Question about Bobcat Garden
Bobcat ransome shuts off when engage blades
Runs but when I engage the blades it cuts off
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 975 Answers
You have a bad safety switch somewhere marty. there are videos on you tube that show how to test them.
Posted on Dec 18, 2016
SOURCE: Craftsman 18.5 briggs/str 42''won't cut
It sounds to me like a very loose belt or very worn out belt and also an adjustment problem.
Posted on Mar 24, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
SOURCE: Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
Posted on May 15, 2009
SOURCE: I have a 15.5 HP Sears Craftsman 42
I'm betting that you need a new safety kill switch - probably the one underneath the seat (the spring-loaded plunger switch that won't let you use the machine without your *** in the seat). Could also be the one behind the "dash" that is associated with the blade engagement mechanism.
I know that the under-seat-switch cannot be bypassed or it will disable the machine in the exact way that you described. Why do I say this? Because I just tried to bypass my own "***-in-the-seat-safety-switch" on my very own 15.5 HP, 42" Sears tractor, and it responded by punishing me - the absense of the switch caused the motor to cut out when I tried to put the machine in gear AND/OR engage the blade. It seems to have some measured capacitance - the absense of same seeming to interrupt the ignition timing enough to shut the motor down when you attempt to get anywhere past neutral or engage the blade. These "safety" switches may be needed by a very few who prefer to be drunk while they mow lawns on steep slopes that their tractor mowers were not designed for, but I find these items to be troublesome and enfuriating. My trees shed a lot of sticks in high winds, and I can't stand shutting the machine down and restarting it EVERY SINGLE TIME I have to dismount to clear sticks or other obstructions out of my mowing path. This is an obnoxious, "nanny-design" feature that desparately needs to be discontinued. It also makes both jump-starting the tractor and electrical troubleshooting much more difficult than they should be. The tractor should let you dismount without shutting down, as long as you have disengaged the blade and shifted into neutral. It should also let you jump start with jumper cables - impossible to do with your rear end in the seat. By the way, call Manufacturer's Supply, Inc. at 1-800-826-8563. They may have a replacement - their item number 31-9664 might do it, but talk to them first. I'm calling them tomorrow. Good luck.
Posted on May 17, 2010
Testimonial: "VERY THOROUGH - THANKS"
mastermaid
  • 502 Answers
SOURCE: nedd manual for bobcat/ransome T3100
Ask here, they will find every Bobcat manual
Posted on Mar 06, 2011
Mowers shuts off when I engage the pto switch, I jumped all of the safety switches,put new pto switch on, belt and pulleys are fine! Please help
Craftsman Garden Tractor 917.28746 Engine shuts off when ...
www.shopyourway.com > Manage My Life > Questions
Craftsman Garden Tractor 917.28746 Engine shuts off when engaging mower deck. 917.28746 ... Then start the tractor and pull the pto button out. If the engine ...
Why does my engine die when the blade is engaged ... - iFixit
https://www.ifixit.com/.../Why+does+my+engine+die+when+the+bl...
iFixitI have an older Murray riding lawn mower, whenever I engage the mower the engine dies, otherwise it runs .... My dr feild brush mower ... cuts off when I engage theblades. ... My Huskee only shut off once I put it in drive with the blade engage.
Riding Lawn Mower Problem - Dies when PTO engaged - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Apr 28, 2008 - When I pull the switch to engage the PTO, the engine bogs down real ...off I can keep the engine running with the mower engaged then it is fine ... Riding mower cuts out
May 18, 2010
mower dies when I let off the clutch
Sep 19, 2008
pto on Cub Cadet will not stay engaged...
Apr 6, 2008
Craftsman Mower deck (clutch) Won't engage
Jul 1, 2006
More results from forums2.gardenweb.com
Dec 29, 2015 | Garden
While I was cutting grass the Engine shut down. Pulled the brake up. Push the PTO back down to shut the blades down. I started the engine, engine runs perfect.
try replacing the battery most with an electric clutch PTO have to have a really strong battery as the alternator system is not strong enough by itself
Jun 16, 2015 | Garden
Engine shuts down when cutting deck engaged
This is probably due to a misadjusted or faulty safety switch on the rider's seat. There is a deadman switch there that will shut down the mower if the rider gets off the seat with the blades engaged.
Mar 06, 2015 | Garden
Why does my rover rancher stall when i go to engage the cutting deck
1>the pressure switch under the seat may be malfunctioning? (it will cause the engine to die immediately when trying to engage the cutting blades because it thinks your not sitting in the seat.
2>dirty or clogged air cleaner element will cause engine to die when engaging cutting blades. This can be tested very easily by removing the air cleaner element and then trying to engage the blades again. If this works then replace air cleaner element immediately before running the engine anymore.
I have personally experienced both of these problems myself more that once.
Feb 17, 2015 | Garden
How do i replace cutting blades on bobcat ransomes 36 walk behind mower
Often, you can find manuals on line. Just Google using make model information. Search for a user's manual.
Oct 02, 2014 | Garden
Ransome mower
Sounds like the engine is running too lean, not getting enough fuel under load. Needs a good carb cleaning, fuel filter. Don't know about the engine, if it has idle and high speed adjustments . May need to be adjusted.
May 20, 2014 | Garden
Ransom's bobcat ztr wont engage forward or reverse? Belt or hydraulics?
Check you hyd. engage and disconnect pin. Check belt may be slipping.
Mar 01, 2014 | Garden
Toro 20056 engine runs but the cutting blade does not engage
you have a Toro and for whatever reason it is listed in the flat panel TV area.
Aug 29, 2012 | Televison & Video
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Garden Logo
348 people viewed this question
Top Bobcat Garden Experts
Daryl Gleaton
Dan Apthorp
Tom Chichester
Are you a Bobcat Garden Expert? Answer questions, earn points and help others
