Question about HTC Cell Phones
My phone is stuck on airplane mode and wont allow me to make calls
When i try to make a call it comes up, make sure airplane mode is switched off. i go in to settings and airplane mode seems to be frozon
Noggin
  • 944 Answers
SOURCE: Airplane Mode..
Here is the link to the user manual; http://www.nextel.com/assets/pdfs/en/support/guides/phones/i265/ug.pdf Check page 119 of the manual (129 of the pdf)says: "Sometimes you may want to have your phone on,but turn off its ability to make and receive calls, such as when you are on an airplane. To set your phone so that it cannot make or receive phone calls, Direct Connect calls, Group Connect calls, Talkgroup Calls; or transfer data: 1 From the main menu, select Settings > Advanced > Airplane Mode. 2 Set this option to On. This icon U appears. Note: Pressing p for more than 5 seconds also turns on Airplane mode. To restore your phone?s ability to do all these things: Set this option to Off." Hope this helps :)
Posted on Jun 29, 2007
  • 54 Answers
SOURCE: my samsung upstage phone is stuck in offline mode
Has the phone been dropped or gotten wet? If you look at the antenna area are there any cracks in the housing? If any of these are true you may have a bad connection between the antenna and the main board of the phone. If you can see any cracks in the housing i would recommend taking it to the shop for repair. Its not too expensive a repair usually around 30 to 40 dollars. If you need any help let me know!
Posted on Jan 11, 2008
SOURCE: airplane mode
I have found that if you press and hold the power key when turning on the phone, it can activate the airplane mode. Try to press and release it when turning it on to stop this problem.
Posted on Jul 10, 2008
SOURCE: LG shine stuck on headset mode
reset the phone or cntuck to lg care
Posted on Apr 10, 2009
SOURCE: M001 Phone when trying to make a call it says : NOT ALLOWED DIAL"
This is for another similar clone marked with the "vaio" name but it might be useful to someone out there. I found that by following solution one above (thanks Mrfixit) to step 6 as below and then following the second part of what I found at http://chinamobiles.org/archive/index.php/t-16088.html worked for me. I reproduce the steps below:
1. make sure to have 2 sims in phone(do not use 3g sims) 2. make sure wlan is disabled 3. enter engineer mode (type in *#3646633# 4.scroll up not down to number 10 RF test tool 5.choose gsm touch ok verify ok touch power scan 6.select band dcs 1800 press ok phone will go to test looking for DES(frequencies) wait until phone crashes or seems inactive
BUT THEN
Connect your mobile via USB cable to a PC, DO NOT CONFIRM any connection mode at your mobile, just and ONLY connect the cable!!!
11. Press the Menu button (second from the left, the one with the seven small dots on it) until you are at the main menu with the 12 icons on the display.
12. Go to "Settings" --> "Network Setup" --> "SIM1 network setup"
13. Go to "Preferred mode" and choose "GSM preferred" or "GSM only"
14. The mobile will switch to your selection, but the message that it will stays on display. Do not press anything else, just wait for about 10 - 15 seconds.
15. Disconnect the USB cable from the phone, it will show you that it has switched to your selection.
16. Get back to main menu, switch off and restart the mobile --> DONE
Posted on Oct 23, 2009
My phone says In Airplane mode, but replacing SIM card did not help?
You just have to go to sertings and turn off airplane mode.
May 07, 2017 | Cell Phones
Hello, asking for my daughter, her phone wont receive calls and she cant place calls
First of all make sure the SIM card is active and you have network signals, secondly try to find out if the fone is kept in offline mode or airplane mode.
If you find everything proper, try to insert the sim in another device and make sure the SIM is working correctly
Feb 16, 2015 | Samsung GALAXY S4
My huawei phone is stuck on airplane mode cant turn it off how do i turn airplane mode off
Sometimes these phone get stupid. Pull the battery out, wait about 30 minutes. Then put the battery back in, and turn it on. Go to your settings using a different method than you normally do, (they have a couple) and try rather than turning off your plane mode turn ON your mobile mode. Good luck.
Oct 25, 2014 | Huawei Metropcs M750 M750
My sharp phone is stuck in airplane mode, help
scroll up from the bottem of your phone click on airplane mode then slide off
Jul 06, 2014 | Cell Phones
My iphone 4 has just stopped working in the phone mode, i can slide to unlock and type text etc but the phone options are stuck? what have i done?
I would advise you to back-up your data just in case you may need to restore your phone if all else fails.
  • Try restarting your phone, if it's Jailbroken, your springboard may be messed up and require you to restart or "respring" your phone.
  • If you phone can't make any calls or won't allow you to, you may be in Airplane mode. Go to your Settings and check if your Airplane mode is OFF.
  • Do a hard restart on your phone by holding the power button + home button and then waiting for your phone to turn off and on again.
If that all fails, restore your iPhone 4 via iTunes and it should be working again.
Mar 08, 2011 | Apple iPhone Smartphone
What is airplane mode and how do i get out of it??
Airplane Mode (Motorola CLIQ™ with MOTOBLUR™)
NOTE: Airplane mode turns off the wireless radio. This allows you to use programs while travelling on an airplane, but not make or receive calls. An Airplane icon appears on top of the signal bar when airplane mode is active.
To turn Airplane mode on or off, refer to the following:
Using the Lock key
To use the Lock key to turn off Airplane mode, perform the following steps:
1. At the Home screen, press and hold the Power/Lock key on the right side of your phone.
2. At Airplane mode, tap On or Off.
Using the Settings menu
To turn the Airplane mode on or off using the Settings menu, perform the following steps:
1. At the Home screen, press the Menu key.
2. Tap Settings.
3. Tap Wireless controls.
4. Tap Airplane mode to turn on or off.
Dec 04, 2010 | Motorola Mobility CLIQ Cell Phone
Touch diamond stuck in airplane mode, gwes error
try updating your ROM, you find everything on HTC website in support section
Jun 27, 2009 | HTC Touch Diamond Smartphone
About my Daughter phone
Check with your operator for 'firmware updates'.
That will address many problems.
May 08, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Cell Phones Logo
54 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
