Question about Bosch 1587AVSK 5.0 - AMP Top Handle Jig Saw with Case
How do I remove a broken blade from a BOSCH 1587 Jig Saw
I can not turn the broken blade sideways to remove it with needle nose pliers even after turning the release knob on the top of the handle multiple times clockwise. Upward pressure does not help.
5 Suggested Answers
  • 3 Answers
SOURCE: blade wont stay in Bosch 1882VS jig saw
From your description I cannot say for certain, but it sounds as though you are not locking the blade correctly, or the blade lock mechanism is broken. You can tell if the blade-lock is working by clicking it. It should make an audible "click" that you can feel. Also, you can pull on the blade ( with the saw UN-plugged of course!) and feel if it is properly seated. If you are operating the blade-lock according to the instructions and it still doesn't lock positively, see a service center before you use the tool again. A broken blade-lock could be dangerous.
Posted on Apr 10, 2009
rowdy45176
  • 2176 Answers
SOURCE: after changing the blade on a bosch 1587VS jig saw
I would recheck the installation of the blade and the tightness. If still a problem there is a spring under the lever that might have broke (they tend to do that) and is jamming the spindle. Let me know and I will help you with the breakdown for this tool
Posted on Jul 26, 2009
rowdy45176
  • 2176 Answers
SOURCE: change blade 1587 Bosch avs
are you using the "T" shank blades and also are you loosening the spindle enough to allow the blade to turn, sometimes you have to push up a little to turn it and also pull away from the roller guide. Let me know and also there is a TINY spring in the top of the spindle that has a nasty habit of breaking and winding around itself not allowing proper operation.
Posted on Oct 10, 2009
puertobori
  • 7733 Answers
SOURCE: I have a bosch 1587 vs jig saw i got used. I
In most models at the blade shuck holder is a screw that thigh the blade,unscrew it and change your new balde .
Also Go to this LINK and find the part/diagram that can help you.
Please thumbs back if help is fine,thanks!.
Posted on Nov 04, 2010
The Blade broke off and cannot get it out by running it
Hi Ron:
Here's what I would do;
- UNPLUG THE SAW
- Use a screwdriver or needle nose pliers to get the broken bit out while holding the retaining clip in the release position.
Sep 03, 2015 | Bosch RS15 1 1/4 Reciprocating Saw
Extracting broken blade not sticking out of blade holder
Spray with WD 40 and insert Needle nosed pliers to grab and pull it.
Nov 30, 2013 | Ryobi Js550l Jig Saws
How do you change a blade in the Bosch Jig Saw Model 1587 AVS
Pull the black knob on the top front of the handle up and turn it clockwise to tighten and counterclockwise to loosen. I'd turn it counter clockwise at forst just to make sure it's loose enough to accept the blade when you start.
Sep 01, 2011 | Skil 1587AVSK - Bosch Jig Saws Power Tools
I have a bosch 1587 vs jig saw i got used. I don't know how to install a blade. I have never had one like this. I turned the top handle the way the diagram showed but I don't think something is working.
Nov 02, 2010 | Bosch 1587avsp Vs Orbital Jigsaw
I want to remove the blade (Jig Saw 1587 AVS
there should be a botton or thumb press undernith up frount unplug and depress and blade will come out
Apr 09, 2010 | Bosch 1587AVSK 5.0 - AMP Top Handle Jig...
Change blade 1587 Bosch avs
Oct 06, 2009 | Bosch Saws
Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Jul 28, 2009 | Bosch 1581AVSK Top Handle Jig Saw Kit
Blade won't stay in jigsaw
It sounds like you need to replace the shaft.
Feb 22, 2009 | Bosch Saws
BOSCH: 1581 VS... BROKEN BLASDE HOW TO REPLACE WITH NEW BLADE
hi there is a hole on the top of the handle at the front when holding it it is just in front of your hand you need a long series flat head screwdriver to loosen turn the blade sideways and out she comes
hope this helps glenn...........
Nov 09, 2008 | Saws
Bosch 1587AVSK 5.0 - AMP Top Handle Jig Saw with Case Logo
57 people viewed this question
Top Bosch Saws Experts
Tim Venetis
Craig Butler
Craig Butler
Are you a Bosch Saw Expert? Answer questions, earn points and help others
