Question about Acer Aspire 5500 5570-2609 Laptop
How to recover apache?
I want to use Easyphp but at the beginning after installation it works but if i shut down my computer and i try to start easyphp again it cannot start what i see is message saying Apache is stop mysql is stop and i cannot do any thing and i cannot also access data base i created befor
  • 432 Answers
This page may help you out. http://www.easyphp.org/introduction.php
For my server, I use http://www.php.net/downloads.php. It works well without any problems.
In your Apache httpd.conf file add this script at the very end:
</IfModule>
#load the php main library to avoid dll mistakes
Loadfile "C:\Program Files\php5ts.dll"
#load the sapi so that apache can use php
LoadModule php5_module "C:\Program Files\php5apache2_2.dll"
#set the php.ini location so that you don't have to waste time guessing where it is
PHPIniDir "C:\Program Files\"
#Hook the php file extensions, notice that Addtype is NOT USED, since it isn't needed
AddHandler application/x-httpd-php .php
AddHandler application/x-httpd-php-source .phps
Posted on Mar 13, 2009
At startup windows narator give error 0xc000007b
If you have installed a network card, uninstall any software you installed for it, then shut down your PC. Uninstall the network device you are having trouble with and boot your computer into safe mode (Power up the computer and IMMEDIATELY begin to tap the F8 key SLOWLY about ONCE PER SECOND until you see a menu, then STOP. Use arrow keys to select safe mode then press enter) to see if it will start correctly. If windows starts in safe mode, the reboot. If windows starts normally, there may be a problem with the driver software (download new drivers) or the card itself is bad, and windows chokes on it. You may wish to try and install it again, but that is your call. I would try a different adapter.
Sep 16, 2013 | Acer Computers & Internet
Acer Aspire 5002WLMi PC Notebook Laptop shuts down automatically
  • Start tapping the F8 key. The Windows Advanced Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected.
  • Press Enter. The computer then begins to start in Safe mode.
  • When you are finished with all troubleshooting2_bing.gif, close all programs and restart the computer as you normally would.
If this does not work you will probly have to go back to factory settings
May 13, 2010 | Acer Aspire 5002WLMi Notebook
HP 520 Notebook. Shuts down before installing new OS.
I agree a clean install is always the better, fresh start J
OK it sounds like missing drivers, what you have to do is create a new installation CD that will load the drivers for your laptop as it boots. I haven’t try this method with windows 7, but I know it works well with Windows XP. Try and create a new Windows XP CD with the drivers see: http://unattended.msfn.org/unattended.xp/view/web/35/
The start a new installation with this Windows XP CD and reformat you computer, after that you can do a new upgrade to windows 7
Nov 25, 2009 | Office Equipment & Supplies
Laptop wont switch on fully
Did you press F8 as you boot up to get boot up options and did try the Last Known good Configuration and Safe Mode?
If these didn't work I suggest you re-install Windows.
Apr 10, 2009 | Acer Computers & Internet
Compputer shuts down abruptly
If you have recently fitted new hardware. Take it out.
If not, buy a power surge protector from your local pc store
Jan 30, 2009 | 2005 Mercury Villager
Alienware Aurora desktop crashes on bootup
try to change the cooling fan mayhbe its the problem that your proccessor is over heated.
Dec 25, 2008 | Alienware PC Systems Alienware Aurora High...
Cann't shut down properly
If you are trying to shut down with the camera still connected!!??GOTO the bottom right of screen and ""safely remove hardware"" see if the system will shut down.....sometimes a hardware driver does not want to shut down so you must turn it off and plug it in again when you start windows again....
Nov 28, 2008 | Sony VAIO PCV-RX753 PC Desktop
After shutting down my computer there is no sound
Check your computer if there is a program running called deep freeze. If it is active have it disable re-start and install again your sound driver.
Nov 23, 2008 | ASUS K8V-MX Motherboard
It sounds that you might having problem with your power supply unit, try replacing it with another working one. Problems like this one can be caused by defective power supply unit.
Nov 10, 2008 | Dell Dimension 2400 PC Desktop
MY DAUGHT WAS USING MY COMPUTER AN SHE DOWNLOADED SOMETHING WITHOUT ME KNOWING AN,I HAVE SOME ICONS ON MY COMPUTER THAT WILL NOT DELETE OFF HOW DO I FIX THIS PROMBLEM
You can trying using safe mode
To get there depends on your OS
If your using Windows 98:
  • Restart the computer.
  • Just after the POST diagnostics and memory count, start pressing the F8 key
  • On the Startup Menu, choose Safe Mode
or you may use the system configuration Utility Method.
  • While in Normal mode, Close all programs.
  • Click Start, Run and type MSCONFIG in the box and click OK
  • In the System Configuration Utility, on the General Tab, click the Advanced Button
  • In the Advanced Troubleshooting Settings dialog box, check Enable Startup Menu. Click OK. Click OK again when the System Configuration Utility reappears.
  • You will be prompted to restart the computer. Click Yes. The computer will restart in Safe mode.
  • When you are finished with troubleshooting in Safe mode, open MSCONFIG again and uncheck "Enable Start-up Menu." under the Advanced Menu, then click OK and restart your computer
Windows Xp:
If Windows XP is the only operating system installed on your computer, booting into Safe Mode with these instructions.
  • If the computer is running, shut down Windows, and then turn off the power
  • Wait 30 seconds, and then turn the computer on.
  • When you are finished with all troubleshooting, close all programs and restart the computer as you normally would.
To use the System Configuration Utility method
  • Close all open programs.
  • The System Configuration Utility appears, On the BOOT.INI tab, Check the "/SAFEBOOT" option, and then click OK and Restart your computer when prompted.
  • The computer restarts in Safe mode.
  • Perform the troubleshooting steps for which you are using Safe Mode.
    When you are finished with troubleshooting in Safe mode, open MSCONFIG again, on the BOOT.INI tab, uncheck "/SAFEBOOT" and click OK to restart your computer
Windows as part of a multiboot system
Use this method ONLY if you have multiple operating systems installed on your computer.
  • When the Boot loader menu (list of the available operating systems) appears, use the arrow keys on the keyboard to select the version Windows what you want
  • Press Enter, and then immediately begin tapping the F8 key. The Windows Advanced Options menu appears.
  • Scroll to and select the Safe mode menu item , and then press Enter.
Windows Vista:
  • Turn the computer on or Restart the computer
  • Start tapping the F8 key. The Windows Advanced Boot Options Menu appears. If you begin tapping the F8 key too soon, some computers display a "keyboard error" message. To resolve this, restart the computer and try again.
  • Ensure that the Safe mode option is selected (the top option)
  • When you are finished with troubleshooting, close all programs and restart the computer as you normally would.
Oct 20, 2008 | Computers & Internet
Acer Aspire 5500 5570-2609 Laptop Logo
122 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
