Question about Plumbing
Moen 87650srs lever removal - Plumbing
2 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Posted on Feb 23, 2009
How to tighten set screw on Moen brantford shower lever
It sounds like the lever handle adapter may be broken or has become disengaged. . Remove the handle and inspect it. If the adapter is broken, it can be purchased at a plumbing supply house. Neither Home Depot nor Lowes will have it.
Dec 12, 2015 | Moen Home
Moen 4700 lever broke off, how do i reinstall it
some have to. be pryed up with a pry bar (small) then just putnew handle in place replace screw and the red/blue cap
Jan 05, 2015 | Moen Plumbing
Trying to change cartridge on Moen single lever kitchen faucet with sprayer. Now that it's been reassembled, gets no water from spout when turned on. When lever is turned on, sprayer goes off and...
Moen has a diverter built in that will need to be replaced.
use the same steps as when you replaced the cartridge, but this time you will need to remove the spout, there is a small diverter, you will see it when spout is removed.
take this part with you to the hardware store, along with the O Rings from the spout, as they will need to be replaced also
use a non silicone faucet lubricant when putting back together
Aug 08, 2010 | Moen 7437 Chateau Single Hole Kitchen...
I have a kitchen single lever moen faucet and the cartridge wont come out. I have removed the retaining clip and all screws
you may need to get the moen cartridge puller,either moen brand, or brass craft, they can be tough to pull some time's
Feb 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
How do I pull a moen single lever kitchen cartridge out that is old and stuck?I removed the horseshoe shaped clip. When I pull the valve stem, it doesn't budge.
there is a little plastic tool that comes with a new cartridge....you use it to turn the cartridge back and forth....breaking the seal that has formed between the rubber on the outside of the cartridge and the inner wall of the valve. After doing that you should be able use a pair of channel locks to pull the cartridge out.
Oct 20, 2009 | Moen & Replacement Cartridge
HOW TO DISMENTLE OR REPLACE A MOEN SINGLE LEVER
shut water off at stops under sink. Unscrew water supply lines from directly below handles. Above them you will find plastic nuts, remove them. Disconnect pop/up lever and you should be able to lift faucet from sink.
Sep 24, 2009 | Moen & One Handle Tub & Shower Faucet
Single lever moen shower valve -can't remove handle
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Plumbing Logo
207 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
