Question about Frigidaire 24 in. FDB635RF Built-in Dishwasher
Er uo message on display of frigidaire dishwasher fdb4050lhb1
Brand new not 2 months old just started last week doing this
  • Anonymous Apr 25, 2009
    I have the same problem - Dishwasher 4 months old - ER UO error. What do you do?
SOURCE: Frigidaire PLD3465REC dishwasher error??
Hi, I am having the same problem you describe above with the model nr PLD3460RDC1. Were you able to find out what it was? Thanks so much!
Posted on Aug 18, 2006
  • 3 Answers
SOURCE: error code
We had the same problem with our Frigidaire dishwasher (different model though). We called them and they said the UO stands for Vent Open (the display can't make a V so it makes a U). The active vent was not closing when it should be closed (the repairman said the gasket was stuck up in the assembly so sometimes it would seal and sometimes it wouldn't) and thus the error. Since our machine was still under warranty, we had the vent replaced at no cost and haven't had the problem since.
Posted on Dec 29, 2007
SOURCE: Error code ER then UO any ideas?
The vent fan on the top right hand side at the back of the dishwasher, has wires coming down the side. The wires were not conected they had to be plugged in. The Er uo code stopped flashing and the dishwasher started working.
Posted on Oct 11, 2008
SOURCE: Error Message 'Er' on frigidaire dishwasher
I had the same problem. I pressed the "Start Cancel" button, kept it down, then pressed "Rinse Only" button. The display then went clear. I pressed "Start Cancel" again, then "83" showed up on the display. I let it run its cycle, then it corrected itself. A little scary, but it worked. This answer board is great!
Posted on Feb 22, 2009
SOURCE: 6 mo. old frigidaire d/w displays the "ER clean S" flashing error
Probably a control panel failure. This unit does not ventfrom the front like most do, so there needs to be some clearance above the top of the tub to avoid blocking the vent fan, otherwise moisture gets trapped in the machine and works it's way into the control panel eventually.
Posted on Apr 08, 2009
What does code Uo mean on the dishwaher
It is a Vent problem. The vent aids drying at the end of the cycle.
Frigidaire Diswasher ER UO Error code [FIXED] - Appliance Repair ...
forum.partsdr.com > Forum > Appliance Repair Help > Dishwasher Repair
May 25, 2012 - 20 posts - ‎3 authors
The ER UO error code means "Vent Open". On the top back right corner of the dishwasher tub, there is a vent and fan that opens to help dry the ...
Frigidaire Dishwasher Error Codes - What To Check - How To Reset ...
https://removeandreplace.com/.../frigidaire-dishwasher-error-codes-what-to-check-ho... Feb 18, 2016 - The error code will display where the usual numbers are on the display screen. .... Do you have an error code on your Frigidaire dishwasher and need ..... Can you tell me what do you mean by "knockout plug has been removed"? ... Frigidaire dishwasher manual says UO error code is vent assembly error.
Diagnose UO Error Code - Dishwasher - YouTube
? 3:15
https://www.youtube.com/watch?v=pvJTiTd35vI
Dec 22, 2016 - Uploaded by Byrd Appliance Specialists
Byrd Appliance Specialists 3825 Gilbert Dr., Ste. 342 Shreveport, LA 71104 www.byrdas.com 318-459-8745 ...
My Samsung washing machine is showing a UE code during a spin ...
www.samsung.com/uk/support/skp/faq/1025292 Jul 5, 2016 - Your appliance will display a UE code when it has detected an unbalanced load and has stopped the ... If the door remains locked and the machine is displaying UE error, please run a drain program. ... What does this mean?
LG Help Library: Error Codes - Dishwasher ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library May 10, 2017 - An error code on the display of the dishwasher can usually be resolved by performing a few simple troubleshooting steps.
LG Help Library: UE Error Code - Top Load Washer ' LG U.S.A
www.lg.com > Home > Support > Product Help > Help Library Sep 1, 2017 - After 3 attempts to balance, the uE will change to UE, meaning the unit was unable to rebalance the load and requires assistance. To determine ... What does code UE mean on the dishwasher Google Search
Oct 31, 2017 | Dishwashers
Message "er" and "uo" on front panel and slight bumping noise
The UO code on most Frigidaire dishwashers means that the vent at the back of the dishwasher is open (or at least the sensor is claiming it is open). Since this vent should be closed except during the drying cycle, the unit will not start. This avoids having the washer spray water into your cabinet during the wash cycle.
The vent sensor is an optical sensor that is inside the vent assembly. So there are a few places that could fail causing the error. First check the wiring and the connectors for the wires between the vent and the CCU (main control board). If there are any broken wires or corrosion the message may not be reaching the control board. Replace any faulty wiring. If the wiring is fine, try replacing the vent assembly. On some Frigidaire models, the wiring and the vent assembly need to be replaced at the same time. If that doesn't solve the problem then the control board needs to be replaced.
Please note: when I look at the parts for the FDB1050REC0, I found a static dryer vent, http://www.appliancepartspros.com/frigidaire-static-dry-vent-154433001-ap3214620.html . Please make sure that you are buying the parts for the correct model dishwasher.
I hope this helps.
Dec 17, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
Model number FDB4050LHB1, is very loud when operating and does not dispense cleaning tablets or liquid, cycles through but does not clean, and cleaning tablet or liquid still in door, tablet door will not...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Nov 28, 2010 | Frigidaire 24 in. FDB635RF Built-in...
Frigidaire = Garbage
go with a kenmore reasonable price ....work very well and sears is very good re their appliances per warranty
Aug 23, 2009 | Frigidaire 24 in. PLD3465REC Stainless...
Dishwasher er error code
I have a similar problem with my Frigidaire FDB4050LHS1. My Owner's Manual says to contact the Customer Care Center if the display shows "Er", "uF", or "CE". When I called them, Maria didn't have a clue what the codes meant - all she could do was give me phone numbers to authorized service centers in my area.
I managed to get ahold of a "SERVICE DATASHEET" P/N: 154718601. The error code "ER/ER" means there is a "switch failure"; "ER/CE" denotes a "Configuration Error"; "ER/uo" means "Vent will not close"; and "ER/UF" means "Fan not running".
The schematic only labels three switches - labeled "USER INTERFACE SWITCH", "DOOR SWITCH", and "FLOAT SWITCH". There is also a switch in the pump motor assembly. If either the door or user interface switch is faulty, then you probably won't be able to do anything other than call a repair service - unless you know how to replace these switches yourself.
If the float switch is causing the error, you might be able to run the "Water/Service Test". From "PF" (denoting a Power Failure) or idle mode (with no lights on whatsoever), press and hold the "DRY/AIRDRY" and "START/CANCEL" buttons at the same time for 3 seconds. This will start an 8-stage test that runs for about 7 and 1/2 minutes. The display will show which step the test is in until it shows an error code. Step 1 tests the water valve, which is where the float switch is located. If that switch is bad, you will likely see "Uo" displayed within the first minute of the test.
Aug 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Error code
Nov 26, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Er message on panel of Frigidaire GLD3450RD
I had the same problem last spring. Unfortnuatly, the problem is within the electronic control. Steam leaks in, due to an improper seal ring. Humidity stay in the compartment and eventually, the contact on the wire ribbon corrodes. For me, it meant a new electronic module.
If the eletronic module is ok, then the only working solution require that you order and install a "fit kit" from Frigidaire.
Some models even have a recall made form Frigidaire. Better check with them.
Nov 15, 2007 | Frigidaire 24 in. GLD3450RD Built-in...
So far so good. I fixed mine by removing the vent and even though it says no repairable parts I disassembled it then removed the rubber gasket and cleaned it with a brush under hot water. I then cleaned the plastic ring it seals against. Next I removed the spring and stretched it to make it about a quarter inch longer and then reinstalled the spring then the rubber gasket and then closed up the unit. So far it is working fine. I suspect the real problem is that there is a tiny sensor that needs to be covered when the vent is closed. If this is not covered the uo error code is generated.
Apr 22, 2007 | Frigidaire 24 in. PLD3465REC Stainless...
Frigidaire 24 in. FDB635RF Built-in Dishwasher Logo
416 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
