I need a Manuel for a Hh07ae001 carrier heat pump thermostat
SOURCE: the EH mode is locked
Sound like power is going to the E H wire or could be touching or bad thermostat..! Disconnect wires and backtrack!
Posted on Aug 27, 2008
  • 124 Answers
SOURCE: carrier heat pump
fuse is usually a small resetable breaker on the side of the transformer, or a traditional screwin fuse with a plastic cap on one end that is a specialty fuse and is available at most motor shops or elec supply houses. or its a auto type plug in fuse on the circuit board usually 5 amps or three amps. first turn the fan switch on the stat from auto to on. does fan run? if it does you have high and low voltage and your wired wrong. if it is in the stat you are usually looking at red connects to red . yellow to yellow, green to green , orange to orange, white usually to white, that leaves a common power wire to operate the stat, usually connected to the common term on the new stat . this can be any color and is necessary for the new stat to think and work, if it has batteries it will have a display but it needs a red and a common to think and work. this wire can be any color and if your old stat had no common which a lot didnt then youll have to add one. carrier also has a emergency heat strip wire sometimes labeled x2 etc. you can usually jump white over to x2 to perform function if needed. good luck.
Posted on Oct 25, 2008
vanni7
  • 163 Answers
SOURCE: 3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Posted on Jan 04, 2009
SOURCE: Novice here and changing a
return t-stat for another with o/b terminals
Posted on Jan 21, 2009
tborn6
  • 700 Answers
SOURCE: My outdoor heat will not
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Posted on Jan 25, 2009
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
I have a carrier heat pump model # 38RQ034300 I need instructions for. To maintenance and use thermostst correctly
That is model number for your outdoor unit. Thermostats are not dedicated to any particular model outdoor unit. You need instructions for the thermostat so the thermostat make and model number are needed.
Oct 16, 2010 | Carrier Heating & Cooling
Carrier 38CKC042300. oUTSIDE UNIT FAN WAS TURNING REAL SLOW. ac UNIT IS OFF BUT FAN TO OUTSIDE UNIT IS STILL TURNING. sHOULD NOT BE TURNING AT ALL WITH AC UNIT OFF
The outside fan may run if the unit is in defrost mode this is normal for most heat pumps it is there way of trying to keep the outside unit from staying iced over so the next time the unit runs it will have air flow through the coil and the ice will not be there to prevent air flow.
Jan 12, 2010 | Carrier 38CKC042 Air Conditioner
Install programmable Carrier thermostat
you'll be needing an assistance from an A/C technician, If this a progammable you want, some configuration need to be done and a technician can only do that.
You can search the web for a local carrier dealer nearest to you
Nov 05, 2009 | Carrier Heating & Cooling
My outdoor heat will not operate. It is a Carrier 38YRA042330, with a Carrier Thermidistat thermostat and a Carrier Air Handler 40FFKB005300. I have an H5 error code on the thermostat will I put it in...
Jan 25, 2009 | Carrier Heating & Cooling
Wiring diagram to connect programmable Thermo to Heat Pump
I don't know if this will be helpful or not, but I just installed a new Honeywell and the Honeywell customer service guy helped me get the wires done correctly. The number is 800-468-1502.
Jan 05, 2009 | Honeywell Programmable Thermostat Heater
My cARRIER ROF TOP IS SHORT CYCLING IN THE HEAT PHASE
have you checked the filters? May be cycling on the high limit due to not enough air going across the burners.
Also what type of thermostat do you have if it's a manuel one then the heat anticipator may be set wrong.
or the air from a register may be hitting trhe thermostat causing it to short cycle.
Dec 20, 2008 | Carrier Heating & Cooling
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
