Question about Quasar SP-3235 32" TV
How do i get to the pip without a remote on my Quasar tv
Can i get to the pip mode without a remote
4 Suggested Answers
ginko
  • 19396 Answers
SOURCE: 20 year old Quasar colour TV (no remote)
That is because the switches of the front panel buttons are stuck or defective.
Try first unplugging power for ten minutes, this probably wont work.
To fix this the TV must be taken apart from an expert, and front panel replaced.
You can enquiry here for parts.
What you can do at home, is getting a replacement remote and using TV with a remote, or buying a freeview box, and watching and changing channels through the box.
You can get a replacement remote here: Replacement Remote Control orReplacement Remotes
My suggestion, if it is supported in your area, get a set top box with 30 channels : Freeview - digital TV from Argos.
Posted on Oct 11, 2008
SOURCE: my universal remote can't program my quasar tv
please , what model of remote do you have?
Posted on Sep 16, 2009
SOURCE: OLD QUASAR TV WITH BUILTED IN VCR WITHOUT
I think you can use the channel up arrow and it will go into an auto-scan mode. At least that's what I was able to do when I was having my problems with the cable/sat now working. I had to find a way to get it into Cable mode vs TV mode. I think if your tv is in TV mode, this might work. worth a try at least.
Posted on Nov 15, 2011
How do i get pip on a ds27590 without a remote
The original remote will have the PIP button/buttons on it.
Nov 04, 2012 | Sanyo DS27590 TV
The pip got stuck using a universal remote..i cannot clear it no matter what button I use
If you can access the Menu options with your present universal remote, get into it, and surf thorugh picture adjustment and PIP adjustment screen, and set the PIP option to OFF. If you can't access the Menu option with your present remote control, there is no other way to do this without its original remote control.
Apr 06, 2012 | Panasonic CT-36D32 36" TV
I want to load my tv code from my vizio on my remote for my 321
I used 0178 to program my universal remote. You can also try 10056, 10178,10864,10885,11756,10056,11758, and 11499. Then you can try by dropping the "1" from the front of these codes.
Most good remotes have a programming function if this does not work, where the remote will "learn" the proper code.
The actual button remote codes are as follows:
0 00117
1 00121
2 00119
3 00123
4 00116
5 00120
6 00118
7 00122
8 00245
9 00249
Vol + 00183
Vol - 00187
Mute 00057
Channel + 00181
Channel - 00185
Power 00053
Enter 00164
Last 00247
Menu 00171
Guide 00244
Up 00168
Down 00166
Left 00170
Right 00037
OK 00164
Sleep 00054
PIP 00197
Info 00251
PIP Swap 00198
PIP Mode 00199
Exit 00216
Audio 00059
Input 00090
Wide 00138
TV 00110
AV 00105
Component 00231
HDMI 00174
MTS 00055
CC 00025
Zoom + 00165
Zoom - 00169
Freeze 00200
RGB 00253
PIP Ch + 00196
PIP Ch - 00203
PIP Input 00199
PIP Size 00201
Good Luck
Nov 30, 2009 | Vizio VW32L 32 in. LCD HDTV
I dont have a pip button on my remote to reset my
if you do not have the (PIP) button on your remote look for for the (split) button and try the volume down and (PIP/split) trick again. it worked for me!! good luck..
Oct 06, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Turning off PIP without remote
order the origanal remote from www.vancebaldwin.com the part number is RM-C380-1A the cost is $24.22 plus SH. there are a hand full of universal remotes that can control PIP but getting the right one a **** shoot.
Apr 19, 2008 | JVC AV-20120 TV
Pip is stuck and i don't even have a pip button on my remote!
The problem was solved by using the TWC cable remote control and selecting "TV" on the top and the press the big blue "Select" button. DO not forget to put the remote back into "CBL" mode. Apparently this is a hidden feature, which works even on TVs, which officially do not support PIP. I works only with the one tuner, video 2 and video 3 but not video 1.
Dec 05, 2007 | Sony KV-32S26 32" TV
PIP stuck
MrKevin, some Hitachis have 2 different pip buttons on the remote, I believe 1 says pip mode or something to that effect, do the rest of the functions on your remote work? Check and see if you have a second pip button and be sure the remote is set to "tv" if it has that little slide button on the side, good luck, hope this helps
Nov 27, 2007 | Hitachi 50EX01B 50" Rear Projection...
To turn off the "stuck" pip on a Panasonic tv without a remote:
1) Turn off the tv.
2) Then hold down the "Action" button on the front of the tv and press the power button.
2-b) Continue to hold down the Action until the tv powers all the way up, and the reset menu comes up - be patient.
Expected Reslut: Self check menu should appear.
Expected Reslut: The pesky pip screen will be gone!
If the self check menu does not appear, you did not hold the Action button long enough.
Simply begin from step one.
Thanks to Imhiro
Sep 28, 2007 | Panasonic CT-36D32 36" TV
PIP for Sony KV-27XBR45 television trouble shooting
If you have the original remote for this TV on the pip menu (left side slider on remote all the way up) there is a pip off button. If you unplug the unit long enough it should go back to normal. If you go into demo mode and then exit mode you will again be out of the pip. With out the original remote you cannot easily turn pip off.
Apr 13, 2007 | Sony KV-27XBR45 27" TV
PIP won't turn off
I pressed "Demo" on the front of my TV and it worked, I have an old Sony KP-53XBR35 VIDEOSCOPE XBR - no original remote and the Universal remote has PIP button but would not shut it off.
Finally it's off!!!!
Jan 23, 2007 | Sony KV-35V35 TV
Quasar SP-3235 32" TV Logo
18 people viewed this question
Top Quasar Televison & Video Experts
Radames Pagan
Radames Pagan
 Grubhead
Grubhead
Are you a Quasar Televison and Video Expert? Answer questions, earn points and help others
