Relays are located in the "under hood relay/fuse panel" on the passenger side between the radiator overflow and the battery. Remove the lid and on the underside of the lid you will find the diagram. The fuel pump relay will be indicated by a graphic of a fuel filling station pump. The relay itself is yellow. Also check the pump fuse, located in the same relay box and if needed check your inertia cutoff switch located in the passenger footewell. There is a panel to the right just under the glove box. It has a popout access door but its much easier to remover this small panel and providing clear access to the switch. Push down on the rubber cover on top of the switch. If it is engaged you are ok here. If when you push down you hear a click then the inertia cutoff was switched somehow and this cuts fuel supply. These switches have plastic internal parts and dont take much to fail. Hope this helps. Happy to provide further suggestions if you wish to repost more info. Good luck!
SOURCE: location of the fuel filter P38 4.6 Range Rover 1999
The last one of these I saw the filter was in the tank.This is after checking the manual that said it was in the RH rear wheel arch.
SOURCE: Fuel pump relay switch and shut off location
There is a safety switch that can be reset under the hood on the passenger side under the fuse box panel.
SOURCE: where is the fuel filter for 04 range rover
Hi. The filter will be mounted underneath the vehicle. you will need to raise the vehicle, and support it carefully. Once raised, you will be able to locate the filter. It will be just to the right or left side of the fuel tank, mounted on a bracket, in between the fuel line. be sure to disconnect the negative battery post cable, and relive the fuel pressure, before removing the fuel lines form the filter.
Click here to view a picture of your filter.
Testimonial: "thank you very much "
SOURCE: 2001 land rover discovery II locate fuel filter and fuel pump
If you're standing looking at the rear of the vehicle, it's on the chassis rail on the right hand side rear wheel arch.
for Land Rover Discovery 1999-2004 no more external Fuel Filter serviceable anymore...it's a built-in part with the fuel pump. so if you want to change the filter then change the whole fuel PUMP.
