Question about Panasonic KX-FP85 Plain Paper Thermal transfer Fax
Brother fax 930 machine
I just got this brother fax 930 machine second hand , it copys ok it works as a phone ok but when i send a fax it goes through ok and i get a report come out sayin that it has worked, but i phoned the place i faxed to and they say it didn't work what do i do i am so not a technical person.
  • 186 Answers
I would try sending to another source. If the document goes threw the machine and you get a confirmation report saying it was sent, then it was sent. The person on the other end may be having trouble with their machine as well.
Posted on Aug 03, 2007
Re: Brother FAX-930. LCD display?
I think the LCD screen is going bad. I would try to unplug the machine leave the power off for about five minutes and plug back in and see if that works.
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_7148ad2a373711a3
Aug 19, 2009 | Brother FAX 930 All-In-One Thermal Printer
Using MagicJack for faxing; however, Brother MFC 290C is stating poor line condition - why? Also say's low ink Magenta - would that create this problem?
I had the same problem trying to send out faxes out using my Brother MFC 7340. I use a magic jack phone line. Page 106 of the user manual says if sending via VOIP phone line, you should press menu, then 2, 0, 1 to select "Basic (for VOIP) mode. Then press ok. Then press stop/exit. This cuts the modem speed down to 9600 bps and turns ECM off. Then retry to send the fax. I did that and can now send and receive faxes.
Jun 06, 2009 | Brother MFC 420CN All-In-One InkJet...
4100 when I copy I get a black line down the middle Ok after cleaning inside top cover, but,comes back after a few copies. Printing and sending fax ok.
Try printing out a report. If the line is still there you need to use the wire cleaner on your print cartridge or if that doesn't work, replace the drum unit.
Apr 03, 2009 | Brother IntelliFAX 4100 Laser Fax
Copy report after sending fax
it will be under reports, you can set all faxes to do a report after a fax has been sent, ill keep the terminology easy as
Brother, canon, konica blah blah all uses different terminology for it, but there is a setting in reports for user that they can turn on, it like error reporting if a fax deosnt go it will print out a error report so same thing to do with copy report.
regards
Fax Tech
Apr 01, 2009 | Office Equipment & Supplies
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
http://www.fixya.com/support/p170643-brother_fax_930_all_in_one_thermal/manual-1604
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
Display says "printing online" but it is not connected to a PC
unplug machine, press and hold down the "stop/exit" key while pluggung back in. continue to hold the button down for 5 secs, then release. if machine returns to the regular date/time display, you should be alright. if not, then you'll have to call brother or an authorized service center. this is usually caused by a fax stuck in memory, which this procedure should clear.
good luck,
razors
Feb 11, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Copying on the 930
replace your roll, if you havent use for quite some time, chances are this could be overexposed
Aug 30, 2008 | Brother FAX 930 All-In-One Thermal Printer
Brother fax machine
You should be able to catch it on the journal if you print one out.
Jun 12, 2008 | Brother FAX 930 All-In-One Thermal Printer
Panasonic KX-FP85 Plain Paper Thermal transfer Fax Logo
99 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
HEMANT GROVER
mahesh y.h
mahesh y.h
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
