Indesit wie 167 keeps getting stuck on 1 minute left with water still in but i can turn dial to spin to empty not taking softener so don't think it is doing proper cycle
  • 15 Answers
SOURCE: indesit machine won't start
on the bottom of the machine there is a panel made of plastic that may be removed to expose the waste filter.open the waste filter and check that the waste pump is not blocked as in the initial start up the pump is run if there is a problem with the pump the machine will not advance.
Posted on Jul 19, 2007
Richie_asg1
  • 1036 Answers
SOURCE: Indesit WIE 167 says "test".
There is a fault on the program board. It more than likely needs a replacement.
Posted on Nov 05, 2008
SOURCE: Indesit WIE 147 - Display 'F-03' fault
Indesit washing machine error code 3 (F03) On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Posted on Nov 16, 2008
  • 17 Answers
SOURCE: makes noise,softener not dispensing,vibrates on spin cycles!
YOU NEED A BERING JOB
Posted on Dec 16, 2008
beltronic205
  • 1461 Answers
SOURCE: Indesit wahing machine WIE 167 keeps filling with
You need to clear out pressure chamber the part the at tube plugs into the chamber it will be clogged, stopping air going to pressure switch...This should cure..
Posted on Oct 07, 2009
GE washer WCVH6800J1WW - fabric softener doesn't empty
see the causes and remedies:
It spins, but doesn't pump
drain lines clogged, repair+sock in outer tub port, if the lines is not clogge the problem is pump replace
It doesn't spin or pump
frozen pulley pump, replace
It pumps, but the water returns improve the draininin laundry, if have reaches 4 inches cut off the excess. if is lower install air/gap siphon break assembly.
God bless you
Jul 18, 2012 | Washing Machines
Indesit wie 147 washing machine wont empty water it dose every think else but it got stuck and had an error of 5 with water stuck in drain some as looking at the preasure pipe blew down the pipe an no...
It really does sound like you have a blockage somewhere even if you cant feel it. You may need to remove the pump and the pipes to be certain. Try laying the drain pipe on floor level. If it drains then there is definately something in there that needs to be removed. Let me know if you need any more help.
Oct 20, 2011 | Indesit W 123 Front Load Washer
Daewoo DWCLD1013 washer & dryer The cycle keeps getting stuck on spin at around 10minutes, at which time it keeps going round and round with no actual fast spinning, until it stops about 20 minutes...
The cycle that the machine is stuck in is in fact the empty cycle, just before the spin kicks in. It is staying there because it has a problem evacuating all the water. The machine won't go into spin until all the water is gone and after a set time ( 20 minutes is unusually long, most machines stop after about 10,, but I'm not familiar with Daewoo), the attempt to empty is aborted and the machine stops.
Your problem therefore is either:
The filter for the empty pump is clogged with debris (far and away the most likely) you will need to locate and clean the filter
The EXIT to the drain is blocked, check the empty pipe is not blocked
The empty pump has failed (you would usually expect to hear the pump rumming, but it may not be a noise that you are familiar with).
First and second items are easy to fix, the 3rd is a pump replacement, which isn't that hard, but depends on your level of DIY skill
Jun 23, 2011 | Washing Machines
Indesit wahing machine WIE 167 keeps filling with water and did flash H2O have replaced the switch mechinism inside but to no avail tube is not punctured or coroded - will not go onto wash cycle but will...
Oct 07, 2009 | Washing Machines
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
How do I open the pump access on my Indesit WIE 147,
hi there. its likely that there are coins etc in the pump filter,which causes the filter to jam.usually a little persuasion and patience will give you access.try fast left and right turns ,with the emphasis on anti clockwise.otherwise you may need to strip down the pump.patience usully works though!
hope this helps!steve
Apr 16, 2009 | Indesit W 123 Front Load Washer
Hi, my switch keeps going around and around without stopping
Hi I fixed the problem by removing the filter at the bottom right hand corner of the washing machine and removing 2 x £1 coins that had got stuck there
regards
Michelle
Jan 24, 2009 | Indesit W 123 Front Load Washer
INDESIT 167 Stuk on DENO
take the lid off the machine.remove or disconnect the wires off the main board giving them a small spray with a water dispersent or silicone based soloution.by the way turn the power off at the mains before carrying out this procedure.
Jun 29, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
103 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
