Question about Rinnai RC80i Tankless Water Heater 8.0 GPM 157,000 BTU
Can you convert a natural gas rc80i n waterheater to propane
Is there a conversion kit
  • Rinnai Master
  • 5,089 Answers
Contact manufacturer.
Generally the answer is probably no, especially if you have a family, children, dog and neighbors.
Propane burns Hotter and has more pressure than natural gas.
Burner must be more robust cast iron.
Orifices must be changed to accommodate different gas.
Different gas control valve needed.
In some cases there are dip switch changes for type of gas and altitude above sea level ... the higher the elevation, the hotter gas burns.
Here is expected result from changing NG to LP.
But your good luck might lead to less volatile result
http://waterheatertimer.org/images/Exploded-house3.jpg
Posted on Apr 22, 2013
2 Suggested Answers
  • 5089 Answers
SOURCE: What does it take to convert a Rinnai R75LS water heater from propane to natural gas?
Contact Rinnai.
Gas control valve is different, burner is different, burner and gas valve must match, threads are regular instead of reverse, dip switches probably have to be changed since combustion of NG is not as hot. Maybe different sensors. Pressures are lower with NG.
Posted on Mar 28, 2013
Can I convert natural gas water heater to propane?
With knowledge of make and model, your manufacturer can supply a retailer who can provide you with proper kit...
info here...
http://www.propane101.com/lpgasapplianceconversions.htm
http://hometips.me/Mar/Convert-water-heater-to%20different-gas.pdf
Sears com
May 06, 2015 | Water Water Heaters
Where do I get a Propane to natural gas conversion kit for a Reliance 640LORT water heater
You should be able to get this at any home improvement store or a Tractor Supply Store. Another source would be somewhere like Praxair or whoever your local propane gas refill place is.
Feb 14, 2015 | Reliance Water Heaters
Can i convert a Rheem ECO 180DVP (LP gas unit) to a natural gas unit ?
Rheem water heaters should not be converted from propane to natural gas. The burners have been optimized for the rated gas and will not work as well after conversion. (Unlike ranges where the gas/air flow ratios can be adjusted when the burner orifices and regulator are swapped, the water heater doesn't have that option.)
I wish I had better news for you. I recommend you get a new water heater for the LNG service; it will be safer and more efficient.
Nov 10, 2014 | Rheem Tankless Hot Water Heater...
I bought a AQ125BNG from my neighbor and when I read the instructions it says to use a gas pressure regulator on the AQ125B but I dont know if I need it on my AQ125BNG too is not that clear. I will ap
The NG at the end of the model # means natural gas. If you have a nat gas meter outside on your home, the regulator is already there. If you have propane gas for your home, then the control and the appliance needs to be converted to propane, if the conversion kits are available. Call the manufacturer if you have any doubts.
Sep 12, 2014 | Water Heaters
Can 42v50- 36pf be converted to natural gas ?
You would have to inquire of Rheem. Some appliance manufacturers have conversion kits available
Mar 24, 2013 | Rheem 42V50-36PF Professional Propane Gas...
RINNAI R94LS CONVERT TO NATURAL FROM PROPANE
The electric water heaters have replaced the traditional of water heating. The advanced features and the latest technologies of water heater have made it so easy for everyone. Find the best electric water heater on the market today. Read electric water heater reviews and comments from experts. Almost each product is manually reviewed and tested.
Electric Water Heater List Reviews waterheaterlist com
Jan 28, 2013 | Rinnai R94LSi Tankless Water Heater...
Change orfis in water heater
Do NOT do that.
If you put LP gas to NG heater you can cause explosion.
Contact manufacturer and see if they sell conversion kit. Most do not.
Copy following link for general overview and cautions:
http://waterheatertimer.org/pdf/Convert-Natural-Gas-water-heater-to-LP-heater.pdf
Jul 11, 2012 | Water Heaters
I HAVE A PTG-74PVP-2 THAT USES PROPANE & I WANT TO CHANGE THE '' ORRIFICE '' OR WHATEVER IT TAKES TO USE NATURAL GAS INSTEAD . I CURRANTLY HAVE A NATURAL GAS TANK TYPE THAT I WANT TO REPLACE .
you must get the conversion kit which is an orifice and gasket(s),springs, or possibly a whole new gas valve--call the manufacturer, or a wholesale plumbing/heating supply warehouse and they'll be able to find you the part number, or point you to someone who has it---keep asking, and someone in the industry will eventually help you....the correct orifice,gaskets/springs are needed because there is a very precise pressure and flow of gas needed for both natural and propane gas
Mar 09, 2010 | Rheem Paloma Tankless Water Heaters...
I need to convert this water heater to natural gas. Is there a kit available to do this?
No kits are available to convert his unit to NG. This is because the LP uses copper pipe and is within code, the NG uses black pipe and each unit is specifically designed, entirely, to use the gas associated with the unit.
Feb 05, 2010 | Bosch AquaStar Propane Tankless Water...
Rinnai RC80i Tankless Water Heater 8.0 GPM 157,000 BTU Logo
111 people viewed this question
Top Rinnai Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
jdthefixer
Are you a Rinnai Water Heater Expert? Answer questions, earn points and help others
