Question about Briggs & Stratton Garden
Valve adjustment on 23hp troy built mower
Not starting
    Sergeant:
    Champion:
  • 320 Answers
Model, Type and Code are required if this is a Briggs and Stratton engine. Thanks; George
Posted on Oct 18, 2013
buffalonyman
  • 1865 Answers
SOURCE: Troy Built Riding Mower will not start
Your replacement battery is likely defective.
Posted on Jul 09, 2009
  • 582 Answers
SOURCE: How do I level the mower deck? I have a 48
the easyest way i have found is to use 4 pieces of brick , get the mower on a level surface place one oiece of brick under each corner of the deck and make adjustments until the deck starts to raise off the bricks
this should be the three inch level . my mower had the same problem and this worked for me
Posted on Sep 03, 2009
  • 74 Answers
SOURCE: need a wire diagram to reconnect starter solenoid
http://i107.photobucket.com/albums/m314/Restrorob/MTD/MTDOHVTwinWireDiagram.jpg
Posted on Sep 20, 2009
  • 89 Answers
SOURCE: I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Posted on Nov 09, 2009
  • 3911 Answers
SOURCE: How to tighen the built on a Troy Built Pony 42in
You can't really tighten the belt on any of these mowers.
First make sure you have the right belt, if you measured the old one when it broke
then you were not using the size it was before it got all stretched out from use. Find a manual
or look around online for a source to tell you the size the belt should be new and get one.
Second there is a tensioner arm, spring, and pulley which take up the slack, this may
double as a clutch to put in slack when you depress the pedal. Make sure the pivot for the
arm, the spring, and the pulley/bearing are all in good shape.
Third there are belt guides which can also be worn and create slack, so check those and make sure
they are in good shape as well. I may not be the only one who ever put a belt on the wrong side of a guide.
Lastly make sure you have the belt on correctly, and nothing is bent, split, or warped.
Posted on May 03, 2011
Mower turns just a couple times then stops. Could it be the starter (725cc 23hp Kohler engine, troy build hourse)
sounds like the valves are out of adjustment. not letting the compression stroke release on time.
Apr 15, 2017 | Troy Garden
Before. My Troy riding mower stopped running I was having to hold the pto lever down for it to start
adjust valves and make sure flywheel is in alignment with a new straight key
Sep 17, 2016 | Troy Garden
Solenold switch replacement on a troybilt mower
First check voltage at starter with key turn to start. Adjust valves. Why this, if valves are out of adjust. Don't release compression.
Nov 09, 2013 | Troy Garden
How do i adj the valves on a 23hp kawasaki ?
You need to remove the rocker arm cover. Then most engines have a set screw and a locking nut that hold the valve rocker arm on. Loosen the locking nut and with a feeler gage make whatever adjustment you need (tighten or loosen) then holding the adjusting screw from turning, tighten the lock nut. It is not very hard to do and remember that they are all metric fasteners.
May 19, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Kawasaki fh680v 23hp will not start at random. Coils are good, fuel pump, filters air and fuel, plugs and battery are all good. Valves are adjusted correctly and one head gasket has been replaced. It will...
Check solenoid on the back of carb! I just had a similar issue with the same motor, would start rite up but had no power! new fuel pump coils, plugs ect I found the ground wire going to the coils were zip tied to manifold and rubbed through on the underside of wire never saw it 2 days later ripped it apart again and bingo found it taped it fixed problem.
Aug 12, 2010 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
Troybuilt/bronco wont start
IF YOU HAVE A NEW BATT IT COULD NEED THE VALVE LASH RE SET
Sep 19, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy built lawn tractor won't start.changed plugs.
i have a troy bilt riding mower,i start the mower it only runs for 15 to 25 min's ,so i changed the coil to see if it would run long. but after a few minunts it stop again so i don't know if maybe it's my carb. what could it be.... help
Jul 03, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Built 6.75 Self Propelled to Slow
put oil or grease all the shafts and bearings inside and out, if possible adjust the cutter blade contacts.
May 20, 2009 | Troy Bilt 5.5hp Self Propelled Mower
I OWN A 2006 TROY BUILT HORSE 23HP. THE PROBLEM IS THE ENGINE IS HARD TO CRANK. I REPLACED THE STARTER AND BATTERY. COME TO FIND OUT THE ONLY WAY I CAN GET IT TO CRANK IS TO TAKE THE SPARK PLUGS OUT. ITS...
You either have a problem with the wiring and its not allowing the voltage to flow freely to the start or there is some type of internal engine failure that is causing the valves to stay closed.
May 13, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
199 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
