The button has stayed indented and I can't start the washing machine.how do I get it out and springing again?
  • Washing Mach... Master
  • 15,633 Answers
If the button is just stuck, you can use a sewing needle to pop it out. Just try and lightly pull it out with the needle. If you are not able to do that you can use something thin like a piece of a soda can to slide around the outside of the button. My though is that the switch has failed though. It will have to be replaced. The bad news is that this is most likely a part of the whole control board and it could be expensive. Post the make and model number.
Posted on Apr 21, 2013
  • gibsshar2 Apr 21, 2013
    Hi it is a lg wm1295fhb washer and I don't think it's stuck because the button can move around under the panel. What do you think I should do ?
  • Brad Brown Apr 22, 2013
    http://www.partmaster.co.uk/cgi-bin/prod...
rylee_smith
  • 8619 Answers
SOURCE: MACHINE STOPS DURING WASHING CYCLE SIMPLY PUSHING
Hi
Thanks for using FixYa. To start with check the lid switch which is located near the door frame inside the main housing of your washer. If that appears to be fine then check if the door is closing properly as if it is not then it is a door lock issue and you might have to replace the door lock assembly. Please do accept the solution if the issue is resolved or post a comment with the manufacturers name and model no# for further assistance.
Thanks
Rylee
Posted on May 25, 2010
blueextc3221
  • 15935 Answers
SOURCE: Washing machine won't start
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
blueextc3221
  • 15935 Answers
SOURCE: WASH CYCLE STARTED WHEN I
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 15, 2010
blueextc3221
  • 15935 Answers
SOURCE: Philco washing machine
Posted on Sep 17, 2010
Daniel S
  • 4323 Answers
SOURCE: My electrolux EWF 1074 washing
Hi
First make sure that nothing is blocking the drain pump assembly located inside the bottom of the unit, after this test the door lock-switch assembly. If the door lock-switch is also fine then the control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Sep 12, 2011
Asko W600 extra rinse button not working
some can be taken apart and inside is a spring loaded connection that pushes the button back out sometimes hard water and soap and debris can jam and stick the spring and u get what ur getting? you may be able to by pass the extra rinse by disconnection the prongs to it and taping them up?
Mar 29, 2015 | Asko W600
Why won't washing machine start?
It is most probably the door sensor that is faulty. If the sensor does not sense the door closing the machine will stay in "open door" mode and will not start with it's program.
If the machine is still under warranty, take it in for repair or have someone check it out for you. It should be a quick fix, if parts are available.
May 24, 2014 | Washing Machines
Error message
Hit cancel the amount of minutes will stay the same and then hit the start button again.
May 13, 2009 | Kenmore Elite 45986 Front Load Washer
LG wd8013F bowl support plastic pin fell out. I turned machine upside-down, replaced plastic pin, now doesnt wash or spin.
(A) Set-up
1) The inner bowl is supported by (2) heavy springs at the top, plus (2) telescopic shock absorbers beneath the bowl.
(B) Observed Problem
1) Inner bowl was missaligned, causing out of balance knocking & banging, also drive belt was squealing from misalignment.
(C) Remedy:
1) Disconnect power from outlet.
2) Remove (4) screws from back plate, remove back plate.
3) Bowl is suspended on (2) heavy springs from top, and (2) telescopic shock absorbers below bowl.
4) Inspection showed plastic pin retaining shock absorber end to frame had fallen out.
5) Place old carpet or whatever on floor, invert washing machine.
6) Re-align end of shock absorber into housing piece.
7) Re-insert plastic pin (about 2 inches long x 1/2 inch diameter) securely into place.
8) Re-assemble.
Also:
a) It could be one of the top springs as per (B)1 above may have broken or become loose.
b) In this case the top cover plate is easily removed from machine by removing (2) screws at the rear top of cover.
This gives access to the (2) heavy springs, which are easily repaired.
Note:
Sometimes the machine will not re-start again following out of balance problems.
1) Turn power off again, re-boot like computer.
2) There is also a re-boot procedure similar to Alt+Ctrl+Del on computer.
3) Use three buttons simulateously, Start+spin+option buttons or similar.
4) I fiddled with these until all lights lit up, then after a while the machine worked satsifactorily.
Cheers
Nov 06, 2008 | LG Washing Machines
Washer power
Sounds like you have a stuck or shorted keypad. I've seen this a lot on this model. Solution is to replace the keypad. Catriver.
Aug 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
52 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
