I am replacing an T8411R with RTHL3550 and I have the following wires (old=new): G=G R=R O=O Y=Y E=aux/E W2=?? C=?? I do not know what terminals to attach W2 and C to.
  • 31 Answers
W2 should be an ac unit and the 'c' is your common wire.
Posted on Apr 23, 2013
3 Suggested Answers
SOURCE: Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Posted on Apr 21, 2010
  • 5 Answers
SOURCE: i am installing a totaline progammable thermostat,
First off, make sure that the wires you are connecting at the thermostat match the circuit board of the unit. It is good practice, but not always followed to do a "1 for 1". To answer your question, W2 is simply when there is 2-stages of heating. If your furnace does not have 2-stage heating, then leave it empty on the t-stat. "C" is common. Common is neutral, so it should have continuity to the ground or L2. If your old stat did not utilize this, I wouldn't worry about it, unless the new stat is a touchscreen and constantly lit stat. Just keep this in mind. W-warm (heat), Y-cooling, G-fan, R-hot (main 24v power from furnace to thermostat), C-common (not always required), AUX (auxillary, if there wasn't one used on your last furnace, I wouldn't worry about it.). X may have been a common, or a dead terminal.
Bottom line, if you open your furnace to see the circuit board and where the thermostat wire connects, and match above, you should be just fine. Make sure you turn power off prior to opening the furnace, and when landing the wires on the stat. You could inadvertently blow the 24v transformer.
Posted on May 09, 2010
Have a rthl3550 I have 7 waire need to wire it up
Not using c and w2 and e can go to e
Jul 09, 2017 | Heating & Cooling
Have a rheem 41-20804-15 changing it to a
Do you have it programmed right? I don't know the colors of your thermostat wires but your w2 wire will be hooked together with your emergency wire they will be on the E terminal. you hook it up the same way you took it off but hook w2 and E together on the E terminal.
Sep 04, 2014 | Heating & Cooling
How do you relpace an A.C. thermostat?
E Back up heat/ white wire
AUX Jumper to E
Y yellow wire / Cooling - compressor
G Indoor fan Green wire
O Reversing valve energised in cooling most units Orange wire
L unknown. consult your manual Leave open
R Main power Red wire
B Reversing valve energised in Heat Rheem units only.
C Common second leg of power Blue wire.
Aug 30, 2014 | Honeywell RTH3100C - Digital Heat Pump...
I am replacing an T8411R with RTHL3550 and I have the following wires. Original vs New G=G,R=R,Y=Y,O=O......? I have a W2 and an E wire that go into different screws on original but no seperate terminal...
C is actually a power wire; it provides power for some programmable thermostats. You don't have to connect it on the new thermostat; cover the end with electrical tape to avoid it causing a short. (If you keep that wire accessible, it will be nice for someone who wants to use another programmable thermostat. The ones which can talk to wireless networks require this wire.)
Do you have a heat pump? That is the only time a thermostat uses an E wire.
The W2 wire should go to AUX (third screw terminal from the left) and the E wire should go to E (second screw terminal from the left). See page 25 (27 on the pdf) of the Quick Installation manual for the RTHL3550. This manual is available from Honeywell at http://yourhome.honeywell.com/home/Products/Thermostats/Digital-Non-Programmable/RTHL3550D.htm .
I hope this helps.
Nov 03, 2013 | Heating & Cooling
I am installing a totaline progammable thermostat, the old one is a rheem, i hooked the b wire to the b terminal the r wire to the r terminal the g to the g terminal and the y to the y terminal the e l and...
May 08, 2010 | Heating & Cooling
Apr 21, 2010 | Honeywell Heating & Cooling
I had an old thermostat that i had to change need wiring diagram
both thermostatats will have terminal designators R,W,Y,G, possibly O/B, C, W1,W2, Y1, Y2, etc.
Simplest method is to remove wires from old stat one at a time. mark where they came from and then install at same desinated terminal on the new t-stat. Hope this helps. be sure to shut off power supply to the unit (furnace) first. The wire coming to the R (RH,RC) terminal is the 24 volt a/c hot, all others are feeding back to perform given function.
Dec 20, 2008 | Honeywell Programmable Thermostat Heater
Thermostat Wiring: W2? E? Where to connect?
You have a heat pump. You need a thermostat for "Heat pump with Electric back-up heat". Make sure the 'stat has either an "aux" (auxilliary heat) or an "E"(Emergency heat) terminal. The wiring instructions will be provided with the thermostat.
Dec 15, 2008 | Honeywell Electronic Programmable...
MY HEAT PUMP SYSTEM WILL NOT WORK IN EMERGENCY MODE
the thermostat sub base has a place to connect a wire usually white to energize the heat strips when you push the stat way hotter than the house temp. that is why the strips come on in normal heat. it also has a terminal that is only energized in emergency heat and it also should have a wire connected to it so that terminal can supply power to the strips when the stat is switched into emerg heat . you can identify the terminal from the wiring diagram and if need be jumper w2 wire over to the aux terminal and it will work. they both go back into the airhandler and power the same strips. w2..................................................................................................w2 in airhandler to strips or w2...jumper to aux......................................................................................................................w2 in airhandler to strips.
Nov 10, 2008 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
405 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
