Question about Nikon D5100 Digital Camera
How to format sd card in nikon d5100 - Nikon D5100 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
Press the MENU button. Press cursor-left. Use cursor-up/down to select the wrench icon. Press cursor-right, then use cursor-up/down to select the "Format" command.
Posted on Apr 21, 2013
likha
  • 790 Answers
SOURCE: DSLR - Camera stuck in formatting mode
Hi!
if you want use the 4G you make sure your memory cards is compatible to 4G. then now you have got stuck when you back the 512!? all you have to do is to reformat your camera in to software. Thanks!!!
Posted on Nov 02, 2007
Steve5
  • 423 Answers
SOURCE: SD Card in Nikon F10 not recognised by XP
It could be one of two problems. The most likely is that the card reader you are using cannot read SDHC cards, of which all 4GB and larger cards are. Try using the camera's cable to download to your computer directly to the USB port. I bet you'll find that it works that way. The other problem could be (but not likely) that you are shooting on the RAW file format, instead of the jpeg file format. Most software cannot recognize RAW files, but jpeg is pretty universal.
Posted on Mar 19, 2009
praky16
  • 744 Answers
SOURCE: nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Posted on Jul 22, 2009
  • 102366 Answers
SOURCE: Nikon Coolpix L11 Memory Card Error
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Mar 09, 2010
  • 102366 Answers
SOURCE: Nikon Camera does not accept any memory card
Try formatting the card in the camera, not the computer.
Posted on Jun 03, 2010
Nikon coolpix s630 shows memory contains no images no sd card in it
That is what you get when the camera memory has no images. And the SD card is missing. This does not seem to be a problem. The tool menu will let you format a new SD card.
May 05, 2017 | Nikon Cameras
Trying to transfer photos to computor, hit transfer and it comes up Failed to initialize pluto. Don't know what to do.
You didn't say what software you are using, but there are better ways to download your photos. The best way is to connect your SD flash memory card to the computer. If your computer has a SD card slot you are in luck. If not, you can buy a USB SD reader for under $20 on line or in any computer store.
To use it, remove the SD card from your camera and insert it in the reader. Your computer will automatically recognize the SD card as an external memory device; exactly as it does with an external hard drive. You can then open the SD card and access the folder with your pictures. All you need to do is copy and paste your photos from the SD card to a new folder on your computer. It's that simple. Almost all professional photographers use this method and do not transfer pictures from the camera with the SD card in the camera.
Aug 17, 2015 | Nikon D5100 Digital Camera
On my nikon D 5100 an error code appears when i try to take a picture. It states " err40F5" what is this error! ? Tha ks,
Change the SD Card, because it might be corrupted or writing speed was not enough.
For Nikon D5100, it is recommended to use SD HC Class 10 card.
Dec 30, 2013 | Photography
Erase card photos
To erase all photos on the memory card format the card. You'll find the format command in the Setup menu.
Apr 11, 2013 | Nikon D5100 Digital Camera with 1855mm...
Can not locate write-protect switch
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Mar 12, 2013 | Nikon D5100 Digital Camera
My nikon memory card is locked how to unlock it ?
Apr 21, 2012 | Nikon D5100 Digital Camera with 1855mm...
Nikon 5100 - sd card is not recognized occasionally
Go on the Nikon site and get the firmware update, I had the same problem after I tryed to use 16G card.
Dec 20, 2011 | Nikon D5100 Digital Camera
Sd card won't click into place on my Nikon d60
Check your SD card, there may be a piece of it missing. Did the same to my camera and looking into the card holder, there was a piece of SD card lying at th bottom! (I used a needle to dislodge it!)
Mar 11, 2009 | Nikon D60 Digital Camera
Nikon D5100 Digital Camera Logo
155 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
