Question about GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher just started not filling enough water to wash dishes.
It use to fill for about one to two minutes and the water came up to the heating element before it shut off and started the wash cycle. Now it only fills for about 20 seconds and you cant see any water in the tub. It starts the wash cycle immediately after the 20 second fill.
I'm thinking something went bad in the control board.
  • 170 Answers
It does sound like a circuit board problem but lets not rush out and pay an exorbitant service fee yet...I checked the user manual and this model does have a timer also...so often timer go out and many people think the problem lies elsewhere...but when a timer goes out or a couple of teeth no longer engage then you could have any number of problems...I doubt the solenoid is bad or it would not initiate at all to begin with,,,,,so here is a little test......turn the DW on and cycle the timer to where it starts the water solenoid....watch the timer to see that it turns and disengages. the solenoid...How quick was it? (if under your accustomed 2 mins... problem with timer). Another test is to do the same and hold the timer tightly preventing it from turning and see if you can force the fill valve to stay open longer (if so...bad timer).
I hope this helps...please rate me....The Fang
Posted on Mar 27, 2009
My dish washer wont fill with water
there is a float, usually at front left side inside dishwasher, that may be stuck..possibly an utility holding it up, or the fill valve is stuck. When dishwasher calls for water, it fills until this float rises to proper level and shuts the valve off at proper level. If it sticks, water will shut off at improper level.
May 01, 2014 | Zanussi FS1255S Front Load Washer
My MDB5600AWW isn't cleaning the dishes. Even easy stuff like wet pasta sauce. I watched/listened and discovered the water is not staying in the tub during wash cycles. It fills, then slowly (1-2 mins)...
Check the drain hose... it sounds like it has fallen down too low and is not looped high enough to keep the water in the tub....this will let the water drain right out as it fills like you are saying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Oct 12, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Hobart WM-ID dishwasher doesn't heat water enough to clean dishes
The WM-1D does not have any internal heating devices. You have to supply the machine with the proper water temp. It has two fill valves, one for wash and one for rinse. It should have 150F supplied to the wash fill valve and 180F to the rinse fill valve.
Feb 04, 2010 | Hobart AM14C-155 Dishwasher
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
Dishwasher- dishes not clean
Hi
Thanks
Rylee
Dec 08, 2009 | Thermador DWHD64 Dishwasher
Kenmore elite dishwasher, does not get the dishes wet
sounds like wash motor is not going . it will fill and control thinks motor is working . then it will drain wash water / ( drain pump is a different motor ) and then refill and so on .. never washes but fills and drains and heats. ( look for leakage under the motor i'm sure you will find some ..
Nov 22, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore model 665 does not clean dishes
Hi
Thanks
Rylee
Aug 29, 2009 | Kenmore Dishwashers
Dishwasher does not clean the dishes properly
Hi
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dish washer not filling
I had the same problem. It was a clogged water inlet valve. Packed with sediment. Accessible from the bottom if you have the right tools. Just clean out and replace. Or the valve could be bad.
Apr 10, 2009 | Whirlpool 24 in. GU2500 XTP Built-in...
Kenmore dishwasher 58715142400 fills but doesn't wash
Motor has gone out..just like mine...Make sure u have voltage going to the motor, (disconnect the plug from the motor) and use an electric meter to make sure you have voltage going to the motor. If so the motor has either gone out or has been blocked by something! If no noise except clicking then motor has gone out. Looking at about $150 for motor.
Jan 26, 2008 | Kenmore 24 in. 15142 Built-in Dishwasher
GE 24 in. GSD6660GSS Built-in Dishwasher Logo
132 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
