Question about Sony PS3 40GB Best Sellers Bundle Console
Hard drive for my ps3
When i turn my ps3 on hard dis is corrupated
    New Friend:
    Problem Solver:
  • 6 Answers
Greetings, you have to format your hdd, if that doesnt work you have to buy a new hdd and put it on your ps3.
to formatting your hdd you have to enter to ps3 service mode pressing the power button until you hear 3 bips.
Posted on Apr 23, 2013
When you put a game in a message reading "The hard disk's file system is corruped and will be restored" then we press OK. when it gets to 100 it resets and the same message appears.
SAFE MODE:
1. Place you finger on the on/off sensor leave it their until you console turns off then take you finger off the sensor.
2. Place your finger back on the on/off sensor leave it their until you hear 2 consecutive beeps then take your finger off.
3. Once the safe mode screen comes on select the option PS3 SYSTEM RESTORE.
NOTE: A PS3 system restore will delete all data except the OS. I recommend backing up your console onto a USB flash drive if possible.
Good Luck!
Sep 12, 2011 | Sony Playstation 3 (PS3) Console
My PS3 wont boot. Says "Correct hard drive not
I would suggest:
1) With PS3 off 2) Remove drive 3) Turn PS3 on 4) Let it complain about missing drive 5) Turn off PS3 6) Put drive back in 7) Turn on
If it still complains, try safe boot recovery mode again, choosing option 3, then again with option 4 -- If it still doesn't work, it's not looking good, bit hopefully those should sort it unless the drive really is kaput.
Dec 25, 2010 | Sony Playstation 3 (PS3) Console
The system was updated wrong it shouldent have been updated. WHEN IT WAS TURNED BACK ON IT FROZE WITH THE UPDATE INSRUCTIONS AND YOU CANT GET IT TO DO ANYTHING. IT SAID SOMETHING ABOUT THE OS NOT WORKING...
To fix this you must download a new OS(operating system) to do this u have to download it to a flash drive from xbox.com and follow there instruction on their website
Apr 18, 2010 | Sony Playstation 3 (PS3) Console
How i can fix red screen on ps3 ?
Well first of all you can try the below steps -
1. turn off your ps3 with switch at back
2.hold power button
3.(do this while holding pwr button) switch back on the ps3
4. if done correctly the ps3 should make a loud fan noise causing the fans to enhance for awhile, that should clean out anything that could overheat the ps3
Sometimes the red light will be flashing because there is a problem with the connection of the hard drive to the rest of the PS3 or the hard drive itself is broken.
You can usually fix this problem by re-setting the drive. To do this, go to the side of your console and take out the hard drive. Then replace it in exactly the same position. If the red light is still flashing when you turn your PS3 on, you might have to get a new hard drive, or even a new PS3. Please post comments for more help or information..........
Good Luck!!
Thanks
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
X button on PS3 controller not working
Hey i bought my controller from gamestop brand new for 60$ and after 8 months same thing happend to me.
I think it happend because i tunrned the ps3 off incorrectly and i corrupted some data , i could fix that dat because the data corruped was those files for recognizion of the "X" button.
To restore it you will need a PS3 Dvd/Bluray controller to go the XMB and restore using that controller.
Jan 31, 2010 | Sony Dual Shock 3 Controller for...
SWirly lines but no menu
Hi, this sounds like a hard drive problem. Try taking your hard drive out and putting it in another PS3 to see if it does the same thing. If it does, then your hard drive is damaged and needs replaced.Your hard drive is located on the side of your PS3, pop the cover off and remove the retainer screw and slide it to the front of the PS3 (pull straight out on some models).
Aug 17, 2009 | Sony Playstation 3 (PS3) Console
Ps3 turns on, but icons don't show up.
It sounds like it isn't loading from the hard drive. Take your hard drive out and see if it works on a different PS3. If it does the same thing then your hard drive is toast.
Aug 04, 2009 | Sony Playstation 3 (PS3) Console
System32 dll file is missing or corrup
There is a good possibility that you are having a hardware failure of the Hard Disk Drive, causing the windows error.
Either in the BIOS or in the F12 boot menu should be an option to run diagnostics, see if the hard drive fails. If it does, then you need to replace the drive.
If not, you will likely need an XP Installation CD so you can boot to Recovery Console and run the command CHKDSK /P to try and recover the operating system
Jun 05, 2009 | Compaq Presario 5000 PC Desktop
40G PS3 system corrupted
Hello. If the hard drive will not reformat inside the PS3 when you press X, then you will need to remove it and reformat it on a PC using an external device or replace the hard drive. Thanks.
Jan 09, 2009 | Sony Playstation 3 (PS3) Console
Sony PS3 40GB Best Sellers Bundle Console Logo
29 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
