Question about Dryers
Hoover vision hd vhc 380 turbo dry condenser dryer will not heat up just blowing cold
rogrrabbit
  • 986 Answers
SOURCE: Hoover Condenser Tumble dryer HSC 170 not heating up
The heating element have got old and brittle over time and finally gave up the ghost. But it is not always the element. It could be one of the safety Hi-limits have blown. All parts of the dryer will have continuity if its working properly. Test for continuity by using a meter set on Ohms,or use a poor man's meter. You can make your own poor man's meter by using an ordinary flashlight . Break the circuit in the flashlight and add a couple of wires to it so that you can make the light come on in the flashlight, that's right hot wire that flashlight. When the bulb lights up you have a circuit! You now have a poor man's meter. The next step is to check each little gizmo on the dryer that the wires attach to. All the limits attached to the side of the heat element, the door switch (when door is closed) etc.should have continuity (closed circuit)(the light should come on in the poor man's meter) If you come across an thing near the blower housing with 2 wires attached to it, that is a thermal limit, a safety or a control thermostat (So as not to get a false circuit you need to remove one of the wires to each thing you check) Look for lint buildup or blocked vent going out the house. If everything is good and you have paid the electric bill, then the timer could be bad.
Posted on Nov 27, 2009
SOURCE: Hoover 381/1 condenser tumble dryer empty water
Got a similar problem with an HNC172. The supplier said it is the water indicator sensor that is not working. He fixed it! It still stops!!! Clear lint from the trap in the door. Empty what little water there is in the tank, then make sure it has a good shove to get it back into place and the tube/catch is well joined back. Also take out the condenser unit above water tank, stick in the bath and put the shower hose through it to clear lint. Recommend getting a tea strainer over the plug hole or you block your drain as quite a bit comes out. It helped for a while, but it still has problems. Might be the thermostat for the heater? check the error codes. They flash a different number of times within 15 seconds to indicate which problem is happening.
Posted on Jan 09, 2010
SOURCE: I have a Hoover Turbo
Hi have same problem am just fixing now - looks like build up of snow fluff etc is blocking vent pipe. dryer runs ok when disconnected so may be a solution for you.
Posted on Dec 21, 2010
hunter19_46m
  • 7482 Answers
SOURCE: My hoover condenser dryer model
Hi Alan....
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. If this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For video and pictures on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Dec 31, 2010
heatman101
  • 43501 Answers
SOURCE: Hoover Vision HD dryer not
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Posted on Mar 20, 2011
How do I change the heating element on a hoover vhc 691 b tumble dryer?
Many of the heating elements can be seen and changed by laying the dryer on its back...the element is usually visible from the bottom. I found the part on the link I am incuding for you. Hoover VHC 691B80 Dryer Element 2100W
Dec 15, 2014 | Hoover Dryers
Got hoover vision hd condenser dryer it's drying but taking ages also not turning off
Try cleaning out your vents. That is the most common culprit behind long dry times. If that doesn't do it, then change the operating thermostat.
Oct 25, 2014 | Dryers
Takes too long to dry
Is it heating up at all? I just fixed my vision hd hoover 381 dryer by replacing the heating element. Email me if you think this might be you (matskm@gmail.com). When the dryer is running, feel the metal heater housing (carefully) on the back (silver bulge) if your model is like mine.
Jan 09, 2014 | Hoover VHC391 T-80 Dryer
My hoover vision hd vhc 781 xtb is not heating up
if its not heating on any program the heater element has gone but if its still working fine just use heating from you taps to fill to requires temp or disconect from cold and put it onto the hot out let from your piping just remember not to have it boiling as your clother will shring lol
Sep 24, 2012 | Washing Machines
My Hoover HD condenser dryer won't give out any
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 19, 2011 | Hoover Dryers
I have a Hoover Turbo Dry Vision HD. When I put it on it starts ok and then after about 30 seconds all the lights are flashing and it will not work ?
Dec 19, 2010 | Dryers
Dryers Logo
88 people viewed this question
Top Dryers Experts
