Question about Creative Technology SBS A200 2 Speakers
How to open the subwoofer of the creative sbs a200
My subwoofer not working, how can i bring out the circuit from the subwoofer box for troubleshooting
    New Friend:
  • 3 Answers
Simply unscrew black back panel. Circuit is attached to plate. Sockets sealed with hot glue for air tight. You can melt hot glue with solder iron if neccessary.
how to open the subwoofer of the creative sbs a200 - 78a62dd3-53c2-4048-910f-984e273a29a9.jpg
Posted on Apr 02, 2014
  • Birhan Apr 02, 2014
    But this circuit is amplifiers only. If your problem is distorted sound (like dirty pots), probably you need inspect control pots in setallite.
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: Please help me solve a satellite sound problem
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Jun 23, 2011
Testimonial: "Thanks bronk50 that was helpful but has not sorted the sound issue. the subwoofer is ok but ithink there is a cooked component that distributes sound."
Radio stopped working now dash lights stay on 09 focus
With the parking lamps ON, the instrument panel dimmer switch uses electronic circuitry to provide a variable pulse width modulated (PWM) output to the instrument panel and all applicable switches depending on the driver-controlled level of intensity, The dash lights stay on with headlamp switch off ?
Have checked the fuse's for the Radio ?
Visual Inspection Chart Mechanical Electrical
  • Audio unit
  • Compact disc (CD)
  • Antenna
  • Battery junction box (BJB) fuse 11 (30A) (subwoofer amplifier)
  • Central junction box (CJB) fuse(s):
    • 31 (20A) (audio unit hot at all times)
    • 41 (7.5A) (audio unit hot in RUN/ACC) (early build)
    • 57 (7.5A) (audio unit hot in RUN/ACC) (late build)
    • 62 (7.5A) (audio unit hot in START)
  • Audio unit
  • Speakers
  • Subwoofer amplifier
Do you know where the central junction box Is ?
Pinpoint Test A: The Audio Unit Is Inoperative/Does Not Operate Correctly
Normal Operation The audio unit receives voltage at all times through circuit 29-MD15 (OG/BK), voltage in RUN/ACC through circuit 75-MD15 (YE/GN), and ground through circuit 91-MD15 (BK/GN). The audio unit is operational with the key in RUN or ACC.
    Possible Causes
  • Fuse
  • Circuit 29-MD15 (OG/BK) open
  • Circuit 75-DA4 (YE/GN) open
  • Circuit 75-MD15 (YE/GN) open
  • Circuit 91-MD15 (BK/GN) open
  • Audio unit
  • Can you pull the radio out , to check power and grounds at the radio connector's if fuse's are Ok .
Dec 30, 2016 | 2009 Ford Focus
Pioneer cx4000 home stereo no rear speakers/subwoofers very low sound. only surround sound works normally
Either the sub woofer speaker or the sub woofer amplifier section circuit has the fault. Contact any service technician to make diagnosis the faulty section. If you wish to get some details; check the site linked here. Pull up older posts.
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" of your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 04, 2016 | Pioneer Audio Players & Recorders
Help me with a subwoofer circuit
sub-woofer circuit Michael, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
100W Subwoofer Amplifier Circuit Diagram Working and Applications
Subwoofer Filter Circuit
22 Watt Car Subwoofer Amplifier Circuit Diagram
subwoofer circuit Google Search
Jun 03, 2016 | Audio Players & Recorders
BLOWS FUSES CIRCUIT BOARD NEEDS WORK NEED SCFHEMATIC
it needs more than work if it blows circuit breakers in the fuse box
To get help with a schematics you have to provide make, model, year and all details possible or you can get it yourself by going google and typing in--schematics for ( make model )--and downloading any pdf versions available
Oct 09, 2015 | Audio Players & Recorders
Why my mf0355 has no power?
check wall receptacle for power. check power cable is connected properly.
May 07, 2014 | Creative Technology SBS A200 2 Speakers
My creative 2b2 2.1 370 power does not work, is there a way to check what the problem is < I have check it with a different adapter! is there way to open the subbox to check the power supply board?
You can check whether the AC power adaptor is giving output first. If it is not giving an output , then only do you have to open the subbox to check deeper into the subwoofer circuitry.
Mar 25, 2012 | Creative Labs SBS 370 Computer Speakers
A creative speaker SBS A200 connector pin was damaged. we need to connect that cable directly into the board.so we need that pin details.
Hi, I hope this helps,
Pins look like this: (Top view, not copper side)
1 2 3 4 5
6 7 8 9
1 = Thin white wire from thick white cable (Left input)
2 = Gray (Speaker out)
3 = Orange (+V return from volume unit to bass unit)
4 = Not connected
5 = Thin Red wire from thick red wire (Right input)
6 = Blue (+V power from bass unit to volume unit)
7 = Black (GND - if socket removed, solder 3 socket shield holes to each other or solder black wire directly leftmost hole)
8 = Not connected
9 = Shield copper from thick red wire
Shield copper from thick wire : Solder to GND or Left unconnected
Jun 23, 2011 | Creative Technology SBS A200 2 Speakers
Please help me solve a satellite sound problem with my creative sbs a200 2.1 speaker system. I get sound from the subwoofer but the twoo small speakers have no sound. Any idea which component(s) to replace...
also
hope this helps
Creative Technology SBS A200 2 Speakers Logo
946 people viewed this question
Top Creative Technology Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Creative Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
