Question about Refrigerators
Wirlpool fridge icemaker over flows, never stops running, must shut off water to stop the flow. replaced the dual water valves and still the same.
The fridge is a 2011 model and I was told it was new when we moved in the house, the water supply to the fridge was never hooked up. Once the water was hooked up water poured out on the floor through the door where the ice should come out. tried to adjust the ice size and that did not help. replaced the inlet water valves on the fridge and still the same. With the icemaker unplugged and removed, so that I could at least use the water outlet on the front of the fridge for drinking water, water still tries to flow to the icemaker non-stop.....I would think with the ice maker unplugged it would not call for water?
3 Suggested Answers
SOURCE: icemaker
I put a meter to the ice maker and got a 118.5 reading so it is good. I did not get the spitting you were talking about. The plastic screw broke when I turned it counter-clockwise. When I turned it clockwise it just raised the lever that tells you when the tray is full (it was already set as far clockwise as it would go). When I turned it counter-clockwise it turned a little and then the two plastic prongs broke off. I can't believe that is what they are made of. I was gentle with it and they still broke. No wonder everybody is sick of American products. Luckily I saved my old ice maker and swithced out the face plate (for lack of a better term). The water lines are clear. If I take the line off the back of the freezer, water will shoot out but it does seem like my problem is getting enough water and I am out of ideas. Thanks for your help. I'll take any other suggestions you might have.
Posted on Apr 30, 2007
richroth
  • 9472 Answers
SOURCE: Water flows into ice maker when water lever is pushed
Be sure that you have the water inlet valve wired correctly.
Posted on Nov 26, 2012
Ice maker won't stop filling. Makes a little ice, but water is almost constant into the maker
The water control valve is shot. It's not making ice because there is a constant flow of water into the ice tray. Shut the water off at the feed point for the fridge for now. If the drain gets plugged you're going to have a small catastrophe on your hands.
Here's a procedure to test it to be sure:
How to Test Fridge Icemaker Water Inlet Valve Refrigerator Repair
Mar 20, 2016 | Kitchen Appliances - Others
I used the water dispenser and when done it wouldn't shut off. This is an inside of the unit dispenser. How do you fix this?
Your unit has a inlet valve that the supply of water flows to..This valve splits between allowing water to either the dispenser or the icemaker..This valve may be sticking open allowing water to keep flowing to dispenser..Google Model # w/problem to find location and part#..or call your local appliance repair company
Jan 04, 2018 | Samsung RF266AEPN Refrigeration :...
Water dispenser doesn't work
Replace the water valve on the refrigerator. The valve solenoid is stuck open causing water to flow freely. This should fix both issues with icemaker fill tube freezing and water dispensing.
May 05, 2017 | Whirlpool ED5SHAXM Side by Side...
Maytag MFD2560HES - water flow restricted - noisy fridge
The flow of water is controlled by a solenoid. Thus magnetic -- rather electromagnet which mones the vale from open & close, both in the ice-maker & the water dispenser.
Thus the valve which is activated when door closes, must have lost its earlier condition and must be making an irritable buzz whenever its on. Simply get the Valve assembly replaced, preferably from their authorized service center closest to your place of residence.
Sep 25, 2009 | Maytag MFD2560HES Bottom Freezer French...
WATER DISPENSER NOT WORKING
It might be that you have a restriction at the water supply line serving the fridge. Check it for good flow (have bucket and towels handy!) If supply line is good, then move onto the fridge to check the water inlet valve(s). as newer models have 2 or 3 inlet valves, a main water valve for the entire unit, and possibly one each for the ice maker and water dispenser past the main inlet valve (solinoid).
You can check these by simply shutting off the main supply to the fridge from the house water line 1st, and then removing each water line from the supply side of the fridge and seeing if you have water flow from the house to the valve side. If you do, then reconnect the lines to the fridge valves and see if you can get water flowing to the other side of the solinoid/valve when you have someone try to get a glass of water from the water dispenser, etc.
It is possible that there is an obstruction in the lines, by not very likely. Normally it is a failed water valve(s) (solinoid) that causes low flow or complete loss of flow, especially if you've changed the fridge water filter or replaced it with the "cap" which eliminates filtering of the water.
It is that you'll likely have to replace at least one, maybe more, of the fridge inlet water valves. If you have the time, try to zero in on the failed one by bypassing each, one at a time, until you get water flow. That way, you'll only have to purchase just the replacement valve needed to get things working again.
Jul 07, 2009 | GE GSH25JFR Side by Side Refrigerator
Water flowing to the icemaker would not stop. It over flowed the
sounds like the water switch is stuckopen or the valve is. Is the water going to the icemaker or thru the door. If the icemaker is overflowing and doesnt shut off then unplug unit,still coming in change the valve. Not coming in then look at the switch.
Jun 10, 2009 | Kenmore 53542 / 53544 Side by Side...
Kitchenaid fridge (ksrw25crss02)icemaker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispencer.
hi kev215,
welcome to fixya.com.
Huuum at your service.
You said, the ice maker slowly stopped working, decreasing in the amount of ice it made until finally no ice at all. also, water trickles from water dispenser.
The first thing I would ask is when did you last change your water filter in the fridge?
Or if it's an older fridge with an inline filter behind the fridge!
check the shut off valve for the water line that leads to you ice maker. under the sink or in the basement or where ever the line comes from. I've seen where someone turned the valve a little clockwise unbeknown to the home owner and stopped or slowed the water flow.
The water line should be checked too, for any kinking that may be running behind the fridge or some unseen place!
How old is the fridge??
Let me know,
Thank you Huuum
Sep 23, 2008 | KitchenAid Refrigerators
Ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Mar 28, 2008 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
