Installing new motherboard
Need to find a wiring diagram for a gateway e4600 series I've purchased a new motherboard to get rid of the rdram board and of course it does not just plug right in , any help would be great
  • 2 more comments
  • crash32301 Mar 12, 2009
    That is where I'm haveing the problem is the front panel connector, reset buton the , Hdd lights , looks like gateway uses a 16 pin connector with 5 wires going into it , and the new motherboard has a 9 pin plug in , if I could find out what the wires on the OE plug do I'll be able to make sure that they are plugged in correctly ., also I have a couple power cables that have no where to go ? one is a square 4 pin with yellow and black wires going into it, the other is a flat 6 pin with 3-black 2-orange 1-red, this one was pluged in right next to the main power supply on the old motherboard . Hope this helps you help me this is the 1st time I've tried this and just want to get it right
  • crash32301 Mar 13, 2009
    looking at my switch you are correct just X-crossed 2 for the power button and 3 on the light I'll look at the old board and see if I can trace them back that way , and yes the old pind said P8 and P9 , I've got the manual for the new board , but I can't find anything on the old one , thanks for all your help so far you have got me going in the right direction and making this a easier job , Mark
  • computerscot May 11, 2010
    I would first trace the wires from the 16 pin connector back to the front piece. 2 should go to the HDD light and 3 to the power button - or something like that. Then look at where they went on the old motherboard. Most motherboards will have writing next to the connectors on the board itself.
    Sometimes with power supplies you will have extra cables. The 4 pin black and yellow ones are used for the processor, if your board needs/supports it. Does the flat 6 pin say like P8 or P9 on it? If so it may have been for legacy boards.
    Did you have any luck googling the motherboard to find a manual?
    Most of the stuff should plug in to a similar port on the new motherboard. Take notes when you disconnect parts from your old motherboard. The easy stuff is the hard drives, power connectors to the optical/floppy drives and ribbon cables. They all only go in one way. The harder ones are the front panel connectors, HDD lights, reset button, front panel connections for USB/firewire, etc. Look at the motherboard (I recommend a strong flashlight), there should be writing near the connectors that say stuff like HDD, Power, reset, USB, etc.
    Normally what I do in this scenario is look at the motherboard for a name and model number and then google it. I have found several wiring diagrams this way. If you can determine the maker of the motherboard you could try their website.
    Problem Solver:
  • 10 Answers
IF the motherboard came with a manual, I would start there. Most all of today's motherboards come with some sort of documentation on how things need to be connected. If the motherboard did not come with a manual, try going to the manufactures web site and find the documentation there. You probably are not going to want to use the same specs for the original motherboard that came with the PC in the first place.(in fact, don't)
Posted on Mar 23, 2009
Need a wiring diagram for a Gateway DX4300-03 system board
Need to know board model and those cases are wired so the plugs fit the original board. Your best bet would be to just get a new tower case. www.tigerdirect.com has them for $25
Dec 11, 2013 | Computers & Internet
My son has an acer e4600 and I don't know how to determine what kind of motherboard he neeeds. I have been told by 2 people that he needs one
Motherboards for proprietary manufacturers [such as acer] are built for them and only supplied by them. For all intents and purposes, that board is 'dead'. Acer technicians would advise that you purchase a new CPU [box] which would ship a casing, power supply, motherboard and processor, plus other hardware that a new CPU will ship with from the manufacturer.
It is advised that you approach your dealer or store where this unit was purchased from for additional information.
May 14, 2010 | Computers & Internet
I need help with wiring diagram for e4600 gateway desktop
Gateway's support documents page for this series is here. You can try picking your particular model from the list and see if any of the available manuals gives you the information you need. If not, please post a followup comment with more information about the problem you're having and I'll try to help further.
Mar 27, 2010 | Computers & Internet
Hi I have a mother board EP-4T2A3 and it supports
This EP-4T2A3 is unique, that the can only utilize the slightly more expensive RDRAM memory modules. Furthermore, because of the dual memory controllers in the i850 chip-set, all motherboards based off of this chip-set must also have its RDRAM installed in pairs. You can purchase RAMBUS chips of PC600 to PC800 memory modules. You have 4 RIMM slots, and they must be installed in pairs, or you will get speeds of only a single module. The unfortunate part is that the RDRAM modules are a little more pricey. You can find some samples of these HERE.
Good Luck
Mark
Dec 29, 2009 | EPoX EP-4T2A3 Motherboard
I need to replace the motherboard on my Gateway 503GR. Will the following motherboard work? eVGA e-7050/610i GPU - motherboard - micro ATX - GeForce 7050
Check your wiring harness on your Gateway and see if it will match up to your new board. If the wiring harness will match up then you can install the board. However, you will now have a custom built computer in a Gateway case.
Aug 01, 2009 | Gateway 503GR PC Desktop
Looking for the manual for a Gateway 700S PC. Specifically 2 questions ... 1) how do I open the ATX tower case? and 2) what EXACT memory specs do i need to upgrade this unit from the 256MB that it came...
for the memory upgrade, your system used RDRAM RIMMS.
it supports the following memory modules (which must be installed in pairs).
and as for opening the case, you there should just be ~2 screws on the side panel away from the motherboard ports that you can remove and it will slide off, or there might be 1 or 2 thumb screws.
64MB Module 64MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-136 128MB Module 128MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-079 512 MB Kit 256MBx16, 800MHz PC800, 184p RIMM, RDRAM, 45ns, 2.5v PC800-Kit-081 64MB ECC Module 64MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-134 128MB ECC Module 128MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-080 512 MB ECC Kit 256MBx18, 800MHz PC800, 184p RIMM, ECC, RDRAM, 45ns, 2.5v PC800-Kit-082
Jun 24, 2009 | Gateway 700 X PC Desktop
I need to set up RAM on GATEWAY ATXAEG LX3 700S P04 for first time. What is the correct placement of RDRAM.
RDRAMs have to be installed in pairs (at least in my case I think) but can the two pairs be of different capacity? as in:
64,64 - 256,256
(Upgrading 2 64mb RDRAM to 2 256mb RDRAM)
Jun 16, 2009 | Gateway (4000782) Motherboard
Gateway performance 1400 motherboard specs
Performance 1400 Memory Specifications Standard Memory 128 MB (removable) Maximum Memory 1.0 GB Memory Expansion 4 sockets (2 banks of 2) Memory Comments PC800 RDRAM RIMMs. RIMMS must be installed in matching pairs. CPU Type 1.4GHz Intel Pentium 4 Model Comments 400MHz FSB, Intel 850 Chipset
Apr 27, 2009 | Gateway (4000811) Motherboard
I want to upgrade my procesor to faster procesor.
Upgrading processor is not likely a practical solution; find out the motherboard manufacturer and contact their site for more information. As to upgrading the motherboard, you'll have to know what kind/size of board your system will require. If you don't have lots of experience, this process is very risky.
Frankly, the cheapest way to upgrade your computer is to buy a used and working product with Windows XP already installed. Go to http://craigslist.com, select your city, and search for a brand name you trust. I've bought DOZENS of used computers very cheap that way (I'm writing this on a $2,200 Dell Latitude D620 I bought fiv months old for $500, who needed the cash!)
Mar 30, 2009 | Gateway Computers & Internet
Memory limit for my dell E139761 motherboard
Although the motherboard ultimately decides how much memory your system can handle, Dell does not list the specifications of motherboards. You need the model number of the computer, and if the motherboard is not the original one that came in the computer when it was built by Dell they won't know either.
You can go to dell.com and put in your service tag to see the specifications yourself. If you post the computer model number or service tag here that's what someone else will do anyway.
Mar 23, 2009 | Dell Computers & Internet
Computers & Internet Logo
220 people viewed this question
David Payne
David Payne
