Question about GE PP950SMSS
Need calibration procedures for my ge cooktop pp950
Tried the calibration procedure that came with the FL large element that I needed to replace, but these procedures will not do what the included instructions tell me to do. It goes into a CAL 1 mode. Is there another calibration procedure I don't know about?
  • Fred Apr 23, 2013
    Trying to explain differently, is there another calibration procedure other then the one that comes with the replacement element? I follow the procedure and it will tell me TECH MODE will flash, it doesn't, CAL 1 does. I don't know what to do from there. Any suggestions?
  • Fred Apr 23, 2013
    I am doing the calibration after I have replaced the original (F161 code) with a GE part and the calibration method was within the box
Fred,
Did you get an answer? Having the same problem!
Thanks!
Posted on Apr 15, 2015
  • 161 Answers
SOURCE: GE Cooktop JP930 surface element not working
It sounds like the burner needs to be replaced. When they burn out sometimes they short out to ground. The cooktop will have to be removed from the counter and the glass top opened. You will probably be able to see where the element is burned out. Replace it and you should be fine. If it is too expensive to fix just disconnect the wires to the burner where they attach to the control . Then you can use the remaining burners. I really don't know what a replacement burner costs. An open coil is around $30.
Posted on Jul 15, 2008
Eddie Rentas
  • 59 Answers
SOURCE: ge jp340 radiant cooktop
Hello
I have the manual for your stove in PDF format, I will gladly email it to you.
Eddie Rentas
Tupper Lake NY
Posted on Jul 19, 2008
SOURCE: Right front (large) burner indicates hot, won't work, flashes F153
I hade a code 153 also. Changed the element(costly-$200) and had to recalibrate the pan sensors(in the manual). All works fine now.
Posted on May 29, 2009
Controlfrk
  • 304 Answers
SOURCE: Burner only cooks on high heat.
You need the switch for that burner. The contacts inside are stuck together. You will need to pull the unit and separate the glass from the lower body to access it. To get the right switch you need full model and serial number located on a plate at the bottom of the unit.
Your ability to perform this is dependent on how mechanical you are. The Whole unit must be removed from the counter opening and the base unscrewed from the glass, remove knobs before disassembling. For someone mechanical this is not difficult. De-energize whole unit first.
Once the two pieces are separated the remainder is mechanically easier. Disassemble the box on right containing the switches and replace the correct one. Reverse the process for reassembly. Good Luck
Posted on Aug 31, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Cooktop drop-in model # jgp328bec2bb - how to
Turn off the gas,unplug the power.
Take the cooktop out of the cutout and support it on the countertop.
Remove all grates and valve knobs.
Remove all screws from the valves and the burners.
Remove the burner base plates.
You may have screw on the side holding the top to the base,if so,remove these too.
The top will separate from the bottom exposing your parts.
Posted on Feb 11, 2010
1960 ge cooktop element replacement
Your are not quite specific about what kind of a cooktoop ypu want to replace:
DIY How To Replace Gas Cooktop
Whirlpool Cooktop Broken Glass Replacement Model RCC3024
ge electric glass cooktop board glass replacement
Cooktop Main Top Replacement GE Electric Cooktop Repair Part WB62X10047
You can search for more using these terms with COOGLE
Youtube Replace GE cooktop
Sep 24, 2015 | GE Cooktops
Right Front Burner shuts off after 30 seconds. Fault code f153 flashes. I have reset the circuit. Same issue occurs. Any advice?
x9009 Hello and sorry to hear about your problem.
You have a open heat sensor, one 1 of your heating elements.
I suggest you contact a service company for repairs.
I tried to help you, Please help me by vote/rate my response.
Thanks and good luck.
If you live in the Denver Co area, I can help you out
Dec 22, 2010 | GE 30 in. Profile JP939 Electric Cooktop
Large element stopped working/that hot surface light stays on
I have the same problem with mine. Do you have any answer yet?
Jul 20, 2010 | GE 30 in. Profile JP938SCSS Electric...
I wasn't supplied with a manual. Need to know amperage
should be sticker on underside of unit to give you this info
Aug 08, 2009 | General Electric 30 in. Profile PP950...
May 21, 2009 | GE Cooktops
Jul 13, 2008 | GE Profile JP930 Electric Cooktop
Electric cooktop burner malfunction
The outer ring of the element is most likely broken. You'll need to replace the element.
Apr 06, 2008 | Cooktops
Problem with large surface unit
The element is bad. On some models the elements have a 5 yr warranty. Check your owners manual.
Sep 26, 2007 | GE 36 in. Profile JP960SCSS Electric...
GE PP950SMSS Logo
183 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
