You will have to call in for service free if its still under the 1 yr warranty, but i solved it from not spinning by rotating it side by side slightly when the unit is on, and getting the fan to move slightly, then it should run as normal. when i sent it in, it came back in the same condition, so i sorted it out myself.
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and...
(More)
have an old airconditioner that no longer works attached to bedroom wall unit under house pipes and lead go through hole in wall along wall in next room need to know how to remove whole unit thanks
Cleaned the filers. Reset the filter so the light would go off and now the unit doesn't work. Tried...
(More)
Cleaned the filers. Reset the filter so the light would go off and now the unit doesn't work. Tried unplugging, plugging in and nothing. All the lights work on the unit but nothing happens.
