Question about GPX BC112B - Bc112b Boombox & Cd Player
CD player will not work, power on, CD switch on, display says "No" when all is loaded
I've had my jukebox for 6 years and the free play ran out. I forgot the code its a rowe cd 100 commerical
it should have a free credit button on thecircuit board they usually black or
red just press several times
Aug 21, 2011 | Wurlitzer Jukebox CD Player
When i switch my teacpdh300 cd player on the drawer open and when i close it, it reopens
hi,
Check the tray loading belt of your cd player. If the loading belt is over sized then this problem can occur. Normally the loading belt will become over sized after a few years of use according to the weather condition. . If so the loading tray will not go inside fully and will not engage with close sensing switch. if so the it will open automatically without any external command .Normally in all players the loading belt will be under the loading tray near the frond side of the mechanism. check the same. keep the player in eject position remove power and then try to replace the belt.
ok
Jun 16, 2011 | Teac PD-H300 CD Player
Cd player reads err on display
internal problem in radio,you would have to take it to a dealer to send out for you,
Jan 01, 2010 | 2000 Chrysler 300M
My eurovox radio/cd/tape player displays error message E-99 when i switch to cd
E99 RESET PROCEDURE:
Remove CD magazine by pressing eject button on changer.
Remove all discs from magazine and re-load empty magazine into
changer. Using the Radio RESET CD system by pressing and
holding the “ON”/”POWER” button for about ten seconds, or in
earlier models the “EJECT/6” button.
Oct 03, 2009 | Car Audio & Video
Jvc dvd XV-N322S REGION CODE-2 is showing 'NO FILE'
It's a software problem pls upgrade ur dvd player.ur problem will be solved
May 11, 2009 | JVC XV-N322 DVD Player
Re: Kenwood DV 605 CD Player... Power On: Reads "Loading." All 5 CD lights are lit up but the CD changer does not turn. CD #1 appears on screen with two green lights appearing.
ace71cf.jpg We repaired this problem by taking the advice of another member of FixYa! The component had recently been packed to be shipped. After unpacking the unit when we powered up the read out only displayed "LOADING" and the CD changer door would not open. We removed the exterior cover and gently moved the CD changer one position. When it locked back into position we powered up and the unit works fine now. FixYa sure help me save perhaps a $100. or more by not sending it to the manufacturer or another shop. And it was working within minutes so we could enjoy using it right away. Thanks guys I very much will recommend this sevice to others... this was the 2nd problem we fixed that day by logging onto FixYa!!!
Z-Dawg
Dec 06, 2008 | Kenwood DV-605 Multi-disc DVD Player
2004 honda accord CD player not working
I have the same problem I bought one with the same problem. Does any one have a solution.
Help
Dec 02, 2008 | 2004 Honda Accord
New installed cd player wont work
did tou wire the red line to 12volts when the ignition switch is in the acc or on position- and the yellow wire is powered at all times regardless of the position of the key switch?
Apr 02, 2008 | Aiwa CDC-X227 CD Player
Need Help !
Judging from the symptoms, I'd guess that "ACCS" means "accessory". All CD players have a constant power input and an accessory power input. There has to be voltage on both wires for the CD player to work, although the clock and CD load/eject functions will work with just a constant power connection. My guess is that there's an accessory switch somewhere in the boat that needs to be turned on for the CD player to activate. Failing that, if you can get the the wiring on the back of the CD player, the red wire is the accessory power wire. You can simply cut it and re-connect it to the same source as the yellow constant power wire. This will allow the CD player to work independently of any outside switches.
Jul 10, 2007 | Clarion M5675-RET CD Player
GPX BC112B - Bc112b Boombox & Cd Player Logo
61 people viewed this question
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
