Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
I have a jandy one touch and when I program my spa filter to go off, it stays on. Help
    Top Expert:
  • Jandy Master
  • 8,686 Answers
See if you have any other programs overriding it
Posted on Mar 05, 2016
  • 128 Answers
SOURCE: We have the Jandy AquaLink RS PDA, we have two
If you have a spa side remote unplug it at the outside control panel. If the problem stops it's the remote
Posted on Aug 30, 2009
  • 246 Answers
SOURCE: We have an AquaLink RS4 All Button control in the
can't be made the only is to cancel the delay on the back dip #4 heater cool down turn off breaker when do this also change assign jva at system setup
Posted on Sep 13, 2009
  • 5 Answers
SOURCE: I have Jandy RS4 system with 4-button poolside
Pull the cover off the control panel. You will probably find a button which would be accessible from outside the panel with a paper clip or pencil but is unlabeled. On the board itself by the button, in small letters it should say "reset". Push the button and see what happens.
Posted on Oct 09, 2009
  • 990 Answers
SOURCE: Jandy Aqualink rs4 when set on auto the system
Go through your menu again and reset. These have defaults that may be causing the trouble if the power went out or your battery backup is old. Check this and let me know and we can look further. Your menu should help to walk you through problems, it is very user friendly. Hope this helps, let me know.
Posted on Nov 07, 2009
  • 990 Answers
SOURCE: Jandy aqualink rs8.Pool and spa lights wont come
If it's both lights and they are on seperate switches I would start by checking the GFCI and be sure it is not tripped and if it is you would need to find out why. Then check power in and out of the light module in your power center. If you can set the power center to service and turn the lights on manuley from there then it is programming but most of the time it will be something in the lights or their circut.
Posted on Mar 06, 2010
How to I cancel filter program and add new one
go to system setup go to progam highlight filter or whatever you want to either program or change highlight and then change or add
Jul 19, 2014 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy one touch control panel model 8156 - spa turns on when pool is on
if you have a 4 button spa side remote unplug if it goes away replace spa side remote
Aug 03, 2012 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do I delete an Aqualink RS4 program? The filter is on all the time. When I set a new program start and stop time the controller keeps adding programs versus replacing an/the existing programs.
to delete a program go to system set up go to programs add or delete or edit if doing on its own disconnect spa side remote if goes away replace spa side remote if no spa side reset board clear memory and re program write down all auxs and JVAs
Dec 26, 2010 | Jandy Aqualink Rs4 One Touch Control...
How do you clear all programs for the filter and spa on the AquaLink RS24 touchpad?
Their should be a small hole in the bottom right corner of the touch pad. (I think, could be left) You can use a tooth pick or a paperclip to push through the hole and that will clear all memory.
Dec 04, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
How do you reset the programs? Unit is saying
You need to hit the menu button and go into program. In there you will see each item, such as the filter that is on a schedule. When you hit the filter, it will have 3 options, add, remove, or change. Just hilight the schedule and hit remove, that program will be deleted.
May 15, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink rs4 when set on auto the system goes from filter to spa (the spa never having been programed).
Oct 25, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jet blower randomly starts ...
most of the time this is caused by a faulty spa side controller. If you trace the line from the spa and disconnect it see if that solves the problem.
Jul 24, 2009 | Jandy Aqualink Rs4 One Touch Control...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
