Question about Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner
Polaris pool clener sweeper not moving - Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner
    Top Expert:
  • Polaris Master
  • 8,688 Answers
If water pressure ok check inside for hoses off or belts broke
Posted on May 22, 2016
2 Suggested Answers
SOURCE: Older Polaris doesn't sweep
pantera ll by wicor sand filter distributes the sand back into the pool, what could the problem be?
Posted on Jun 02, 2009
The Polaris sweeper works if I shut the hole beneath the diverter below the skimmer basket.
make sure pump top seal ok and intake union ok see if leak in diverter valve or just leave closed during cleaning
May 24, 2016 | Polaris Pool & Spa
Polaris 3900 is not picking up debris
open unit see if belts and hoses ok and if ballast ball has water replace it
May 18, 2012 | Polaris 3900 Sport Pool Cleaner ()
The wheels are not moving when hooked up, When i move one manually they all move. i made sure the pool filter basket is clean and the water pressure going into polaris seems like it is strong.
Also check the skimmer basket and pump. Make sure they are functioning properly. Check all hoses, connections, and swivels for leaks that could be causing a lack of water pressure in these pool cleaners. Make sure that your wheel RPM is between 28 and 32. Increase the pressure to create more RPM.
Aug 29, 2010 | Polaris 380 In Ground Pool Cleaner
Need picture of hose set up for polaris 380. Not just the diagram but an actual picture of it assembled. Thanks
should be a return outlet half way in pool closest to pump install fitting into wall connect Polaris and turn on filter pump and booster pump should move around pool adjust screw on back bottom for tail
Apr 29, 2010 | Polaris 380: Polaris Booster Pump
Polaris 380
polaris has belts in side it if your handy you can replace them your self if not any pool place can do it but it is a belt i have a 380
Jul 21, 2009 | Polaris 380 In Ground Pool Cleaner
If the unit travels normally and picks up debris as it should,there may be a problem with a feed hose inside . Separate the haed shell and inspect. often the plastic clamps finally give out and allow hose to pop off. Also check inner hoses for any swelling and possible slits.If the unit doesn't act in a friendly way then you have water supply issues and/or inadequate water pressure to unit. Check stream from wall with unit disconnected.
Apr 06, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris 180 In Ground Pool Cleaner In Ground Pool Cleaner Logo
35 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
