Question about Cisco 2610XM Router
Router won't start. - Cisco 2610XM Router
  • Gopi Venkatesan
    Gopi Venkatesan May 11, 2010
    Can you power up the box?
  • Adi Sunardy
    Adi Sunardy May 11, 2010
    It could be Hardware problem, it could be Power Supply problem. Please submit more info for your router condition.
  • 30 Answers
Reload a new image using the serial process via serial port
Posted on Dec 05, 2009
Wireless LAN button won't switch off.
Most Netgear routers have a recessed button on the back or bottom panel, marked "Reset" or "Restore Factory Settings". Because the button is recessed, you will require a thin tool to press it. Most people use a straightened paperclip.
  1. Power up the router, and wait for it to complete booting up, typically about one minute.
  2. Press the Reset or Restore Factory Settings button until the test or power led starts blinking. This takes about 20 seconds. Release the button.
  3. Wait for the router to reboot.
  4. Log in with the default password. If the reset was not successful, try these additional steps AFTER the router has finished rebooting.
  5. Unplug the router's power.
  6. Press and hold the Reset button. While the button is held down, reconnect router's power.
  7. Continue to hold the reset button for 20 seconds after reconnecting the power.
  8. Wait for the router to reboot.
  9. Log in with the default password.
Apr 17, 2013 | NetGear N600 Wireless Dual Band Router
My Linksys E2500 router won't fully power up. The lights are dimly lit.
Start to change:
1-Charger / Cable then;
2-Test; no luck?
3-Device is dead
Apr 12, 2013 | Computers & Internet
My modem and router won't work simultaneously
They chain together. Connect the modem first to the ISP drop. Then the modem to the routers main port. Then the connect the PC to the router.
Modem > Router > PC
Jan 09, 2013 | EnGenius Technologies ESR-9752 300mbps...
Set up cd
you do not need the cd if you use its web-based interface, open your browser to the router's IP and start making changes to the router configuration from there.
good luck
Majdi
Dec 27, 2011 | Belkin Basic Wireless Router
Can't connect iphone to dlink router
When my ipod tries to connect to my computer wirelessly, it asks for the password. I enter it, but it won't accept password. It finds the router ok, just says password is incorrect. I've checked and it's the right one. Any suggestions?
Nov 27, 2011 | D-Link DIR-615 Wireless Router
My password won't work?...and it won't open...what would i do ??.the reset button also wodl'nt work?/
if the reset button wont work better to replace the router. But before replacing try the following steps first to reset your router.
Step 1: Plug the power of your router wait until the lights are fully initialized.
Step2 : Reset your router by pressing the reset button or hole with atleast 5-10secs.
Step3: Open a browser (ei, IE Mozilla or Google Chrome etc.) and type the specified IP address on the address bar.
Step4 Then type the username : Admin password : 1234 or leave it blank.
Hope it helps.
Sep 09, 2011 | Edimax BR-6226n nLite Wireless Broadband...
The router took longer and longer to start once the switch was turned on. Now it won't start at all.
remove switch and disassemble and clean it. mine was full of wood dust , cleaned it and it worked like new again.
Jul 30, 2011 | Bosch 1617EVS 2 Router
My old d-link router works fine. I bought a new DIR-615 but it won't connect. My computer won't "see" it. I followed all directions several times.
Make sure that the broadcast SSID in your router is enabled. Try setting it up again and make sure all necessary settings are set, or it might be the settings in your computer itself, let me know what type of computer you are currently using so i can check.
Jul 03, 2011 | D-Link DIR-615 Wireless Router
Open Questions:
2611XM Inbound NAT/Port-forwarding/Service Distribution Problems My NAT port-forwarding is working on some servers but not all servers. Keep getting (111) Connection refused when trying to access a number of the servers from outside. Searched and searched..tested...re entered them..have not been able to figure out. Thanks, Greg interface FastEthernet0/0 description ***Outbound interface connected to ISP*** ip address xxx.xxx.xxx.xxx 255.255.255.248 ip nat outside ! interface FastEthernet0/1 description ***Inbound interface connected to 2924 Core Switch-port 1*** ip address 192.168.15.1 255.255.255.0 ip nat inside THESE TWO WORK ip nat pool xxx_SAP 192.168.5.2 192.168.5.2 prefix-length 30 type rotary ip nat pool xxx_webserver 192.168.5.130 192.168.5.130 prefix-length 30 type rotary ! ip nat inside destination list 101 pool xxx_webserver ip nat inside destination list 102 pool xxx_SAP ! access-list 10 permit 192.168.0.0 0.0.255.255 access-list 101 permit tcp any host xxx.xxx.xxx.xxx eq www access-list 102 permit tcp any host xxx.xxx.xxx.xxx eq 3299 access-list 102 permit udp any host xxx.xxx.xxx.xxx eq 3299 THIS IS ONE OF THE ONES THAT DOESN'T WORK ip nat pool xxx_RDP 192.168.5.11 192.168.5.11 prefix-length 30 type rotary ip nat inside destination list 115 pool xxx_RDP access-list 115 permit tcp any host xxx.xxx.xxx.xxx eq 8089 access-list 115 permit udp any host xxx.xxx.xxx.xxx eq 8089 xxx_distribution_1#sh ip nat statTotal active translations: 1504 (0 static, 1504 dynamic; 1504 extended)Outside interfaces: FastEthernet0/0Inside interfaces: FastEthernet0/1, FastEthernet0/1.5, FastEthernet0/1.10, FastEthernet0/1.15 FastEthernet0/1.20, FastEthernet0/1.25, FastEthernet0/1.30 FastEthernet0/1.35, FastEthernet0/1.40Hits: 4130866 Misses: 93029CEF Translated packets: 4158864, CEF Punted packets: 110268Expired translations: 109237 Dynamic mappings: -- Inside Source [Id: 1] access-list 10 interface FastEthernet0/0 refcount 1469 -- Inside Destination [Id: 2] access-list 101 pool xxx_webserver refcount 22 pool xxx_webserver: netmask 255.255.255.252 start 192.168.5.130 end 192.168.5.130 type rotary, total addresses 1, allocated 22 (2200%), misses 0 [Id: 3] access-list 102 pool xxx_SAP refcount 13 pool xxx_SAP: netmask 255.255.255.252 start 192.168.5.2 end 192.168.5.2 type rotary, total addresses 1, allocated 13 (1300%), misses 0 [Id: 14] access-list 115 pool xxx_RDP refcount 0 pool xxx_RDP: netmask 255.255.255.252 start 192.168.5.11 end 192.168.5.11 type rotary, total addresses 1, allocated 0 (0%), misses 30
Feb 26, 2017 | Cisco 2610XM Router
Cisco 2610XM Router Logo
59 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
