Question about Lenovo Computers & Internet
Snowy screen on my lenovo
After I shut down and then open it and push start I get a snowy screen. I have to pull the power cord and re-attach and then I get the normal screen and cam move on. It has not happened during working on computer... it is just if I set it down and it goes to sleep or at start up.
  • Lenovo Master
  • 5,660 Answers
You have the 'snowy screen' option enabled. If you press the Fn key down, and tap on the S and C key, Santa Claus will dance across the screen............
WHAT? !O_O!
You gonna' believe that? lol!
You need to diagnose. However the problem is a loose connection of Video Cable.
Loose at motherboard side, or LCD screen side. Could be Video Cable is damaged also. (Stretched/Broken wires)
What is the model number? It's on the bottom of the laptop. I should be able to get you the link to the HMM. (Free) (Hardware Maintenance Manual)
Then if you wish I can step by step guide you, through the diagnostic procedures, and disassembly required to access both connections, of Video Cable.
Also can guide diagnosing through a diagnostic flowchart
Post back in a Comment
Regards, joecoolvette
Posted on Apr 21, 2013
  • 324 Answers
SOURCE: Viao PCG-GRX650 won't shut down fully
DaveBaker,
Here are a couple of tips that I've collected that may address your problem.
Go to start>run>then type in "cmd" without the quotes. this will bring up the command prompt. next type in the following command: "shutdown -s" without the quotes again. This should tell your system to shutdown your computer entirely.
Next
Try doing this. Hold down "ctrl" and left click "shutdown". This skips some windows XP shutdown procedure and should do the trick.
And, finally
http://support.microsoft.com/?kbid=831431
You cannot log off, restart, or shut down your Windows XP-based computer This article talks about an issue with Norton 2003 incompatibility.
Would appreciate any feedback as to which of these worked for you.
Thanks much!
Ron-
Posted on Nov 10, 2007
SOURCE: my compaq presario v5000 shut down and wont restart
My Presario v5000 is doing the same as above. Except, I let it cool for a little while and it turned on. Now it only turns off after a while. I'm not to sure exactly why that is but i could possibly be an over heating automatic shutdown procedure.
Posted on May 12, 2008
kikoksky
  • 119 Answers
SOURCE: laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Posted on Jun 13, 2008
  • 50 Answers
SOURCE: HP ZD 8215 Laptop Start-up Problem.
2 beeps with no post means either you have a memory failure or the motherboard has failed
Posted on Jul 17, 2008
vincent721
  • 240 Answers
SOURCE: my compaq presario c500 doesn't respond to the start button
try to turn on the laptop without the battery and only the power cord plug in.
if your laptop works with this you need new battery or update bios ( there might be fix for battery monitor)
if not, call service support, might be motherboard issue
let me know an update
Posted on Apr 03, 2009
Lenovo r61i has just started to shut down if I try to run it with the power supply attached. When I run the computer on the battery only it does now shut down until the barrry runs out of juice. Why?
If you are running Windows 7 or 8 there is a power setting that you can change to tell it when to shut down the screen or go to sleep. Click on the power icon in the lower right task bar. You will see something like power settings. Also you will see when to shut down the screen, for both battery an electric. You can make changes there an fix problem. I just did this a week ago an fixed the same problem.
Jan 27, 2016 | Lenovo Computers & Internet
Laptop will not shut down
push power button 40 sec and You wil shut down your Lenovo.
Jul 20, 2014 | Lenovo ThinkPad Computers & Internet
Why does my Lenovo cant start up windows.
Try to perform full restart, press power button down until computer shuts down (+5 seconds). Then try to restart it. If repair function is offered, do not select that, select "start up windows normally".
Apr 24, 2014 | Computers & Internet
When laptop charging in off position and if i connect usb pen drive, ext. HDD, etc. these are on and flashing
Is the laptop off or Hibernating? Sleeping? Open the Control Panel, Power Options, Set to High Performance, open Advanced Power settings, set Hibernate and Sleep to Never. Shut down the laptop at the Start Menu. If the AC cord is plugged in the battery will charge. Nothing else should work.
Jan 16, 2013 | Lenovo 3000 C200 CM 520 1.6G 512MB...
Easynote tj74 wont turn on
Your not getting power? When you plug the laptop in does the Battery charge light come on? Are you getting power to the laptop? Do you have a multimeter to verify voltage from th AC outlet to the AC jack? Or ,the power gets to the laptop and push the on/off button you get no response? Or, you push the on/off button and the laptop starts then shut down? No lights, no leds blink. Remove battery, Try another cord/charger. Has it been dropped or damaged that would jar loose a connection, or pulled by the cord resulting in a damaged AC jack?
Nov 19, 2012 | Computers & Internet
MY LENOVO LAPTOP WONT SHUT DOWN
push and hold down the power button.then unplug power cord and remove battery.wait a few min then but battery back and plug it in and restart..
Mar 24, 2012 | Lenovo G530, G550, G560...
My lenovo T400 will not shut down even when all applications are closed. I have to manually shut it down with the power button
Hi guest, try to turn off the pc by using the power button. Then remove the cables and battery on the laptop. Then push & hold the power button for 5 seconds. Reinsert the cables and battery then turn on the pc.
Check if you will be able to shut down your pc using the operating system..
May 15, 2010 | Lenovo ThinkPad T400 PC Notebook
HP won't start - pushing the button and nothing happens...
first thing first, may you have a multitester on you, chick the power cord on replace the power cord , chick the power supply and open it and chick the fuse it might be cut, replace the fuse. and if does not work then replace the power suplly with the same specification.
Nov 05, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Satellite screen is blank & won't shut down
Don't know why the screen is blank. Toggle the F9 key to make sure you didn't accidentally toogle off the screen.
As far as turning off the power and shutting down the computer, the old stand-by is to take out the battery and then pull the plug. The computer will power down. Replace the battery, replace the plug and then push the start button. You may have to start it up in SAFE mode since the shut down process was not the "normal' process the computer expects to follow.
Dec 13, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
122 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
