Question about RME Fireface-800 56-Channel 24-Bit/192kHz FF800
ADA8000 NO SYNC - click and pops!!! ADAT out from RME to ADAT IN in ADA8000.
Can I bridge two behringer fca1616?
With firewire it is possible, I've ran a live show with 2 FCA1616 connected over firewire and an ADA8000 hooked up to one of two's ADAT inputs.
You just have to make sure that you let them all synchronise to the internal clock of one of your interfaces. So one is the master and listens to its own clock, and the other listens to the other ones clock over firewire.
Or you can just push a few buttons until it works :p
Feb 21, 2014 | Behringer FIREPOWER FCA1616 Firewire...
Tip
When Using ADAT with Digidesign Interface (Fix pops & clicks)
When you connect a device (a lightpipe optical ADAT for example) to your audio interface such as the Digi 003 be sure to change the "Hardware" settings in the File Menu, from internal to optical, and ADAT for using for using an optical ADAT device, such as the M-Audio Octane. This will stop the pops and clicks that happen when the clocking is not set for ADAT.
on Dec 08, 2009 | Digidesign 003 Rack Firewire Audio...
Digital in out
The ada800 gives out 8 channels of ADAT, the edirol UA-25 are only stereo opticals and not compatible with the ADA8000 as it does not have any adat inputs or outputs.
Hope this helps
Jan 31, 2010 | Edirol UA-25 External Sound System
Im tryna get songs on my mp3 player and i dont no what website to go to i need to no the websites order fo rme to download songs on my mp3 player and i have the usb cord i just dont no how to download...
you can use websites like itunes.com and get the music then use windows media player to sync the songs to your mp3 player just load the music you get into the windows media player library and then drag them over to a sync window and click on the sync button :)
Nov 27, 2009 | Emerson BAR901 MP3 Player
My facebook website is looked
You will need to conatct Facebook directly. They will be able to answer your question.
Nov 09, 2009 | RME Intelligent Audio Solutions RME...
What driver I can get?
Hi !
You need SoundMAX Audio Driver version 5.12.01.3663 WHQL driver for Windows
And you can get it from here: asus_download_pics01.gif Global
Good luck
Nic
Mar 04, 2009 | RME Intelligent Audio Solutions RME...
How so i expand the outputs on a motu using adat
You have to goto motu audio/midi setup an config the optical output to adat and make sure you set the sample rate to 48000 and check your setting in audio/midi setup in your system preference under mac this should solve the problem.
Dec 08, 2008 | Motu Traveler (8250) Audio Input
Tape torn near end. How to fix????
You'll have to open it up, but be very careful doing this. It can be done though, with a steady hand.
Nov 11, 2007 | Quantegy ADAT: ADAT: 60 Minutes ADAT...
RME Fireface-800 56-Channel 24-Bit/192kHz FF800 Logo
19 people viewed this question
Top RME Computers & Internet Experts
David Payne
David Payne
Are you a RME Computer and Internet Expert? Answer questions, earn points and help others
