Question about LG Studioworks 700S 17" CRT Monitor
I have LG 700S 17" Monitor
My Computer Configuration is P4 1.700 GHz, 1.5 GB DDR RAM, 80GB IDE HDD.
When i install Vista Ultimate. After the Installation is complete. Vista Starts for the first time. it shows preparing .... to start Windows Vista for the first time.
After that screen, My computer does not hang up but black screen is displayed with a mouse pointer in center which i am able to move. after that black screen nothing is displayed.
Please help....
  • 253 Answers
Try tapping f8 when you start your computer and when at the MS startup menu choose
  • Enable low resolution video (640x480)
  • and if windows starts update your video driver and that should fix the problem, when you restart more than once the options go back to default (not low res video,whatever video driver is installed)
    Posted on Mar 30, 2009
    Barracuda (ST380215A) 80 GB IDE (ULTRA ATA) 7200.10 Hard Drive Problem While installing Windows Xp sp3 hard drive not detect @ partition screen System configuration is as: Processor:- AMD Athlon XP...
    Seems like your hard drive is malfunctioning, try another HD. That 80gb is already obsolete and the circuit board might have some defect.
    If you could pull out the underside circuit and clean the gold contact points and try it again, if still not working...... buy a new one!
    Check also the jumper and cable it must be in the "master" configuration.
    Hope that helps you out!
    Thanks for asking FixYa!
    Aug 09, 2011 | Seagate Barracuda (ST380215A) 80 GB IDE...
    LG Studioworks 700S 17" CRT Monitor, on screen
    Dear Sir,
    This problem is not from monitor side,check computer RAM.Clean it twice and reinstall it on place.If you are using VGA card then disconnect it from PCI slots and connect VGA cable to on board VGA . I think it solves your problem.Let me know
    Jan 08, 2011 | LG Studioworks 700S 17" CRT Monitor
    I am using Intel845 motherboard and intel 2.4 p4 processor and 1gb ram. Can i install windows vista or windows 7 or microsoft server 2008 , is they supported to my Configuration. Any updates need to meet...
    For Windows Vista to work : It requires minimum 2.0 ghz processor, 1 gb RAM and 60-80GB hard disk.
    For Windows 7 : It requires minimum processor 3.0 ghz, 1 gb RAM and 60-80 GB hard disk.
    Otherwise, your operating system or hardware problem will occur.
    Dec 29, 2010 | Microsoft Computers & Internet
    When I install vista os the blue screen appear in monitor(Dumping physical memory in disk). i used (...80gb sata HDD) ...
    The operating system is not compatible with the physical configuration of you computer...
    this is the reason...
    install XP and install a tranformation pack for vista to have a glossy look of vista in XP...
    Aug 22, 2010 | Intel D845GVSRL 533MHz FSB 845GV Chipset...
    How much i can upgrade my d530 ultra slim desktop RAM and HDD
    You can install up to a max 2 GB RAM and can add a 2nd hard disk
    See the following Specs for your computer.
    dotclear.gif HP Compaq Business d530 Ultra-Slim (Pentium 4 2.8GHz, 256MB RAM, 40GB HDD, XP Pro) Type Personal computer
    • Product Form Factor Ultra-slim desktop
    • Built-in Devices Speaker
    • Width 12.4 in
    • Depth 13.1 in
    • Height 2.8 in
    • Weight 15.4 lbs
    • Color Silver
    Processor
    • Type Intel Pentium 4 2.8 GHz
    • Installed Qty 1.0
    • Max processors supported 1.0
    Cache Memory
    • Type L2 cache
    • Installed Size 512.0 KB
    • Cache Per Processor 512 KB
    Mainboard
    • Chipset type Intel 865G
    • Data bus speed 533.0 MHz
    RAM
    • Installed Size 256.0 MB / 2.0 GB (max)
    • Technology DDR SDRAM
    • Memory Speed 333.0 MHz
    • Memory Specification Compliance PC2700
    • Form Factor DIMM 184-pin
    • Upgrade Rule Max 2 x 1 GB module
    Storage Controller
    • Type 1.0 x IDE - Integrated - PCI
    • Controller interface type ATA-100
    Storage Controller (2nd)
    • Type 1 x Serial ATA - Integrated
    • (2nd) storage controller interface type Serial ATA-150
    Storage
    • Floppy drive type None
    • Hard Drive 1.0 x 40.0 GB - Standard - ATA-100 - 7200.0 rpm
    • Hard Drive (2nd) None x None
    Dec 08, 2009 | HP Compaq Business d530 Ultra-Slim PC...
    I cannot get it to install on Vista, is there a problem?
    Could you mention the computers configuration on which you are trying to install windows Vista and what error or symptoms you are getting when you try to install Vista
    Vista installation can fail
    1. If memory (RAM) is bad
    2. Hdd is corrupt or has bad sectors
    3. Optical Drive is Bad
    Thanks for using fixya
    Proton
    Aug 28, 2009 | LG Flatron L1710B 17" LCD Monitor
    Finding Intel 845GVSR & 915GLVG Compatible Motherboard & Proc
    you can use intel dg41 mbd , dualcore processor,1 gb ram,160 gb hdd or use intel atom for support contact 91-9645071021
    Aug 11, 2009 | Intel D845GVSR Motherboard
    Ihad a ACER Aspire 5052AWXMi, AMD Turion MK38,
    yes you can upto 2GB and 160GB HDD
    bkas your laptop having DDR ram, 80GB is ATA HDD,
    Jun 22, 2009 | Computers & Internet
    845 mb dsplay diver for windows vista
    what PC model, what monitor?? what video card??
    need mor einformation in order for use to help you.
    Oct 23, 2008 | Microsoft Windows Vista Ultimate Edition
    Adding Ram
    The RAM should be fine running along side each other but make sure you check the motherboard specs install the RAM leave running for 5-6 hours see how it goes also try memtest86 on your system here is the link
    http://www.memtest86.com/
    Regards,
    Spud
    Jun 18, 2008 | Computers & Internet
    LG Studioworks 700S 17" CRT Monitor Logo
    132 people viewed this question
    Top LG Computers & Internet Experts
    Alun Cox
    Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
