Question about Toshiba Televison & Video
Toshiba TV 22BV500B Menu freeze, will not go to SET UP
During resetting TV's in home the Toshiba menu freezes and will not go to SET UP
SOURCE: toshiba 32a33 32"tv
My dad and I fixed the TV/Video problem over the weekend using one of the solutions suggested. Make sure you stay away from the red wire running from the back of the tube to the circuit board.
1. Take the cover off the back of the TV.
2. On the bottom of the TV is a circuit board that is mounted on top of a plastic tray. Remove the cables running from the speakers by squeezing the tab on the white plug and pulling them up and off the board.
3. Looking at the back of the TV, pull the board+tray out (barely secured in there) and flip it 180 degrees so you're looking at the front of the board.
4. Desolder and remove the TV/Video push button. It's labeled on the PCB, and should be the second button in from the left.
5. Place the tray back in the TV and make sure the other buttons still remaining on the baord are aligned with the buttons on the front of the TV.
6. Put the cover back and you're done.
TV works as good as new again. Of course I can't use the TV/Video button on the TV itself, but the remote handles that fine. 20 minutes max, and no repairman needed.
Posted on Jul 07, 2008
SOURCE: toshiba 36a40
Double check that the Demonstration in the menu is not set to on. This will cause it to keep scrolling thru.....
Posted on Sep 05, 2008
  • 26 Answers
SOURCE: WII Console Freezes up
You may check out Wii Fix Guide to fix the problem yourself. This DIY guide will show step by step pictures to fix the problems yourself without any technical knowledge........
Posted on Apr 09, 2009
  • 556 Answers
SOURCE: My toshiba tv is going through all the menu options and wont stop
you have it in the demo mode go into the menu and turn auto demo off.
Posted on Aug 07, 2009
Fixe_You
  • 1800 Answers
SOURCE: nextar ma852-801 mp3 freezing...reset?
Hi.
Welcome To Fixya Community.
Solution 1:
  • Try to Turn it ON/OFF(Reset).
If that isn't Working try This:
Solution 2:
  • You are going to upgrade the Firmware of your Mp3 Player in order to perform that follow these Steps:
  • Installation of the Upgrade Tool:
  1. Download the Upgrade Tool application (the download link is in the bottom of this Solution) to your computer.Double click the application.Follow the instructions shown on the screen to complete the installation.Firmware Upgrade:Note: All the existing files in the player will be erased while upgrading,please make a copy of your files before doing this.Turn on MA852-801 player. Press and hold the MENU button todisplay the main menu. Select “Settings” → “System” →“Upgrade” and press the MENU button to confirm. Select “Yes”and then connect the device to a computer via USB interface once you see the following window:
2. Select ”Program files” 􀃆 ”Firmware Update” from the Start
menu or double click the “Firmware Update” icon on the
desktop. You will see the following window shown on the
screen:
6fc021c.jpg***************************************************************************************
3. Click Open button, and specify the upgrading firmware with
the extension “ .rfw ” (Please download the firmware from
Nextar website named MA852-801 – updated firmware.rfw).
Click Update button to start upgrading.
Note: This process may take about 2 minutes depending on the
computer system you use. Please don’t disconnect while upgrading,
it may cause serious damage to the player.
4. Once it shows "Firmware update successful"wording in
“Update Info” window, then click Exit button to finish
upgrading.
*************************************************************************************(5) 5. Safely remove the player from the PC.
6. Turn on the player. Please wait about 20 seconds for the
player to automatically initialize settings.
Downloads:
Upgrade Tool.
Firmware File.
Additional Help:
Nextar Ma852-801 Mp3 Player Manual Guide.
please don't hesitate asking me if you need any Further Info.
Thank You For Using Fixya.
Good Luck.
Posted on Nov 04, 2009
Toshiba 50 inch flat screen is on retail lock cant reset by remote or unplugging tv what can i do
There should be someplace in the menu that says first time setup or initial setting or something similar where it steps you through setting your TV. During that process it will ask you to choose between home or retail. Make sure you complete all the steps. If you can't find it in the menu, give me the model number and I will look it up.
Feb 21, 2015 | Toshiba Televison & Video
Toshiba 32BL505B- 32 inch TV - Lack of settings - No Installation, or TV Settings.. Please Help
1. Press the menu button on the remote
2. Once the menu comes up press the numbers 7935 in succesion
3. This should bring up the hotel menu, turn off the hotel mode at the top of this screen
4. Then press the menu button to exit out of the menu and next time you press the menu button there should 6 icons available
Jan 10, 2013 | Televison & Video
I just bought 32 inch 2 hours ago, and am using it with an antenna. Almost every time I turn to channel 5, the remote freezes and I can't even use the buttons on the side of the tv. I have to...
This is my second set in as much days from Best buy. Exact same problem.
Sep 21, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
Manual for 22bv500b
Please click on the link below to download the manual for your TV:
http://www.toshiba-om.net/LCD/PDF/English/Country_Specific/BV500-22-English-Specific.pdf">Toshiba 22BV500B User Manual
The manual will open in a new browser window or you can click on the link with your right mouse button and choose "Save Target As..." from the pop-up menu to save it directly to your PC. You will need to have Adobe Reader or another PDF file viewer installed on your PC to open the file
Click here to download Adobe Reader
Hope this helps. If you have any difficulty downloading the manual or need further assistance with your TV, please let me know.
Regards,
BElectric.
Apr 27, 2011 | Toshiba Televison & Video
Re: Playstation 3 Console (60 GB) - Freezing I've had my 60GB PS3 for around 24 months and it has been fine. Recently, it has started freezing in two ways: 1. Either just leaving the playstation doing...
I seem to have a very similar problem to yours on the 60GB as well. I am curently doing the total reformat but it takes a long time to do it and i have to go to work while it is reformating. So anyway if it works i will let you know. me e mail george_masono@hotmail.com
Dec 29, 2009 | Sony Playstation 3 (PS3) Console
I have a samsung TV that freezes temporarily.
i've just some digging around and found that you can access a service menu and perform a reset which sorted the issue for me.
Access the service menu by pressing, in order, whilst the tv is in stand-by mode:
info
menu
mute
power
when the tv comes back on you will have a service menu; select option 12 (reset) the tv will then switch off.
this will reset your TV back to factory defaults.
turn tv back on and you should be prompted to go through the plug and play setup again - go through everything and then all should start working OK
Nov 11, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
My sansa fuze keeps freezing
Start the sansa updater, set sansa to recovery mode plug into computer. unplug when told sansa should restart (Lock sansa press and hold rec and menu until recovery begins)
Also you can Try
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....
Nov 02, 2009 | SanDisk Sansa Fuze MP3 Player
Freeze
it is the problem of remote setting only. call somebody for help.
Sep 20, 2007 | Toshiba 35A44 35" TV
Televison & Video Logo
19 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
