Question about PSA Parts Limited Phihong PSA16U-480 - Power injector - AC 100-240 V - 1 output connector(s) (PSA16U480POE)
How do i open my routers nat for xbox 360
Poe16u-480. ieee 802.3af compliant single port injector
Every time i try to join my friends game it says session is ureachable and it is really annoying. We live at different IP addresses and could connect before. We all have the same DLCs and it is only me...
make sure you and your friends have open NAT, you need to port forward certain ports for xbox live on your router, try to check if ubisoft also has specific ports need to be open. if still the same contact your ISP, they might be having problems.
Mar 23, 2011 | Ubi Soft Assassins Creed: Brotherhood for...
My NAT typ on xbox live is set to strict i want to change to open
Put the IP Address of your Xbox 360 in the DMZ on your router. Anything in the DMZ is free of all firewall restrictions and all ports are open to this device. Once you place the Xbox 360 in the DMZ your NAT will be Open.
Thank you for using FixYa!
Mar 01, 2011 | Belkin Basic Wireless Router
My nat is set to strict and I have done all the port forwarding and open ports nothing works i'm very frustrated.
As you said your NAT is set to "Strict" I assume this is about the Xbox 360.
Mar 01, 2011 | Computers & Internet
My router is on, and is hooked up to my verizon modem. My xbox 360 and my computer are both hooked up to the router and all the lights are on but only my computer is working for the internet where my 360...
with verizon, you need to set the modem to full bridged mode so that the connection from your modem will be opened. This certain firewall is called NAT. Your modem and your router has this feature. To disable NAT on your modem, you need to set it to full bridged mode. To disable the NAT on your router, you need to open ports on your router.
You need to open this port on the router for Xbox live to work
TCP: 80, 3074, 53
UDP: 88, 3074
forward it to the ip of your Xbox.
this should set the NAT on your xbox to open, not moderate.
Sep 18, 2010 | Dell TrueMobile 2300 Wireless Broadband...
Better online gameplay xbox 360 open nat type
Hey to open your NAT log into your router and look for a setting called DMZ enter your xbox IP (usually starts with 192.168.1.?) into the DMZ box and enable it.
Good Luck & Game on!!! :)
Jan 25, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Connecting xp to xbox 360 for internet. now it tells me nhat i have a strict nat setting dont know how to change.
There should be an option for AUTO settings. Make sure that is selected and it should fix your problem. If not, post here again and I'll help further.
Sep 22, 2009 | Microsoft Xbox 360 Console
Can't get NAT setting to Open for xbox 360. Won't connect to other users with open setting
The NAT is set to the actiontec modem/router so the next troubleshooting is to open the ports of the XBox ports 80, 3074, 53 TCP and 88, 3074, 53 UDP. To allow the XBox on the network using your modem/router.
Jun 27, 2009 | Actiontec (GT704WG) Router
Cant have private chat or play games with friends
This should solve your problem
For most devices that use NAT, port forwarding is not required to connect to Xbox Live. This is especially true if you use an Xbox Live certified device. Sometimes, you may have to configure port settings on a non Xbox Live certified router or gateway.
If there is a firewall device between the Xbox console and the network device, you may have to configure the firewall to enable communication on specific network ports. If the NAT status in the Network Status area of the Dashboard is "moderate" or "strict," you may have to configure port settings.
The following ports must be available for Xbox Live to operate correctly:
� UDP 88
� UDP 3074
� TCP 3074
To open the ports on your router see this handy website here,
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
which gives you a step by step guide.
Before opening the ports you must give your Xbox 360 a static IP address (manual) be sure to use an IP address that no other item on your network is using and is fairly high up in your range, for example if your router's address is 192.168.0.1 then you should use something like 192.168.10 for your Xbox 360.
You can also enable DMZ (Demilitarized Zone) on your router, which will open up all the ports to your Xbox 360, however NEVER use this on a PC's IP, see your router's manual on how to do this.
Once the correct ports are open for your Xbox 360, then your NAT should say open.
Nov 26, 2008 | Microsoft Xbox 360 Console
Router will not allow me to play onling games through xbox 360
If the problem has something to do with NAT firewall in your router, then you may need to open certain application ports for your XBOX in the router. You may check this link from Microsoft http://support.microsoft.com/kb/908874 that talks about NAT firewall and XBOX live.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Nat / strict
First, why are you connecting to your laptop? Second, reset your modem and router. I doubt you need to open ports that are not normally open...but if you think you need to do more, access the router and open the ports manually.
Nov 27, 2007 | Microsoft Xbox 360 Console
PSA Parts Limited Phihong PSA16U-480 - Power injector - AC 100-240 V - 1 output connector(s) (PSA16U480POE) Logo
52 people viewed this question
Top PSA Parts Limited Computers & Internet Experts
David Payne
David Payne
Are you a PSA Parts Limited Computer and Internet Expert? Answer questions, earn points and help others
