory Card That says Micro SD Card should fit in the Coby Kyro, The SD Card is one of the smallest cards there are.
Mar 31, 2012 | Coby Kyros 716829701508 Tablet PC
Can not connect coby kyros to wireless network my laptop is connected but it keeps saying out of range
Coby tablets are not compatible with WIFI "HOTSPOTS", HOTSPOTS use ADHOC networking, which the tablet doesn't support.
Dec 16, 2011 | Coby Kyros Tablet
I accidently dropped my tablet and cracked the screen. It still works but I can't use the touch screen. Where do I go to get it repaired? I live in Sacramento, Ca
Here is a best buy in your area. The geek squad will be able to send your tablet out to be fixed.
http://stores.bestbuy.com/133/
Sep 06, 2011 | Coby Kyros 716829701508 Tablet PC
My kyros won't charge
I would first try a different power cord/brick and make sure that isn't the issue. If that still doesn't work then you may have a broken port on your Kyros. In that case try and get a warranty replacement and if that isn't feasible you will most likely have to pay for the repair. If you recently dropped it while it was plugged in, that may have broken the connection between the port and the device.
May 04, 2011 | Coby Kyros 716829701508 Tablet PC
Coby Kyros MID7022 Logo
211 people viewed this question
Top Coby Tablets & eReaders Experts
Fred Block
Fred Block
Martin Murray
Are you a Coby Tablet and eReader Expert? Answer questions, earn points and help others
