Question about Car Audio & Video
I have a 99 Saturn 87k miles Well when I drive the car won't shift out of 2nd gear and revs up to 3-4 Rpms at 25mph sometimes it'll shift back into gear but if I add transmission fluid it's fine I usu
I have a 99 Saturn 87k miles Well when I drive the car won't shift out of 2nd gear and revs up to 3-4 Rpms at 25mph sometimes it'll shift back into gear but if I add transmission fluid it's fine I usually add 2-3Q but after 15-20miles of driving it the transmission fluid is empty already! I dnt c n e leaks??
    New Friend:
The leak could be internal or where you can't see! Which is causing it to get hot and burn the fluid!
Posted on Apr 24, 2013
Trouble shifting into 2nd gear and reverse but drives good once it shifts?
No not the whole transmission. Could be a band or servo. It still has to come out and be tore down to fix.
Nov 22, 2015 | 1996 Ford Explorer
Transmission
A/T tranny issues. (solenoid )
my auto tranny is slipping in call gears. forward and reverse?
there are no guessing, just tests.
check all fuses.
check AFT levels using the operators guide, (dont guess at ways, do it right way, as 99% dont)
so DRIVE is stuck in 1st gear, or 2nd?
the connect the jumper for the TCM, and get the flash codes.
if it says VSS is dead, then it is.
why wonder this. the TCm will not lie, it will see any bad VSS signals and report them on all cars made. but has flash codes this year.
there are 3 or 4 paths here
1; inputs to TCM wrong, sure it will shift wrong. how could it not.
2: TCM bad , it has good inputs and its outputs are wrong.
3: the TCM to tranny connections are bad, (corrosion)
4: the Solenoids have the correct inputs but fail to work.
bad solenoids or far far worse.
note the order here.. only this works unless guessing with $1500 fist of dollars is ok.
the FSM covers each tests. from 1 to 4.
for on car tests. if the solenoid tests pass its a bad tranny.
Feb 12, 2014 | 1993 Toyota Camry
Truck sometimes revs and jerks back into 1st out of 2nd when yuor just idling around
run fault codes and look for a problem TCM. The problem is the engine at idle and gear changing is when the management system is trying to select the best gear for the rpms and as soon as it selects up the rpms drop so it shifts down and the cycle is repeated.
Oct 30, 2013 | Cars & Trucks
Rpms rev but car does not go when gas i pressed then transmission feels like it engages
possible that there is an issue with the torque converter clutch servo/solenoid operation
take it to an accredited service center and have it properly diagnosed
Apr 23, 2017 | 2008 Saturn VUE
2002 silverado 1500 HD Transmission skips second gear
have the fault codes read to find out the servo/solenoid that is not working'
check that the vacuum actuator for the transmission is working and that the vacuum hose is connected
that is the unit that makes ratio changes possible at certain rpms and vacuum settings from accelerator pedal positions
Apr 21, 2017 | 2002 Chevrolet Silverado 1500HD
My '99 VW bug doesn't catch 2nd gear sometimes
the gear changing selectors are faulty and needing inspecting for damage ,gear box removal job
Jul 10, 2010 | 1999 Volkswagen Beetle
Transmission will not shift out of 1st gear.
Check your transmission fluid level. If the filter has never been changed, now is a good time to replace the fluid and filter.
Jul 11, 2009 | 1993 Saturn SC2
Used transmission installed and doesnt shift at the right rpms
Ck your trans modulator., and if not already done, you pan filter and fluids
Jun 06, 2009 | 1992 Chevrolet C1500
The engine rpms rev when shifting
Your trans is slipping, u are going to need to have it checked out at a trans shop, they will test drive it in most cases for free and report what they think is wrong or recommend more diagnostic work if they are unsure..
May 21, 2009 | 1999 Honda CR-V
Car Audio & Video Logo
182 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
