Question about Poulan Pro 260 Chain Saw Rear Handle With Cable & Outer Manifold
HOW DO I INSTALL ACCELERATOR ACBLE ON A 260 PRO POULAN CHAIN SAW?
HOW DO I INSTALL AN ACCELERATOR CABLE INSIDE THE REAR HANDLE OF A 260 PRO POULAN CHAIN SAW?
2 Suggested Answers
steve_lima
  • 181 Answers
SOURCE: Pouulan Pro 260 chain saw - installed brand new
thake the muffle off and look inside the hole at the piston.if you see any marks on the piston,the saw will never start.you need to change the piston and cylinder assy.the cost is about $150.00 for the parts.that does not include any labor cost.most of the time it's not worth repairing.let me know if this helped or not...................................
Posted on Jun 06, 2009
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
Where can I find a thumbwheel adjustment foe a poulan chainsaw?
You can find just about any item needed to fix you chainsaw on www.ereplacementparts.com
I am not sure if you have the Poulan 260 pro, but I have attached the link from e replacement parts for that saw.
http://www.ereplacementparts.com/poulan-260-pro-chainsaw-parts-c-16962_17133_202439.html
Good luck in fixing your saw.
Aug 13, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do you chage a choke knob on a poular chain saw
If the knob is attached to a cable you will need to replace the entire cable which comes with the knob attached. You can just follow the cable and determine how to route the new one and attach it the same as now to the carb.
Jun 17, 2014 | Poulan Pro 260 Chain Saw Av Springs,...
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
Oct 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where can i find a service center to purhase a chain adjusting assembly for a poulan 2055 chain saw in the tampa area
Poulan Service Locater
http://www.poulan.com/node6604.aspx
An example of an IPL for a "2055 Gas Chain Saw Type 7" follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2055-Gas-Chain-Saw-Type-7/75.2055-Gas-Chain-Saw-Type-7.1.59.1.html
See the "Handle, Bar and Chassis Assembly" print, item 29, $2.53
If not your saw, yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type. HTH
Lou
Feb 24, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
How do I put the cutting chain onto the bar of a Poulan Pro 260 18" unit?
If the chain is off the bar slide then you have to loosen the set screw on the bar on the side where it goes into the main body, may be undser a cover.....
Feb 15, 2010 | Poulan Pro Chain Saw 46cc 20"
Jun 06, 2009 | Poulan Garden
Poulan pro 260
Clearance from coil to flywheel should be around .010
Oct 25, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan Pro 260 Chain Saw Rear Handle With Cable & Outer Manifold Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
