Question about Vehicle Parts & Accessories
Abs light stop on dashboard on a 95reg calibra
Its had new abs rings on the back wheels and a new abs sener on the front left wheel and its been to my local vauxhall dealer they cant help me either after i spent 70 can you please help me
  • 5,759 Answers
Could be bad sensor.
Posted on May 09, 2013
Intermittent abs light
What make , model an year vehicle ? Is the wheel speed sensor integral to wheel bearing hub or separate ? Could be a corroded tone ring on half shaft . ABS activates on every stop damaged tone ring
Sep 13, 2016 | Cars & Trucks
ABS brakes activate when they should not
A bad hub bearing could cause false ABS activation . Or the tone ring that triggers the wheel sensors . Tone ring is located inside hub bearing or axle shaft . They get corroded an rusted . Chevy Truck ABS Problems Unwanted ABS Activation
Mar 08, 2017 | GMC Cars & Trucks
ABS Light Stays On
Since you replaced the pick up units or sensors, check the tone rings on the axle shafts. The tone rings is what the sensors detect and are located at each wheel that has ABS. A tone ring looks like this:
This tone ring is on a Ford Ranger - which is pretty much the same as your Mointaineer. Notice the break in the tone ring. This will cause an ABS Fault indicator and will need to be replaced to extinguish the lamp. Check the brake fluid level and top off if needed.
Try another AutoZone or similiar to get a code and be non-specific about the light - just say a light came on on the dash and you don't know what it is about.
Jan 03, 2013 | 2004 Mercury Mountaineer
1998 chevy express van 3500 front brakes and rear are new, front calipers are new but ABS light on dash is on, the front brakes smoke after a little while of driving. Thanks Joe
I'd first make sure the new pads are the correct size. Doesn't happen very often but maybe the parts person gave you the wrong size pads ( for the smoking problem). As for the ABS light, most newer cars will throw out codes if you wait too long to change them out, I would contact a chevy dealer or search online about reseting the code (light).
Dec 07, 2010 | 1999 Chevrolet Silverado 1500
LEFT FRONT WHEEL BEARING IS MAKING A REAL LOUD NOISE AND THE abs LIGHT IS ON. what COULD IT BE?
Well, start by repairing the obvious issue. ABS sensors are located in the same area, so when the bearing fails, metal filings go everywhere and mess up ABS sensing...
Sep 06, 2010 | 2007 Chevrolet Uplander LS Minivan
Check abs system lite on how do you find the code list
ABS Fault Code List 1991 Corvette (C4)
Code Definition
21 Right Front Wheel Speed Sensor Fault
22 Right Front Toothed Wheel Frequency Error
25 Left Front Wheel Speed Sensor Fault
26 Left Front Toothed Wheel Frequency Error
31 Right Rear Wheel Speed Sensor Fault
32 Right Rear Toothed Wheel Frequency Error
35 Left Rear Wheel Speed Sensor Fault
36 Left Rear Toothed Wheel Frequency Error
41 Right Front Solenoid Valve Fault
45 Left Front Solenoid Valve Fault
55 Rear Wheels Solenoid Valve Fault
61 Pump Motor or Motor Relay Fault
63 Solenoid Valve Relay Fault
71 Electronic Brake Control Module Fault
72 Serial Data Line Fault
75 Lateral Accelerometer Fault (Short ot Open)
76 Lateral Accelerometer Fault (Signal out of Range)
Mar 12, 2010 | 1991 Chevrolet Corvette
Speedo suddenly not working and two warning lights appeared on dashboard one being ABS light warning light.
If the ABS (and likely the traction control) light came on at the same time that the speedometer stopped working, you likely have a faulty wheel speed sensor at the right rear wheel. You can test this by swapping the two rear wheel speed sensors (ABS sensors). If the speedometer then works (but the ABS & Traction control lights stay on), replace the sensor that is now at the left rear (was at the right rear). If no change, you may have a fault in the ABS & Traction control - control unit.
Rear wheel speed sensor at www.bavauto.com
http://www.bavauto.com/shop.asp?HC1=0&Htarget=search.asp&HCY=2001&HCM=330i&SearchStr=rear%20abs%20sensor
Nov 22, 2009 | 2001 BMW 330
Trac Off and ABS Lights came on, won't go off
trac control & abs light staying on in dash on pt cruiser 2001 limited
well had same problem with my pt cruiser 2001, firstly there is no need to plug in computer under the dash for pulling abs error codes,
because the problem can be the cracked abs ring on the drive shaft/cv joint,
turn your steering all the way to left and ask your colleague to see if behind the tyre the abs ring is broken or cracked,
it is circular like a bracelete with grooves, then turn the steering to the right and repeat the inpesction,
if the abs ring is cracked then look on ebay or web for pt cruiser abs ring or kia abs ring, should cost about £5-£10 each
and a garage could heat it up with gas and hammer it into the drive shaft/cv joint for you for about £20-£30,
takes about 30min to 45mins, make sure the garage dont heat the cv booth kit rubber next to the abs ring when heating it up.
i heard you can only buy abs ring for front wheels and its not available separately for rear wheels,
so for rear you may need to buy the whole part it comes on
the front abs rings are easily visible when you turn the wheel to one side, the rear ones may not be visible as i have not seen them
so if the abs ring are good then it wil probably be one of the wheel sensors, in this case you you may look for a garage who will hook up
the computer and pull the code for you, be carefull if the say there are no abs error codes it means the sensors are ok and most of it
there is no need to buy abs sensor for any wheel when there are no error codes
on pt cruiser you can pull engine error codes yourself without a computer, just do the key dance on the ignition,
turn key until dash lights come on then switch off and then again turn key until dash lights come on then swithch off,
then turn key for third time again until dash lights come on , you will see engine error codes displayed then says done,
if there are no error codes it will say done, howevere these are engine error codes only not abs error codes,
abs error codes are pulled using abs diagnostic tool
incase its a faulty wheel sensor, will cost £45 at dealer or £20 from scrap, then a garage can removed the tyre and plug out the old sensor cable
and replace it with a new one, one end is easy to plug in but the other end has to be pushed in at an angle,
its about 30min job and garage can charge £20 or so
my pt cruiser is back on the road with just one abs ring replaced and it all cost me £30 alltogether
Apr 11, 2009 | 2002 Chrysler PT Cruiser
2002 2WD CHEVY TAHOE ABS
Its possible that right wheel speed sensor is dropping out early making the truck think that wheel is locking up. That will activate the ABS and let the brake go on the right wheel which will make the vehicle pull slightly left. The only way to know for sure is to watch the wheel speeds on a scanner and see which one is drpping out first and replacing that speed sensor/bearing assembly.
good Luck
Sep 20, 2008 | 2002 Chevrolet Tahoe
Vehicle Parts & Accessories Logo
46 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
