Question about Zynga Texas HoldEm Poker
I can not play it shom me message - Zynga Texas HoldEm Poker
How do I retrieve recorded messages from an outside phone?
You can access the answering system remotely by dialing your home telephone number from any touch-tone telephone. To remotely access the answering system
Dial your telephone number from any touch-tone telephone. When the answering system answers, enter the two-digit remote access code (19, unless you have changed it). The answering system automatically announces the number of messages (new or old) if there are any. If there are new messages, the answering system automatically begins to play new messages only. -OR If there are no new messages, the answering system automatically begins to play all old messages. You can also enter the remote commands: Play all messages
1 Press to listen to all messages. If there are new messages, the system plays back only the new messages (oldest first). If there are no new messages, the system plays back all old messages (oldest first). Play new messages
2 Press to listen to new messages only. Delete a message 3 Press during message playback to delete the current message. Delete all old messages
3 Press to delete all old messages. Replay current message or previous message
4 To repeat the message currently playing, press 4 after the answering system plays the day and time the current message was received. To listen to the previous message, press 4 while the answering system is playing the day and time the current message was received. Stop
5 Press to stop playback and recording. Play help menu * 5 Press to listen to a list of remote commands. Skip to next message
6 Press during playback to skip the current message and advance to the next message. Record a announcement
7 Press to record a new announcement. Begin speaking after the long beep. Turn system on or off 0 Press to turn the answering system on or off. Exit
8 or hang up Press to end remote access (the call is terminated). 1. 2. 3. 4.5
0 Answering system Remote access Hang up to end the call and save all messages.
NOTES: If you do not enter a valid remote access code, the system answers the call automatically. If the date and time is not set when a message is recorded, the system announces, "Time and date not set" before the answering system announces the number of messages. If there are no messages in the answering system, the system announces, "You have no message." If there are no new messages in the answering system, when you press 2 to play back new messages, the system announces, "You have no new message." If you pause for more than four seconds during remote access, you hear a help menu listing all features and commands. If there is no command for another 20 seconds, the call ends automatically. If the memory is full, the answering system answers after 10 rings and announces, "Memory is full. Enter the remote access code." Enter your remote access code to access the messages and announcements. When the answering system is turned off, the telephone answers after 10 rings and announces, "Please enter your remote access code."
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
My laptop is unable to shom my home screen icon or anything about inter the passsword
try performing a system restore to revert back to the correctly working settings, to do that follow the instructions below:
1. Click Start, type system restore in the Start Search box, and then click System Restore in the Programs list.If you are prompted for an administrator password or confirmation, type your password or click Continue.
2. In the System Restore dialog box, click Choose a different restore point, and then click Next.
3. In the list of restore points, click a restore point that was created before you began to experience the issue, and then click Next.
4. Click Finish.
hope this will help.. good luck
Jun 17, 2012 | Computers & Internet
What does attribute not found mean referring to my emails I can't view them please help????
Hello Benjamin,
I came across a very similar problem yesterday.
The problem might be a photo or video attached to the e-mail.
Try to look at the same e-mail on your computer.
If the email is readable (text and image) then at least you know the probable reason for the "attribute not found" message.
Print a copy of the e-mail with the text and image and take it to the shop where you bought your cell phone. (It is easier to explain a problem when you have an example on paper to show the salesperson).
Shom them the problem when trying to read the *same* e-mail on youe cell phone.
- If you are lucky, they will change a parameter in your cell phone server so that images are visible.
- If you are unlucky, you will be told "noy my problem" and you will have to put up with the annoying problem.
To limited knowledge, there is nothing a user can do to fix this problem on his own.
Dec 13, 2011 | HTC Cell Phones
How to format my nokia 5800 music express mobile phone ?
1) Power off your phone.
2) Press and keep presses, the following buttons:
Green
Red
Camera
3) Then, while keeping those buttons pressed, press the power button.
4) Wait for the shaking nokia hands, and release the Green, Red and Camera buttons.
New lock code is 12345
All data is deleted. Settings are reset to factory default.
Jun 29, 2011 | Nokia 5800 XpressMusic Smartphone
How to reset voice record on my panasonic KXTG9331T?
Greeting message
When the unit answers a call, callers are
greeted by a greeting message. You can
record your own greeting message or
use a pre-recorded greeting message.
Recording your greeting
message
You can record your own greeting
message (2 minutes max.).
1 {GREETING REC}
2 Within 10 seconds, press
{GREETING REC} again.
3 After the base unit beeps, speak
clearly about 20 cm (8 inches) away
from the MIC.
4 Press {?} (STOP) to stop recording.
Using a pre-recorded greeting
message
If you erase or do not record your own
greeting message, the unit plays a prerecorded
greeting message for callers
and asks them to leave messages. If the
message recording time (page 39) is set
to “Greeting only”, caller messages
are not recorded and the unit plays a
different pre-recorded greeting message
asking callers to call again.
Playing back the greeting
message
Press {GREETING CHECK}.
Erasing your greeting
message
If you erase your own greeting message,
the unit plays a pre-recorded greeting
message for callers.
Press {GREETING CHECK}, and then
press {ERASE} while your greeting
message is playing.
Listening to messages
using the base unit
When new messages have been
recorded, the message indicator on the
base unit flashes.
Press {6}.
L If new messages have been recorded,
the base unit plays back new
messages.
L If there are no new messages, the
base unit plays back all messages.
Operating the answering
system
Key Operation
{^} or {V} Adjust the speaker
volume
{7} Repeat message
(during playback)*1
{8} Skip message
(during playback)
(STOP)
Pause message
– To resume playback,
press {6}.
– To stop playback
completely, press
{?} (STOP) again.
{ERASE} Erase currently playing
message
*1 If pressed within the first 5 seconds of
a message, the previous message is
played.
check if this works and tell me if any issues
Apr 30, 2010 | Panasonic KX-TG1033S Cordless Phone
Nokia E66 Incoming name or number of callers not
It's because the caller using voip (ie Skype or similar with hidden id)
Jun 04, 2009 | Nokia E66 Smartphone
How can i delete messages on my BT Studio 1500?
go into menu, go to "play message", scroll down to "all messages" press the tick button, when the messages play press X (secrecy) button.
you have to delete them one by one
hope this helps
Jan 11, 2009 | Xact Communication XG2200 Cordless Phone
Delete messages
This is from the manual.
Erasing Messages
You may erase messages in the following three ways:
To erase a message while it is playing
1. Press and release PLAY/STOP button.
2. Press the review and skip buttons to select and play the message you want to erase.
3. Press the delete button, the current message is erased, and the next message plays.
To erase all previously played Messages in a mailbox
1. Make sure the phone is OFF (not in talk mode)
2. Press and hold the delete button until "ALL OLD MESSAGES ERASED" is announced.
To erase a message from the handset :
1. Press the flash/answerer button on the handset
2. Press the play/stop (key 2) on the handset.
3. Press the erase (key 0) on the handset to erase a message during playback.
NOTE: Erased messages cannot be restored.
Jan 08, 2009 | GE 28112 Trio Cordless Phone
Zynga Texas HoldEm Poker Logo
Top Zynga Facebook Apps Experts
 Grubhead
Grubhead
Are you a Zynga Facebook App Expert? Answer questions, earn points and help others
