Question about Garmin iQue M3 Pocket PC GPS Receiver
Cannot iinstall garmin ique m3 on my computer, missing installation software!!! Any help? LEMUX
  • 3 Answers
I did two things at once, not sure which one of them fixed the problem but it works now.
1. Make sure you are not in active GPS mode.
2. Downoad Windows Mobile PC
Posted on Jun 20, 2009
Garmin iQue M3. Gradually not responding to touch
First make sure the screen is clean of any dirt or oils that may deposit on your screen from your fingers. Use a stylist (a mini pencil like item that came with your GPS) or and other non metal semi pointed item and go through the screen alignment process. Hit the "X's" as you see them (it will move 4 or 5 times to ensure the screen is aligned.) After it is aligned it should give you other options. I have seen GPS's recycle trough the alignment process two or three times before cycling out. If you do this and you are still you are having issues, and you have tried resetting it, you may have a hardware issue.
Mar 07, 2011 | Garmin iQue M3 Pocket PC GPS Receiver
Can I replace the battery in a Garmin iQue M3 ?
Unfortunately the answer according to garmin is no. The battery is non-user replaceable. It may be replaceable by Garmin. You can get contact details for Garmin at http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=0E66B6932CAEAD7A98A6C126E06B1F02 if you want to check with them.
Jul 25, 2010 | Garmin iQue M3 Pocket PC GPS Receiver
Hot sync problem for Garmin iQue 3600
If reinstalling on the same computer with your original cd doesnt' work then I suspect that your registry has gotten corrupted somehow.
I'd find another computer and try a totally new install to see if that works. This registry stuff is a headache.
If it works on a different computer then I'd go into the registry and remove all traces of Palm and ique and start all over. Always make a backup of your registry before messing around with it. If the original CD worked before then there's no reason to download newer versions unless you are wanting to solve some other problems.
Don
Jan 27, 2010 | Garmin iQue 3600 GPS Receiver
Need to replace the main battery in my Garmin iQue M3...is this something I can do myself? No longer under any warranties so opening the case should be fine. Can't find anywhere online with information on...
procuring the battery is one of the problems you will have. The other problem is loosing springs on the toggle switches if you are not careful in dissasembling the thing.
Oct 13, 2009 | Garmin iQue M3 Pocket PC GPS Receiver
Can't install software drivers from CD
Try going to the Garmin website at http://www.garmin.com . You can download the drivers in the support section. After you install the drivers reboot your computer and then connect the GPS with the included USB cable.
Apr 06, 2009 | Garmin iQue 3600 GPS Receiver
Would not come on
No this is not normal send it back for repair, if you bought it for less than a year you should have warranty coverage. You have to call garmin to get RMA #.
Apr 21, 2008 | Garmin iQue M3 Pocket PC GPS Receiver
Sync problems with windows vista
I got a Vista computer in April and have problems also. You need a special program to install the maps. email Garmin and they will send you the link. An SD card reader/writer is MUCH faster than the sync.
I didn't have syncing problems until after I tried to install Documents to Go. I had to remove Doc to Go v6 because it was making my computer unstable. Doc to GO V10 works with Vista but requires Palm OS6. Garmin says that Palm OS6 can't be installed on the Garmin iQue because they added proprietary software to OS4. I believe my sync problems will disappear after I reload the Palm Software.
Feb 18, 2008 | Garmin iQue 3600 GPS Receiver
Garmin ique 3600 won't turn on after battery goes dead
I had the identical problem; I called Garmin and a new battery = $50, installed only @ the factory. I tried buying one off eBay, but those batteries spec out ok but don't have the pigtail leads required for my M3 (probably would work just fine for M5). I soldered on the pigtail from the old battery from my M3, then put it all back together. Works! However, the new battery ultimately drains down over several hours so when I'm not using it I have to trickle-charge the thing constantly. Bottom line: I suggest sending your M3 back to the factory for a new battery rather than trying to replace it on your own.
Jan 25, 2008 | Garmin iQue M3 Pocket PC GPS Receiver
Garmin 3200 GPS SYSTEM
Have you receicee any help on this? I am having the same problem. Garmin told me to uninstall all of the software and start over. Same problem. Tried it another computer - same problem.
Aug 29, 2007 | Garmin iQue 3200 GPS Receiver
Cant get it to work
If this is an IQue 3600 then you will need to install the Palm Desktop from your original IQue disk in order to sync with your new laptop. The Microsoft active-sync is for a PDA using Windows (Garmin M3 and M5 are windows based PDA w/GPS).
May 09, 2007 | Garmin iQue 3600 GPS Receiver
Garmin iQue M3 Pocket PC GPS Receiver Logo
108 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
